Broken valves and broken dreams
03-15-2006, 13:26
It should be noted that BlueBird recommended and I quote; Keep it around 2000
rpm. The recommendation is for the 3208. Cat calls 2400 rpm in marine applications, "continuous cruise speed". Some people think it's wise to check valve adjustment every 50k miles, some think that's too much. I check it more often as I fear broken parts and I DO NOT EVER take short cuts with my vehicles of any kind. However, ignorance is bliss for most folks and occasionally the bite in the butt from reality hurts. Weak valve springs is the most common cause of valve failure, springs can lose tension in storage. At rest, some valves are open at max lift and some are closed. Those that are open can take a set and lose closing strength, this allows the valve to bounce in operation, compound the problem by running 2700/2800 rpm and some times stuff breaks. Watch that valve lash and check the valve spring tension regularly, other wise, keep your fingers crossed. Ain't diesels fun? Mike Hohnstein Germantown, WI 83FC35 [Non-text portions of this message have been removed] |
03-16-2006, 12:32
<MHOHNSTEIN@...> wrote: > > It should be noted that BlueBird recommended and I quote; Keep it around 2000 rpm. The recommendation is for the 3208. Cat calls 2400 rpm in marine applications, "continuous cruise speed". > Some people think it's wise to check valve adjustment every 50k miles, some think that's too much. I check it more often as I fear broken parts and I DO NOT EVER take short cuts with my vehicles of any kind. > However, ignorance is bliss for most folks and occasionally the bite in the butt from reality hurts. > Weak valve springs is the most common cause of valve failure, springs can lose tension in storage. At rest, some valves are open at max lift and some are closed. Those that are open can take a set and lose closing strength, this allows the valve to bounce in operation, compound the problem by running 2700/2800 rpm and some times stuff breaks. > Watch that valve lash and check the valve spring tension regularly, other wise, keep your fingers crossed. Ain't diesels fun? > Mike Hohnstein > Germantown, WI > 83FC35 > > [Non-text portions of this message have been removed] Just one nagging question and that concerns the chart on the Vintage Bird site! it states that at 2000 RPM' at 3208 n/a engine in a F/C unit speed will be 48 MPH. Now lets get real about keeping it at 2000 RPM's and going down a freeway. Do you think when these coaches came out that the Bluebird Corporation stated in there factory manuals that there motor coaches would last allot longer if they were only driven under 50 MPH? I might be different than most drivers but I try to keep my speed at 55 but not 48 mph on the freeway. Does anyone have a drivers manual for one of these old units? it would be interesting to check it out and see what corp. said in those days. Jon 1978 Wanderlodge Bremerton Washington > |
03-16-2006, 13:35
Hmm, 2200 is 55 in your "vehicle", sounds like "around" 2 grand to me. Mebbe
you need a hobby? MH ----- Original Message ----- From: Jon To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 16, 2006 6:32 PM Subject: [WanderlodgeForum] Re: Broken valves and broken dreams --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > It should be noted that BlueBird recommended and I quote; Keep it around 2000 rpm. The recommendation is for the 3208. Cat calls 2400 rpm in marine applications, "continuous cruise speed". > Some people think it's wise to check valve adjustment every 50k miles, some think that's too much. I check it more often as I fear broken parts and I DO NOT EVER take short cuts with my vehicles of any kind. > However, ignorance is bliss for most folks and occasionally the bite in the butt from reality hurts. > Weak valve springs is the most common cause of valve failure, springs can lose tension in storage. At rest, some valves are open at max lift and some are closed. Those that are open can take a set and lose closing strength, this allows the valve to bounce in operation, compound the problem by running 2700/2800 rpm and some times stuff breaks. > Watch that valve lash and check the valve spring tension regularly, other wise, keep your fingers crossed. Ain't diesels fun? > Mike Hohnstein > Germantown, WI > 83FC35 > > [Non-text portions of this message have been removed] Just one nagging question and that concerns the chart on the Vintage Bird site! it states that at 2000 RPM' at 3208 n/a engine in a F/C unit speed will be 48 MPH. Now lets get real about keeping it at 2000 RPM's and going down a freeway. Do you think when these coaches came out that the Bluebird Corporation stated in there factory manuals that there motor coaches would last allot longer if they were only driven under 50 MPH? I might be different than most drivers but I try to keep my speed at 55 but not 48 mph on the freeway. Does anyone have a drivers manual for one of these old units? it would be interesting to check it out and see what corp. said in those days. Jon 1978 Wanderlodge Bremerton Washington > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
03-16-2006, 13:45
I have a 78 FC 33 with a non turbo 3208. My mechanic
says to keep it under 2500 however that is also around 55-60. I have others tell me that work on Cats that those motors love to rev.... i am also confused??? Help Chris 78 FC 33 Palmdale, ca "Seguro" --- Mike Hohnstein <MHOHNSTEIN@...> wrote: > Hmm, 2200 is 55 in your "vehicle", sounds like > "around" 2 grand to me. Mebbe you need a hobby? > MH > ----- Original Message ----- > From: Jon > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, March 16, 2006 6:32 PM > Subject: [WanderlodgeForum] Re: Broken valves and > broken dreams > > > --- In WanderlodgeForum@yahoogroups.com, "Mike > Hohnstein" > <MHOHNSTEIN@...> wrote: > > > > It should be noted that BlueBird recommended and > I quote; Keep it > around 2000 rpm. The recommendation is for the > 3208. Cat calls 2400 > rpm in marine applications, "continuous cruise > speed". > > Some people think it's wise to check valve > adjustment every 50k > miles, some think that's too much. I check it > more often as I fear > broken parts and I DO NOT EVER take short cuts > with my vehicles of > any kind. > > However, ignorance is bliss for most folks and > occasionally the > bite in the butt from reality hurts. > > Weak valve springs is the most common cause of > valve failure, > springs can lose tension in storage. At rest, some > valves are open at > max lift and some are closed. Those that are open > can take a set and > lose closing strength, this allows the valve to > bounce in operation, > compound the problem by running 2700/2800 rpm and > some times stuff > breaks. > > Watch that valve lash and check the valve spring > tension regularly, > other wise, keep your fingers crossed. Ain't > diesels fun? > > Mike Hohnstein > > Germantown, WI > > 83FC35 > > > > [Non-text portions of this message have been > removed] > > > Just one nagging question and that concerns the > chart on the Vintage > Bird site! it states that at 2000 RPM' at 3208 n/a > engine in a F/C > unit speed will be 48 MPH. Now lets get real about > keeping it at 2000 > RPM's and going down a freeway. Do you think when > these coaches came > out that the Bluebird Corporation stated in there > factory manuals > that there motor coaches would last allot longer > if they were only > driven under 50 MPH? I might be different than > most drivers but I try > to keep my speed at 55 but not 48 mph on the > freeway. Does anyone > have a drivers manual for one of these old units? > it would be > interesting to check it out and see what corp. > said in those days. > > > Jon > 1978 Wanderlodge > Bremerton Washington > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge > Automotive maintenance > Recreational vehicle dealer Used > recreational vehicles Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the > web. > > b.. To unsubscribe from this group, send an > email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the > Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been > removed] > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
03-16-2006, 14:51
The CAT operators manual for my coach says nothing about optimal rpm.
It says do not run it above the rated rpm on the engine plate (2800rpm for a 210hp na). It says it can be run at full load between the rated rpm and 1900rpm (for NA) It does say DO NOT run it at full load under 1900rpm (for short periods, down to 1400 rpm's) for an NA or not below 1400rpm for a turbo. If they thought there was an optimal rpm, why not include it within all those limits? Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Mr Chris Valdes > > I have a 78 FC 33 with a non turbo 3208. My mechanic > says to keep it under 2500 however that is also around > 55-60. I have others tell me that work on Cats that > those motors love to rev.... > i am also confused??? > > Help > Chris > |
03-16-2006, 15:02
I told the forums the way it is, there are plenty of "other"folks who like to
talk with out facts or reality to back up their remarks. I know what I'm talking about. MH ----- Original Message ----- From: Mr Chris Valdes To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 16, 2006 7:45 PM Subject: Re: [WanderlodgeForum] Re: Broken valves and broken dreams I have a 78 FC 33 with a non turbo 3208. My mechanic says to keep it under 2500 however that is also around 55-60. I have others tell me that work on Cats that those motors love to rev.... i am also confused??? Help Chris 78 FC 33 Palmdale, ca "Seguro" --- Mike Hohnstein <MHOHNSTEIN@...> wrote: > Hmm, 2200 is 55 in your "vehicle", sounds like > "around" 2 grand to me. Mebbe you need a hobby? > MH > ----- Original Message ----- > From: Jon > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, March 16, 2006 6:32 PM > Subject: [WanderlodgeForum] Re: Broken valves and > broken dreams > > > --- In WanderlodgeForum@yahoogroups.com, "Mike > Hohnstein" > <MHOHNSTEIN@...> wrote: > > > > It should be noted that BlueBird recommended and > I quote; Keep it > around 2000 rpm. The recommendation is for the > 3208. Cat calls 2400 > rpm in marine applications, "continuous cruise > speed". > > Some people think it's wise to check valve > adjustment every 50k > miles, some think that's too much. I check it > more often as I fear > broken parts and I DO NOT EVER take short cuts > with my vehicles of > any kind. > > However, ignorance is bliss for most folks and > occasionally the > bite in the butt from reality hurts. > > Weak valve springs is the most common cause of > valve failure, > springs can lose tension in storage. At rest, some > valves are open at > max lift and some are closed. Those that are open > can take a set and > lose closing strength, this allows the valve to > bounce in operation, > compound the problem by running 2700/2800 rpm and > some times stuff > breaks. > > Watch that valve lash and check the valve spring > tension regularly, > other wise, keep your fingers crossed. Ain't > diesels fun? > > Mike Hohnstein > > Germantown, WI > > 83FC35 > > > > [Non-text portions of this message have been > removed] > > > Just one nagging question and that concerns the > chart on the Vintage > Bird site! it states that at 2000 RPM' at 3208 n/a > engine in a F/C > unit speed will be 48 MPH. Now lets get real about > keeping it at 2000 > RPM's and going down a freeway. Do you think when > these coaches came > out that the Bluebird Corporation stated in there > factory manuals > that there motor coaches would last allot longer > if they were only > driven under 50 MPH? I might be different than > most drivers but I try > to keep my speed at 55 but not 48 mph on the > freeway. Does anyone > have a drivers manual for one of these old units? > it would be > interesting to check it out and see what corp. > said in those days. > > > Jon > 1978 Wanderlodge > Bremerton Washington > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge > Automotive maintenance > Recreational vehicle dealer Used > recreational vehicles Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the > web. > > b.. To unsubscribe from this group, send an > email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the > Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been > removed] > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
03-16-2006, 15:14
Yo, Kerry, you have a rig that's 24 freekin' years old, you want to run that
tired old tank at 100%, be my guest. You and Jon should talk to Ralph F about the way things are. He could bring some interesting tidbits to your attention. I have turned wrenches professionally for 30 years and I can deal with Cat mechanics as equals. Most of the people in vehicle service in the Milwaukee metro area know who I am. That said, I have NEVER talked to a competent Cat man who thinks it's OK to run a 'throwaway' against the governor. You guys who know better have at it. Hope it don't blow up when you loan it out to some "tourist". MH ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 16, 2006 8:51 PM Subject: [WanderlodgeForum] Re: Broken valves and broken dreams The CAT operators manual for my coach says nothing about optimal rpm. It says do not run it above the rated rpm on the engine plate (2800rpm for a 210hp na). It says it can be run at full load between the rated rpm and 1900rpm (for NA) It does say DO NOT run it at full load under 1900rpm (for short periods, down to 1400 rpm's) for an NA or not below 1400rpm for a turbo. If they thought there was an optimal rpm, why not include it within all those limits? Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Mr Chris Valdes > > I have a 78 FC 33 with a non turbo 3208. My mechanic > says to keep it under 2500 however that is also around > 55-60. I have others tell me that work on Cats that > those motors love to rev.... > i am also confused??? > > Help > Chris > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
03-16-2006, 15:21
I asked a simple question. I said nothing about how I would run my
vehicle. Do you know why CAT did not put optimal rpm's in their manual? I don't see what any of this has to do with who drives my vehicles. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Yo, Kerry, you have a rig that's 24 freekin' years old, you want to run that tired old tank at 100%, be my guest. > You and Jon should talk to Ralph F about the way things are. He could bring some interesting tidbits to your attention. I have turned wrenches professionally for 30 years and I can deal with Cat mechanics as equals. Most of the people in vehicle service in the Milwaukee metro area know who I am. That said, I have NEVER talked to a competent Cat man who thinks it's OK to run a 'throwaway' against the governor. You guys who know better have at it. Hope it don't blow up when you loan it out to some "tourist". > MH > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, March 16, 2006 8:51 PM > Subject: [WanderlodgeForum] Re: Broken valves and broken dreams > > > The CAT operators manual for my coach says nothing about optimal rpm. > It says do not run it above the rated rpm on the engine plate > (2800rpm for a 210hp na). It says it can be run at full load between > the rated rpm and 1900rpm (for NA) It does say DO NOT run it at full > load under 1900rpm (for short periods, down to 1400 rpm's) for an NA > or not below 1400rpm for a turbo. If they thought there was an > optimal rpm, why not include it within all those limits? > > Kerry > 82 FC 35 > Denver > |
03-16-2006, 15:25
Caterpillar had weak valve springs in the early 80'S, we replaced thousands in
truck engines, there were other applications that used the same spring and they gave no trouble if the engine was not in a truck. as far as rpms we had 3208's in several applications, med duty trucks, scrapers, and irragation engines, and excavators. the irragation engines ran at full load for weeks on end sometimes when their was a drought, in an excavator you fire it up ,warm it up, move to full throttle and dig holes and ditchs all day. the medium duty trucksi think in those days the speed limit was 55MPH but not sure. strrong engine but keep your valves adjusted. re -------------- Original message from "Mike Hohnstein" <MHOHNSTEIN@...>: -------------- I told the forums the way it is, there are plenty of "other"folks who like to talk with out facts or reality to back up their remarks. I know what I'm talking about. MH ----- Original Message ----- From: Mr Chris Valdes To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 16, 2006 7:45 PM Subject: Re: [WanderlodgeForum] Re: Broken valves and broken dreams I have a 78 FC 33 with a non turbo 3208. My mechanic says to keep it under 2500 however that is also around 55-60. I have others tell me that work on Cats that those motors love to rev.... i am also confused??? Help Chris 78 FC 33 Palmdale, ca "Seguro" --- Mike Hohnstein <MHOHNSTEIN@...> wrote: > Hmm, 2200 is 55 in your "vehicle", sounds like > "around" 2 grand to me. Mebbe you need a hobby? > MH > ----- Original Message ----- > From: Jon > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, March 16, 2006 6:32 PM > Subject: [WanderlodgeForum] Re: Broken valves and > broken dreams > > > --- In WanderlodgeForum@yahoogroups.com, "Mike > Hohnstein" > <MHOHNSTEIN@...> wrote: > > > > It should be noted that BlueBird recommended and > I quote; Keep it > around 2000 rpm. The recommendation is for the > 3208. Cat calls 2400 > rpm in marine applications, "continuous cruise > speed". > > Some people think it's wise to check valve > adjustment every 50k > miles, some think that's too much. I check it > more often as I fear > broken parts and I DO NOT EVER take short cuts > with my vehicles of > any kind. > > However, ignorance is bliss for most folks and > occasionally the > bite in the butt from reality hurts. > > Weak valve springs is the most common cause of > valve failure, > springs can lose tension in storage. At rest, some > valves are open at > max lift and some are closed. Those that are open > can take a set and > lose closing strength, this allows the valve to > bounce in operation, > compound the problem by running 2700/2800 rpm and > some times stuff > breaks. > > Watch that valve lash and check the valve spring > tension regularly, > other wise, keep your fingers crossed. Ain't > diesels fun? > > Mike Hohnstein > > Germantown, WI > > 83FC35 > > > > [Non-text portions of this message have been > removed] > > > Just one nagging question and that concerns the > chart on the Vintage > Bird site! it states that at 2000 RPM' at 3208 n/a > engine in a F/C > unit speed will be 48 MPH. Now lets get real about > keeping it at 2000 > RPM's and going down a freeway. Do you think when > these coaches came > out that the Bluebird Corporation stated in there > factory manuals > that there motor coaches would last allot longer > if they were only > driven under 50 MPH? I might be different than > most drivers but I try > to keep my speed at 55 but not 48 mph on the > freeway. Does anyone > have a drivers manual for one of these old units? > it would be > interesting to check it out and see what corp. > said in those days. > > > Jon > 1978 Wanderlodge > Bremerton Washington > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge > Automotive maintenance > Recreational vehicle dealer Used > recreational vehicles Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the > web. > > b.. To unsubscribe from this group, send an > email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the > Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been > removed] > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
03-16-2006, 15:51
--- In WanderlodgeForum@yahoogroups.com, putneyflash@... wrote:
> > Caterpillar had weak valve springs in the early 80'S, we replaced thousands in truck engines, there were other applications that used the same spring and they gave no trouble if the engine was not in a truck. > as far as rpms we had 3208's in several applications, med duty trucks, scrapers, and irragation engines, and excavators. the irragation engines ran at full load for weeks on end sometimes when their was a drought, in an excavator you fire it up ,warm it up, move to full throttle and dig holes and ditchs all day. the medium duty trucksi think in those days the speed limit was 55MPH but not sure. strrong engine but keep your valves adjusted. > re > > -------------- Original message from "Mike Hohnstein" <MHOHNSTEIN@...>: -------------- > > I told the forums the way it is, there are plenty of "other"folks who like to talk with out facts or reality to back up their remarks. I know what I'm talking about. > MH > ----- Original Message ----- > From: Mr Chris Valdes > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, March 16, 2006 7:45 PM > Subject: Re: [WanderlodgeForum] Re: Broken valves and broken dreams > > > I have a 78 FC 33 with a non turbo 3208. My mechanic > says to keep it under 2500 however that is also around > 55-60. I have others tell me that work on Cats that > those motors love to rev.... > i am also confused??? > > Help > Chris > 78 FC 33 Palmdale, ca "Seguro" > > --- Mike Hohnstein <MHOHNSTEIN@...> wrote: > > > Hmm, 2200 is 55 in your "vehicle", sounds like > > "around" 2 grand to me. Mebbe you need a hobby? > > MH > > ----- Original Message ----- > > From: Jon > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, March 16, 2006 6:32 PM > > Subject: [WanderlodgeForum] Re: Broken valves and > > broken dreams > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike > > Hohnstein" > > <MHOHNSTEIN@> wrote: > > > > > > It should be noted that BlueBird recommended and > > I quote; Keep it > > around 2000 rpm. The recommendation is for the > > 3208. Cat calls 2400 > > rpm in marine applications, "continuous cruise > > speed". > > > Some people think it's wise to check valve > > adjustment every 50k > > miles, some think that's too much. I check it > > more often as I fear > > broken parts and I DO NOT EVER take short cuts > > with my vehicles of > > any kind. > > > However, ignorance is bliss for most folks and > > occasionally the > > bite in the butt from reality hurts. > > > Weak valve springs is the most common cause of > > valve failure, > > springs can lose tension in storage. At rest, some > > valves are open at > > max lift and some are closed. Those that are open > > can take a set and > > lose closing strength, this allows the valve to > > bounce in operation, > > compound the problem by running 2700/2800 rpm and > > some times stuff > > breaks. > > > Watch that valve lash and check the valve spring > > tension regularly, > > other wise, keep your fingers crossed. Ain't > > diesels fun? > > > Mike Hohnstein > > > Germantown, WI > > > 83FC35 > > > > > > [Non-text portions of this message have been > > removed] > > > > > > Just one nagging question and that concerns the > > chart on the Vintage > > Bird site! it states that at 2000 RPM' at 3208 n/a > > engine in a F/C > > unit speed will be 48 MPH. Now lets get real about > > keeping it at 2000 > > RPM's and going down a freeway. Do you think when > > these coaches came > > out that the Bluebird Corporation stated in there > > factory manuals > > that there motor coaches would last allot longer > > if they were only > > driven under 50 MPH? I might be different than > > most drivers but I try > > to keep my speed at 55 but not 48 mph on the > > freeway. Does anyone > > have a drivers manual for one of these old units? > > it would be > > interesting to check it out and see what corp. > > said in those days. > > > > > > Jon > > 1978 Wanderlodge > > Bremerton Washington > > OK I said enough about RPM's and speed but it is interesting just to see what kind of comments I would get about that chart. I wish I had enough money to put in a new set of gears for the rear end so I could keep up with today's traffic but cost wise its just not worth it. And like I said before when I'm out on the road its not how fast I get there but just the enjoyment of the rig and its being built like a tank. Wanderlodges forever!!!!!!!!!!!!!!!!!!!!!! Jon Bremerton Washington 78 Rebel Bird > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge > > Automotive maintenance > > Recreational vehicle dealer Used > > recreational vehicles Automotive radiators > > > > > > > ------------------------------------------------------------------ ------------ > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the > > web. > > > > b.. To unsubscribe from this group, send an > > email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the > > Yahoo! Terms of Service. > > > > > > > ------------------------------------------------------------------ ------------ > > > > > > > > [Non-text portions of this message have been > > removed] > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > > YAHOO! GROUPS LINKS > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > [Non-text portions of this message have been removed] > |
