Air Step and Batteries
03-20-2006, 06:20
Our batteries are failing. We have been charging them twice a day
while we are parked here in the cold. Nights down to about 17 and days in the 30's, all the campgrounds are closed so we are dry camping so Dick can see the Dr. The batteries still take a charge but don't hold it for as long as they used to. This morning the inverter quit about 6 am so we had to start the generator. Right now we have Interstate SRM 29 12 volt batteries that are 3 years old. Any thoughts on what would be good replacement? Size is a constraint. The Interstate distributor would have to order them and the RV retail place wants $88 each. We talked to a fellow at Northern Battery and he wants $63 each plus installation. We are waiting for a quote from the Trojan outlet. I think the Northern Batteries are probably made by Ray-o-Vac (local manufacturer of batteries) but don't seem to have national distribution. While I was poking around the files and databases I tried to download the file on the air step but I kept getting a message that the file was corrupted. Our air step is leaking badly again and now it won't lock in the out position. A wiggly step is a dangerous thing. One of us and it will probably be me will have to stick her head under the step and figure out how to tighten the valve so I would like diagrams and pictures so I know what I am looking for and at. Julie Bonser 1992 WLWB PT 40' on the street in Madison, WI |
03-20-2006, 07:12
Hi Julia,
If you have separate battery banks for the coach/house and for the engine, consider Gels or AGM's for the coach/house and conventional lead-acid for the engine: starting application. Either will cost you considerably more but should last up to 3 times longer. John Suter 2000LXi lead-acid starting, Gel coach --- Julia Bonser > Our batteries are failing. We have been charging > them twice a day > while we are parked here in the cold. Nights down to > about 17 and > days in the 30's, all the campgrounds are closed so > we are dry > camping so Dick can see the Dr. > The batteries still take a charge but don't hold it > for as long as > they used to. This morning the inverter quit about 6 > am so we had to > start the generator. Right now we have Interstate > SRM 29 12 volt > batteries that are 3 years old. Any thoughts on what > would be good > replacement? Size is a constraint. The Interstate > distributor would > have to order them and the RV retail place wants $88 > each. We talked > to a fellow at Northern Battery and he wants $63 > each plus > installation. We are waiting for a quote from the > Trojan outlet. > > I think the Northern Batteries are probably made by > Ray-o-Vac (local > manufacturer of batteries) but don't seem to have > national > distribution. > > While I was poking around the files and databases I > tried to download > the file on the air step but I kept getting a > message that the file > was corrupted. Our air step is leaking badly again > and now it won't > lock in the out position. A wiggly step is a > dangerous thing. One of > us and it will probably be me will have to stick her > head under the > step and figure out how to tighten the valve so I > would like diagrams > and pictures so I know what I am looking for and at. > > Julie Bonser > 1992 WLWB PT 40' > on the street in Madison, WI > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
