engine cut off clylinder: was Education thread
03-22-2006, 09:59
Larry:
If your talking about the single piston cylinder, engine cutoff, only two
screws hold it together. There are 2 O-rings in it. a small one that forms
the gland nut and one on the cylinder rod base. You can get o-rings for the
small one from ACE hardware. Then use a scribe pick point to remove the old
one, lube the new and insert it. The other o-ring is different, it is
skirted, so to speak to form a tighter seal on the cylinder walls and
allows less air to blow by. Most of those cylinders, it is the front small
seal that leaks.
Safe travels,
At 09:18 PM 3/22/2006 +0000, you wrote:
>Has anyone ever replaced/repaired the fuel shutoff cylinder? Mine
>leaks air so badly that the steps pop out five minutes after I shut
>down the engine?
>Thanks,
>Larry Watson
>87 PT40
>--- In WanderlodgeForum@yahoogroups.com, "Jay Darst"
>wrote:
> > Thanks Randy & Ralph!
> > Randy, I have updated tthe return springs using 2 springs with, what
> > seems to me, have an awful lot of return pressure.
> > I thought the old dual springs were contributing to my somewhat
> > sluggish throttle response, so removed one. Learned real quick when
> > I then engaged the high idle and it headed straight for Wide Open
> > Throttle, that you need the 2 return springs.
> > Seems this places quit a strain on things having some much spring
> > pressure..?
> > Ralph, I still don't find the transducer. Only thing I see is a
> > throttle cable coming from the cruise control board of crap.
> > Pictures anyone? Sure would like to slow down the high idle a bit.
> > Randy, I will add a 3rd return spring to see if it slows the high
> > idle as I know how and where to do that.
> > Thanks to both of you again!
> > Jay Darst
> > 85PT40
> > Springfield, IL
