Rear Air Ride Adjustment
03-21-2006, 11:22
I know you have had this post alot.. However when I looked back,
didn't see much posted on my specific model... I have a 81 FC-33SB.
The left(driver side) rear does not pump up..She leans like hell
(front and rear). From what I have read, I need to check the valve
and/or the adjustment rod. Well, under the bird(with the air dump on-
so she all the way down and does not fall on me) I cannot find any
valves in the back area.. I see the single front one in the center,
but cannot get to anywere in the rear to see them. Its ether the rear
jacks in the way or the tank---in front of the wheels the mufflers,
and genny in the way.. How does one get to look at anything underthere
concerning the air susp.?
Stephen
81 FC-33SB
Plant City, FL
03-22-2006, 01:53
I have done a lot of work on mine...but I have a 35, not a 33, and it's
RB, not SB. I would suggest trying to locate the rod first, then
follow it up to the valve. But you are on the right track, it is
definately the valve of the rod.
Scott
underthere
> Stephen
> 81 FC-33SB
> Plant City, FL
03-22-2006, 02:21
Thank you for the info. I can't even find the rod!
I guess I will have to just crawl under there carefully in the center (by
the air susp, and rear axle) and see what I can see! I kind of get creeped
out under there (and I'm not claustrophobic!) I might have to take her
somewhere to get fixed. I need to make an appt over at Caterpillar to get
the valves adjusted anyway.
Thanks,
Stephen
81 FC-33SB
Plant City, Fl
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman
Sent: Wednesday, March 22, 2006 8:54 AM
Subject: [WanderlodgeForum] Re: Rear Air Ride Adjustment
Scott
underthere
> Stephen
> 81 FC-33SB
> Plant City, FL
SPONSORED LINKS
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v
ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU
kCKkU7Dzhn_ObWmSYTw> vehicles
Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2
=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use
d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP
j9U0JvqYQ>
Automotive
<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de
aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF
4u_5wI8Pmy34cC1O9CxA> maintenance
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati
onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic
le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s
ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer
Used
<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio
nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl
e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si
g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles
Automotive
<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve
hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV
MmISsCWgTnMq_4GlXA> radiators
_____
YAHOO! GROUPS LINKS
* Visit your group "WanderlodgeForum
<http://groups.yahoo.com/group/WanderlodgeForum> " on the web.
* To unsubscribe from this group, send an email to:
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
03-22-2006, 04:48
You will need to be under the center of the coach to find them. I
did all the work on mine with the air dumped, there was enough space
to crawl around under there just fine. Get where your head is up by
the differential with a flashlight and you should be able to find the
rods.
Scott
center (by
creeped
take her
to get
> Thanks,
> Stephen
> 81 FC-33SB
> Plant City, Fl
> _____
it's
> Scott
33SB.
valve
on-
any
center,
rear
mufflers,
> underthere
> > Stephen
> > 81 FC-33SB
> > Plant City, FL
> SPONSORED LINKS
> Recreational
le+dea
ig=DAU
> Wanderlodge
w5=Use
8HJdysB3QLP
> j9U0JvqYQ>
> Automotive
cle+de
sig=IF
> Recreational
+vehic
163&.s
> Used
vehicl
63&.si
> Automotive
e+deal
g=ePNV
> _____
> YAHOO! GROUPS LINKS
> subject=Unsubscribe>
> _____
