1980 FC33 questions
03-13-2006, 18:37
1980 FC33 questions
Hello everyone
I have some questions on an 80 fc33 that I am considering. I have some
conserns I hope to gain some knowledge on.
Right now there is no power from the Kubota 10kw genset to the couch
The couch has a Telma Retarder and a Jake brake
This is an 1980 with a 3208 turbo. current owner ststes previous owner
told him it came from factory that way
Has been sitting for past year did put some algeside in fuel tank
new belts are being installed along with radiator at shop. nonswing
when I go to look at it I will take Harvey's checklist
goat rails modifided
oil and fluid change done regularly does have blue box and recor
Hugh Turner
Thomaston Ga
94 Jep GC
possible 80 FC33
03-14-2006, 02:08
1980 FC33 questions
You want an electric couch??? I've heard of electric blankets, but
couches? Is the switch in the compartment just to the left of the
entrance steps in the 'Gen' position or in the shorepower position?
It could be as simple as that.
Extremely unlikely to be an original engine. I'm pretty sure Cat was
not turbocharging the 3208 in 1980 so it must be a later edition. The
first year BB put the 3208T in was 83 I believe. If it is a retrofit,
one thing to keep in mind is that the 3208NA ran a couple of hundred
rpm's faster than the 3208T. As a result, there was a lower gear
ratio in the rear end of the NA models than the turbo models (I
believe). This means that a retrofitted 3208T will give you more
power up thru the gears and climbing hills, but a lower top speed
unless the governor has been turned up to allow higher rpm's that
match the NA model, or the rear end gear ratio changed. I think
turning up the governor will increase exhaust gas temperatures.
Kerry
82FC35
Denver
--- In WanderlodgeForum@yahoogroups.com, "Hugh Turner"
> Hello everyone
> Hugh Turner
> Thomaston Ga
> 94 Jep GC
> possible 80 FC33
03-14-2006, 14:10
1980 FC33 questions
Kerry is correct. To the best of my knowledge, the first 3208Ta
installation is in the '83 FCs. Earlier ones would have been the
210hp Na (or in some rare instances the 190hp 3208Na Kalifornia
version evident from the valve-cover sticker or the extra wires on
the injection pump).
The standard gear ratio of the Na coaches was 5.29:1 which wouldn't
be tall enough for the 200rpm lower 3208Ta, plus the torque-converter
is different from the non-turbo to the turbo models. Very few early
Na coaches had the optional 4.63:1 gears which would make this engine
useable, turning up the RPM limits on the engine is a good way to
shorten its life.
- Jeff Miller
in Holland, MI
The
retrofit,
> Kerry
> 82FC35
> Denver
> > Hello everyone
some
couch
owner
nonswing
> > Hugh Turner
> > Thomaston Ga
> > 94 Jep GC
> > possible 80 FC33
03-14-2006, 16:11
1980 FC33 questions
Jeff and Kerry
Thank you for pointout the fact that I forgot that stupid"a". I
thought I had read that the 83 was the first year that had the
turbo.I did call Bernie at the plant today he told me if I could get
the body or chassis number he would look it up and see what the it
left the plant with. When I read what had been done he told me it
sounded like it was an up grade for the better. If I get it i will
have to remeber to turn the Jake of if we ever arrive late somewhere.
I would never turn a diesel up to mas RPM it would not be worh what
could come out of the side of the block. I do not know if the rear
end chuck was changed or not I am not sure if present owner does or
not.
Does anyone live in the Houston area that is qualified to do the
coach PDI or knoww anyone that is ? I have found ashop that can do
the bus mechanical side.
Hugh Turner
94 Jeep GC toad
Thomaston GA
Getting closer hopefully
converter
engine
> shorten its life.
> - Jeff Miller
> in Holland, MI
but
position?
was
edition.
> The
> retrofit,
hundred
> > Kerry
> > 82FC35
> > Denver
> > wrote:
> > > Hello everyone
have
> some
> couch
previous
> owner
tank
> nonswing
> > > Hugh Turner
> > > Thomaston Ga
> > > 94 Jep GC
> > > possible 80 FC33
03-14-2006, 17:12
1980 FC33 questions
Kerry, I think this is a typical typo. We all can not be accomplished
typists. I think the intended message from Hugh is clear. The motor
info is dead on..but to chastise someone for a typo?? I guess it is
as rediculous as "recycleing grey water" hmmm ...or not taking the
time to research their "couch" in the Blue Box or from the forum
achives! Nuff said on this.
Scott B
86FC
SC
The
retrofit,
> Kerry
> 82FC35
> Denver
> > Hello everyone
some
couch
owner
nonswing
> > Hugh Turner
> > Thomaston Ga
> > 94 Jep GC
> > possible 80 FC33
03-14-2006, 17:16
1980 FC33 questions
I was joking, not chastising.
Kerry
> Scott B
> 86FC
> SC
> The
> retrofit,
> > Kerry
> > 82FC35
> > Denver
> > wrote:
> > > Hello everyone
> some
> couch
> owner
> nonswing
> > > Hugh Turner
> > > Thomaston Ga
> > > 94 Jep GC
> > > possible 80 FC33
03-14-2006, 17:31
1980 FC33 questions
Kerry, please accept my apologies, I did not discern the humor there.
I guess based on Hugh's response (post # 9481) neither did he.
However, I generally do not make jokes at someone elses expense,
again please accept my appology.
Scott B
86FC
SC
> Kerry
accomplished
motor
is
> > Scott B
> > 86FC
> > SC
but
position?
Cat was
edition.
> > The
> > retrofit,
hundred
gear
more
speed
that
> > > Kerry
> > > 82FC35
> > > Denver
> > > wrote:
> > > > Hello everyone
have
> > some
> > couch
previous
> > owner
tank
> > nonswing
recor
> > > > Hugh Turner
> > > > Thomaston Ga
> > > > 94 Jep GC
> > > > possible 80 FC33
03-14-2006, 17:59
1980 FC33 questions
I was joking. It conjured up a bizzare image of a humanitarian
penitentiary substituting an electric couch for the electric chair.
Kerry
> Jeff and Kerry
> > > > Hugh Turner
> > > > Thomaston Ga
> > > > 94 Jep GC
> > > > possible 80 FC33
03-14-2006, 19:05
1980 FC33 questions
Ralph fullenwider can do a PDI for you. Ernie
03-15-2006, 02:29
1980 FC33 questions
Scott
Thank you
I guess an electric couch could have many uses 1.for people you do
not like strap them to it(electric chair only longer). 2 for those of
us that consider it our second bed we cound install a thermostat for
those chilly days. Smile
Hugh
> Scott B
> 86FC
> SC
> The
> retrofit,
> > Kerry
> > 82FC35
> > Denver
> > wrote:
> > > Hello everyone
> some
> couch
> owner
> nonswing
> > > Hugh Turner
> > > Thomaston Ga
> > > 94 Jep GC
> > > possible 80 FC33
