Sporlan Water Valve- Changeout
03-15-2006, 10:15
Has anyone ever replced one of these? Now that all my water lines are
repaired- and I have pressure, the valve that is used to fill the
fresh tank is obvously not working. EWhen I hook up city water, it
starts to fill the tank- without regard to the valve switch on or off.
I can hear the valve clicking and trying to work, but it does not. The
water pump also is affected by this- because it does not seal the
loop, and lets water bypass around in a circle.
I have even thought about seeing if there was a type of manual valve
with a push/pull type cable to open and close the connection.
Help??!
Stephen
81 FC-33SB
Plant City, FL
03-15-2006, 11:38
--- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...>
Stephen, I have not replaced the full valve, but was able to get a
repair kit and replace the innards. Easy to do. Works great. I
followed the instructions provided by Ralph F, which at the moment,
I cannot seem to find. Basically, you likely need to clean or
replace the inner seal "disk".
Links are hard to paste in Yahoo so search for Sporlan.com and you
will get the company, and there are downloads for parts. I'll stick
the service/part sheet in the files here and at Wanderlodge FC in a
few moments. Good luck.
Frank
85FC33
are
off.
The
valve
> Help??!
> Stephen
> 81 FC-33SB
> Plant City, FL
03-16-2006, 05:10
Steven, I have the same problem you described.(89sp). I have my
valve out right now, and ordered a rebuild kit from bb yesterday,
$30.00.. The valve(I could only get the top off with 4 bolts)and it
was filled with a white scum from water contamanites.I understand
from other owners that it sticks in this condition and causes what
you described.
good luck
Ed Gardels 89sp
Arlington, Texas
are
off.
The
valve
> Help??!
> Stephen
> 81 FC-33SB
> Plant City, FL
03-16-2006, 05:20
Is the diaphragm in good condition? A while back I took mine apart,
removed the white stuff, lightly cleaned the diaphragm, and reassembled
it. Works great so far.
.Curt Sprenger 1987 PT38, Anaheim Hills, Calif.
> you described.
> good luck
> Ed Gardels 89sp
> Arlington, Texas
03-16-2006, 05:28
Yes curt, the diaphram was dirty but now looks clean and new. It was
soooo hard to get at(behind bedroom dresser which i had to
dismantal) that i thought I would put in new parts.Was yours hard to
get to?
edgardels 89sp
Arlington Texas
apart,
reassembled
> ED GARDELS wrote:
> > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@>
it
what
> > you described.
> > good luck
> > Ed Gardels 89sp
> > Arlington, Texas
03-16-2006, 06:28
Ed,
No too bad. Mine was between walls that support the bed and keep the
water tank in place. A space about 12 inches by 24 inches, filled with
plumbing. Lifted the mattress and supported it, removed the mattress
platform, and stuck my head in under the mattress and cussed the whole
time. About a half hour job. It would take all day if I had to R&R the
valve body.
> get to?
> edgardels 89sp
> Arlington Texas
> apart,
> reassembled
> it
> what
> > > you described.
> > > good luck
> > > Ed Gardels 89sp
> > > Arlington, Texas
> SPONSORED LINKS
> Recreational vehicles
<http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\
les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\
bWmSYTw>
> Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\
derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\
tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>
> Automotive maintenance
<http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\
cC1O9CxA>
> Recreational vehicle dealer
<http://groups.yahoo.com/gads?t=ms&k=Recr...ional\
+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\
HfELr6o72IW1A>
> Used recreational vehicles
<http://groups.yahoo.com/gads?t=ms&k=Used...onal+\
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\
&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\
kXbDI4ZSadEw>
> Automotive radiators
<http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\
es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\
ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\
_4GlXA>
> YAHOO! GROUPS LINKS
> * Visit your group "WanderlodgeForum
> <http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
03-16-2006, 07:24
My valve was not clogged, or full of anything. I took it apart before I knew
I had problems, because it was leaking(the big o-ring) I went to the local
hardware store, and got a new o-ring.. Well it does not leak, but it does
not stop water from flowing either. The rubber disc was clean, and soft..
but I guess it has sit up dry for a long time, and the top rubber does not
seal the hole anymore??.. I guess I need a rebuild kit. When I go outside
and move the "tank Fill" switch on/off, I hear a clicking sound inside.. I
assume the solenoid is trying to open/close. and it is getting power. What
cha think?
Stephen
81 FC-33SB
Plant City, Fl
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger
Sent: Thursday, March 16, 2006 1:28 PM
Subject: Re: [WanderlodgeForum] Re: Sporlan Water Valve- Changeout
Ed,
valve body.
> get to?
> edgardels 89sp
> Arlington Texas
> apart,
> reassembled
> it
> what
> > > you described.
> > > good luck
> > > Ed Gardels 89sp
> > > Arlington, Texas
_____
03-16-2006, 07:29
Stephen I believe you can get re-build kits from Stephen Birtles. Give him a
shout.
Quoting Stephen <share@...>:
> cha think?
> Stephen
> 81 FC-33SB
> Plant City, Fl
>   _____
> Ed,
> valve body.
> > get to?
> >   edgardels 89sp
> >   Arlington Texas
> > apart,
> > reassembled
> > it
> > what
> > > > you described.
> > > >    good luck
> > > >   Ed Gardels 89sp
> > > >   Arlington, Texas
>   _____
> SPONSORED LINKS
> Wanderlodge
> YAHOO! GROUPS LINKS
> Visit your group "WanderlodgeForum" on the web.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
03-16-2006, 09:10
Ed- so thats where your sporlan valve was located. Ernie-83pt40 in Texas
-----Original Message-----
Sent: Thu, 16 Mar 2006 10:28:25 -0800
Ed,
valve body.
> get to?
> edgardels 89sp
> Arlington Texas
> apart,
> reassembled
> it
> what
> > > you described.
> > > good luck
> > > Ed Gardels 89sp
> > > Arlington, Texas
> SPONSORED LINKS
bWmSYTw>
> Wanderlodge
cC1O9CxA>
HfELr6o72IW1A>
kXbDI4ZSadEw>
_4GlXA>
> YAHOO! GROUPS LINKS
Yahoo! Groups Links
03-16-2006, 12:04
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote:
yes ernie, the valve is on the floor behind the built in dresser. I
had to dismantle the dresser cabinet and jack it up enough to get my
upper torso in to get the top off the valve. I can barely see it. Any
way it was coated with white mineral stuff which I cleaned off. since
its so hard to get to I thougt it best to put in new parts. By the way
I fixed my gen set(wouldnt fire). Changed fuel filter and tightned alt
belt.
edgardels 89sp
arlington texas
Texas
> From: Curt Sprenger
> Ed,
> valve body.
> > get to?
> > edgardels 89sp
> > Arlington Texas
> > apart,
> > reassembled
> > it
> > what
> > > > you described.
> > > > good luck
> > > > Ed Gardels 89sp
> > > > Arlington, Texas
> > SPONSORED LINKS
bWmSYTw>
> > Wanderlodge
cC1O9CxA>
HfELr6o72IW1A>
kXbDI4ZSadEw>
_4GlXA>
> > YAHOO! GROUPS LINKS
> Yahoo! Groups Links
