Suggestions on wiring 2005 Jeep Grand Cherokee for being Towed by the Bird?
03-12-2006, 07:08
Howdy, Y'all.
I want to hook up the wiring apparatus on my 2005 Jeep Grand Cherokee so that the correct connections are made between my 1993 Wanderlodge and the GC. via the umbilical cord. Anyone towing a Jeep GC? What did you do? Thank you, Jack(unemployed) [ ][Non-text portions of this message have been removed] |
03-12-2006, 08:34
Hi-Jack,
After several lousy attempts to connect the Jeep directly to the coach using the "diode" method, I finally purchased the "independent" system from Camping World which included a separate light and socket for each Jeep tail sidelight. Carefully drilled into the plastic lens' for the sockets and brought the wires from the Jeep rear to the front bumper and attached to the provided socket. Now the only power comes directly from the Bird and goes directly to the independent sockets at the rear; no more diode problems connecting thru the Jeep electronics. John Suter 2000LXi and '01 Jeep Grand Cherokee P.S. What? No sullied-up Texan unhappily stuck in Florida anymore? LOL --- Jack and Liz Pearce > Howdy, Y'all. > I want to hook up the wiring apparatus on my 2005 > Jeep Grand Cherokee so > that the correct connections are made between my > 1993 Wanderlodge and > the GC. via the umbilical cord. Anyone towing a > Jeep GC? What did you > do? > > > Thank you, > Jack(unemployed) [ ]> > > > > [Non-text portions of this message have been > removed] > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
03-12-2006, 14:07
Liz/Jack,
Get the kit that requires you install a 2nd bulb in the taillight fixtures. This method completely isolates the Jeep's 12V system from that of the Bluebird. Many, if not MOST, Grand Cherokee owners use this option. It is simple and certainly non-invasive. I used a kit from Blue Ox that supplied everything you need. BX8869 Bulb and Socket Tail Light Wiring Kit instructions: http://www.blueox.us/PDFS/BX8869.PDF Blue Ox Accessories http://www.blueox.us/Accessories/wiring.htm I have used this method in a Grand Cherokee for 3 years, werks Grate! Jay Darst 85PT40 Springfield, IL where the tornado sirens are blasting. Storm will hit here in about 23 minutes, so gotta find some shelter- this should be a biggy! 1 1/2 inch hail! Sure am glad the Bird is stored INSIDE! Later.... --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy, Y'all. > I want to hook up the wiring apparatus on my 2005 Jeep Grand Cherokee so > that the correct connections are made between my 1993 Wanderlodge and > the GC. via the umbilical cord. Anyone towing a Jeep GC? What did you > do? > > > Thank you, > Jack(unemployed) [ ]> > > > > [Non-text portions of this message have been removed] > |
03-13-2006, 02:48
Hi Jack,Liz,
Several of the other posts detailed how our toad is wired. We have the separate wire and bulbs drilled into the toad tail light lens. I then used a meter to find the signals. You're welcome to come over to see what I have and I'll help get it working. Craig 91 PT40 WPB, FL --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy, Y'all. > I want to hook up the wiring apparatus on my 2005 Jeep Grand Cherokee so > that the correct connections are made between my 1993 Wanderlodge and > the GC. via the umbilical cord. Anyone towing a Jeep GC? What did you > do? > > > Thank you, > Jack(unemployed) [ ]> > > > > [Non-text portions of this message have been removed] > |
03-13-2006, 05:56
Howdy, Jay.
<<<<<--- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > Liz/Jack, > > Get the kit that requires you install a 2nd bulb in the taillight > fixtures. This method completely isolates the Jeep's 12V system from > that of the Bluebird. > > Many, if not MOST, Grand Cherokee owners use this option. It is > simple and certainly non-invasive. > > I used a kit from Blue Ox that supplied everything you need. > > BX8869 > Bulb and Socket Tail Light Wiring Kit > instructions: > http://www.blueox.us/PDFS/BX8869.PDF > > Blue Ox Accessories > http://www.blueox.us/Accessories/wiring.htm > > I have used this method in a Grand Cherokee for 3 years, werks Grate! > > Jay Darst > 85PT40 > Springfield, IL where the tornado sirens are blasting. Storm will > hit here in about 23 minutes, so gotta find some shelter- this > should be a biggy! 1 1/2 inch hail! Sure am glad the Bird is stored > INSIDE! Later.... Wooow!!! Are you OK? Family OK? Thanks for the reply. I don't see how to fit another light bulb in my Jeep's tail light assembly. I am uploading some photos of the tail light assembly. I think that I'll nname the album "2005 GC tail lights". Suggestions and/or ideas are welcome. Thanks, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL |
03-13-2006, 12:56
Liz,
Just looking at the photos, it appears that Jeep made some design changes in the 05 tail light assembly that are not necessarily improvements in my mind. On my 1995 GC, and moved over to my 2004, I used the Blue Ox kit Jay referred to. Easy and simple install, no cutting into the factory wiring - too many electronics to mess up on new vehicles. The tail light assemblies on the 95 and 2004 GCs had another housing portion of the tailights assembly that had no bulb in it. According to the literature, it was originally for emergency vehicles to add lights. You drill a 1 and 1/8 inch hole and insert the light socket. Looking at your pictures, I do not see the extra lighting compartment for emergency vehicle usage any more. However, it looks like you should have room to install the extra bulb in the top red light enclosure, if you measure the clearances carefully. You may have to mount it from the side to match up with that hole in the body panel. It will become clearer if you check out the installation instructions on the Blue Ox site for the BX8869 Bulb and Socket Tail Light Wiring Kit http://www.blueox.us/Accessories/wiring.htm As they say: Does not tap into vehicle existing wiring, simple to install, fits most vehicles with *clearance* in taillight housing, operated by the towing vehicle. It's a very simple installation really. I think it was about $20 for the kit. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy, Jay. > <<<<<--- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > Liz/Jack, > > > > Get the kit that requires you install a 2nd bulb in the taillight > > fixtures. This method completely isolates the Jeep's 12V system from > > that of the Bluebird. > > > > Many, if not MOST, Grand Cherokee owners use this option. It is > > simple and certainly non-invasive. > > > > I used a kit from Blue Ox that supplied everything you need. > > > > BX8869 > > Bulb and Socket Tail Light Wiring Kit > > instructions: > > http://www.blueox.us/PDFS/BX8869.PDF > > > > Blue Ox Accessories > > http://www.blueox.us/Accessories/wiring.htm > > > > I have used this method in a Grand Cherokee for 3 years, werks Grate! > > > > Jay Darst > > 85PT40 > > Springfield, IL where the tornado sirens are blasting. Storm will > > hit here in about 23 minutes, so gotta find some shelter- this > > should be a biggy! 1 1/2 inch hail! Sure am glad the Bird is stored > > INSIDE! Later.... > > Wooow!!! Are you OK? Family OK? > Thanks for the reply. I don't see how to fit another light bulb in my > Jeep's tail light assembly. I am uploading some photos of the tail > light assembly. I think that I'll nname the album "2005 GC tail lights". > Suggestions and/or ideas are welcome. > > Thanks, > Jack > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Homesick Texans in SE. FL > |
