battery update, Air Step, Primus
03-22-2006, 12:25
There is a note in the database of this web site telling of the company that
provided PRIMUS to the RV industry. Mark Dexter. Mardex was his company. He will provide information and service for PRIMUS. He is located in Elkhart Indiana. There is an over temp safety switch on each PRIKUS boiler. If you follow the hot water line out you should see them. It is a small red button with two wires on either side. Mr Dexter told me that the over temp switch's were required by RVIA but not necessary or used in Europe. You can bypass them by pulling the wires and using a bayonet fuse to jumper the wires together. I have my switch's being used because they still work, but you could use the jumper process noted above to test them. You can test the circulation pumps by relocating a wire on the relay above the boiler. Its the center wire that is taken from the outer pole to the center pole. When you do that you should be able to hear the pump and see the stream. ( call Bennie at BB for specific instructions...he told me how to do it) Usually if the circ pumps are bad you get the boiler to fire off but the overtemp switch will cut off the boiler when the failure to circulate lets the water get too hot. The read light on the control panel should only flash red when the boilers fire off. If the red light stays on you do not have the primus firing off. They way you can see if you have a circulation problem..You should be able to observe the coolant stream coming into the top of the header tank of the PRIMUS. I have the instruction manuals for PRIMUS that came with the coach. I will be happy to make them available to you if you like. Contact me at 704-664-3121. Hoe this helps john redden 91 PT-40 [Non-text portions of this message have been removed] |
03-22-2006, 14:57
1. After researching batteries and getting quotes we decided to go
for the Trojan AGM BCI Group Size 31. These should last longer than our previous batteries. The only place to buy the full range of Trojan Batteries instead of marine batteries was here in Madison at: Wisconson Power Control, LLC 6909 Raywood Rd. Ste. B1 Madison WI 53713 Telephone 608.663.4604 Contact Greg Fitch URL http://www.wipowercontrol.com They did a first rate job of installing our new batteries. The frame that held down the wet cell batteries interfered with the terminals so they strapped each battery down and put a thin sheet of fiber glass between the terminals and steel walls as extra insulation just in case there was some shifting of batteries. We asked for a discount because we were buying 8 batteries so what he did was not charge for the installation. It took about 4 hours but we are sure it was done right. We also learned that in spite of the automatic watering system we had installed the last batteries in each bank was dry. This was the automatic system sold by Camping World. 2. I did not get any response about how to determine where the valve is for the air step. It is leaking and we are having problems with step retracting properly and now it won't lock out all the time. I need to know how to find it and tighten it. 3. We looked for the switch/button? behind the Primus boilers to reset. Our boiler controlled from the Driver's Seat in front is not igniting. At least that is what I think having the red light flicker off and then come on and stay on. Any more directions on just where it would be and what it would look like. A picture would be great! We are operating with just the rear controlled primus and it is not keeping up as we would like with the cold nights here in Madison. It seems to have lost some of it's heating capacity and I don't know what would cause that. We both remember that it used to put out more heat and just one was sufficient to keep us warm below freezing. Julie Bonser 1992 WLWB PT 40' Madison, WI dry camping in a parking lot Days in the 40's nights in the high 10's. |
03-22-2006, 15:30
Julia:
The reset button is in the output line (hose) coming from the boiler. Since you have two boilers, there are two resets. If you can't see them, they will probably be less than 12" from the boiler and by running your hand along that hose, you can't miss them. If they will not hold when re-set, then simply tie the two wires together and take the buttons out of the system. They are backup high temperature switchs and will not compromise the system. As far as not heating like the system used to: might be due to many things. Have you noticed how long the boilers operate before shutting off? Have you turned your control knob CW as far as it will go on the panel? If you have and you are not getting enough heat, then the control board could be defective, the Thermister, located in the galley area could be bad or you could have air trapped in the system preventing proper flow. Let us know more about what you find. (Suggest you move back to where it is warmer) (BG) R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Julia Bonser > > 1. After researching batteries and getting quotes we decided to go > for the Trojan AGM BCI Group Size 31. These should last longer than > our previous batteries. The only place to buy the full range of > Trojan Batteries instead of marine batteries was here in Madison at: > > Wisconson Power Control, LLC > 6909 Raywood Rd. Ste. B1 Madison WI 53713 > Telephone > 608.663.4604 > Contact Greg Fitch URL http://www.wipowercontrol.com > > They did a first rate job of installing our new batteries. The frame > that held down the wet cell batteries interfered with the terminals > so they strapped each battery down and put a thin sheet of fiber > glass between the terminals and steel walls as extra insulation just > in case there was some shifting of batteries. We asked for a discount > because we were buying 8 batteries so what he did was not charge for > the installation. It took about 4 hours but we are sure it was done > right. We also learned that in spite of the automatic watering > system we had installed the last batteries in each bank was dry. This > was the automatic system sold by Camping World. > > 2. I did not get any response about how to determine where the valve > is for the air step. It is leaking and we are having problems with > step retracting properly and now it won't lock out all the time. I > need to know how to find it and tighten it. > > 3. We looked for the switch/button? behind the Primus boilers to > reset. Our boiler controlled from the Driver's Seat in front is not > igniting. At least that is what I think having the red light flicker > off and then come on and stay on. Any more directions on just where > it would be and what it would look like. A picture would be great! > > We are operating with just the rear controlled primus and it is not > keeping up as we would like with the cold nights here in Madison. It > seems to have lost some of it's heating capacity and I don't know > what would cause that. We both remember that it used to put out more > heat and just one was sufficient to keep us warm below freezing. > > > Julie Bonser > 1992 WLWB PT 40' > Madison, WI dry camping in a parking lot Days in the 40's nights in > the high 10's. > |
03-22-2006, 17:05
The rear boiler will operate as long as it is called on. The setting
on the CW is the same setting as in the past which is a comfortable temperature for us. We suspect it is air trapped in the system as the reservoirs were quite low when we added antifreeze. I wish we could have stayed where it was warmer. Unfortunately due to having a HMO we had to return to frigid Wisconsin for Dick to get medical care. He had his blood work today and sees the Dr. on Friday to figure out what next. I may have to learn mechanical skills at my advanced age to keep this bird going. Perhaps it will prevent "Old Timers Disease" by keeping my brain learning new things. Julie Bonser 1992 WLWB PT 40' On Mar 22, 2006, at 9:30 PM, ronmarabito2002 wrote: > As far as not heating like the system used to: might be due to > many things. Have you noticed how long the boilers operate before > shutting off? Have you turned your control knob CW as far as it will > go on the panel? If you have and you are not getting enough heat, > then the control board could be defective, the Thermister, located in > the galley area could be bad or you could have air trapped in the > system preventing proper flow. > > Let us know more about what you find. (Suggest you move back to > where it is warmer) (BG) |
03-22-2006, 23:13
Follow up on PRIMUS help. Mark Dexter phone number is 574-293-4328.
He is listed as the contact person for PRIMUS in my data with my coach. I did speak with him once and he has a wealth of info regarding the system. When I was at RIV last year at a BB question answer session I asked Mike Burchett with BB about hydronic heat and the difference between aquahot.webasto and primus. He said that if your burners were working that he liked the primus system best. If not it can be modified with a webasto burner. He was pretty up beat on keeping the PRIMUS if it was working. A call to dexter or cape inovations that lists on this website can provide all the information needed to keep your PRIMUS perking along. I expect that cape inovations will be easier to access and achieve a positive end his login is cape0001 johnredden 91 PT40 [Non-text portions of this message have been removed] |
03-23-2006, 02:57
Playing your current role, you will definitely learn much about your
coach. That's not all bad. Hope you get to the bottom of Dick's health problems. Good luck and let us know how we can help. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Julia Bonser > > The rear boiler will operate as long as it is called on. The setting > on the CW is the same setting as in the past which is a comfortable > temperature for us. We suspect it is air trapped in the system as the > reservoirs were quite low when we added antifreeze. > > I wish we could have stayed where it was warmer. Unfortunately due to > having a HMO we had to return to frigid Wisconsin for Dick to get > medical care. He had his blood work today and sees the Dr. on Friday > to figure out what next. > > I may have to learn mechanical skills at my advanced age to keep this > bird going. Perhaps it will prevent "Old Timers Disease" by keeping > my brain learning new things. > > Julie Bonser > 1992 WLWB PT 40' > > > On Mar 22, 2006, at 9:30 PM, ronmarabito2002 wrote: > > > As far as not heating like the system used to: might be due to > > many things. Have you noticed how long the boilers operate before > > shutting off? Have you turned your control knob CW as far as it will > > go on the panel? If you have and you are not getting enough heat, > > then the control board could be defective, the Thermister, located in > > the galley area could be bad or you could have air trapped in the > > system preventing proper flow. > > > > Let us know more about what you find. (Suggest you move back to > > where it is warmer) (BG) > |
03-23-2006, 03:03
By the way: When you said the rear boiler will operate as long as
called on; please explain. Does it ever shut off? While in full operation does it not give even heat along the entire coach driver's side? You can go the full length of the coach and feel the heat along the baseboard. Make sure that it is even all the way. Is your fan working in the galley? By running the fan on higher speeds, you can heat the coach more. Let me know the answers. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Julia Bonser > > The rear boiler will operate as long as it is called on. The setting > on the CW is the same setting as in the past which is a comfortable > temperature for us. We suspect it is air trapped in the system as the > reservoirs were quite low when we added antifreeze. > > I wish we could have stayed where it was warmer. Unfortunately due to > having a HMO we had to return to frigid Wisconsin for Dick to get > medical care. He had his blood work today and sees the Dr. on Friday > to figure out what next. > > I may have to learn mechanical skills at my advanced age to keep this > bird going. Perhaps it will prevent "Old Timers Disease" by keeping > my brain learning new things. > > Julie Bonser > 1992 WLWB PT 40' > > > On Mar 22, 2006, at 9:30 PM, ronmarabito2002 wrote: > > > As far as not heating like the system used to: might be due to > > many things. Have you noticed how long the boilers operate before > > shutting off? Have you turned your control knob CW as far as it will > > go on the panel? If you have and you are not getting enough heat, > > then the control board could be defective, the Thermister, located in > > the galley area could be bad or you could have air trapped in the > > system preventing proper flow. > > > > Let us know more about what you find. (Suggest you move back to > > where it is warmer) (BG) > |
03-23-2006, 05:15
I meant as long as heat is required it operates. It stops when it
gets to about 70 in the front where the sensor is. Heat is going the full length of the coach on the driver's side. The fan in the galley is turned up to full but doesn't operate as often as we would like. The fan under the couch operates frequently. The curb side heat circulates when we are running down the road with the moto raid on so we are pretty sure the pump is working. By the way the temperature in the front this morning was 65 which is 5 degrees warmer than yesterday's 60. I suspect it didn't get quite as cold last night. Steve Birtles said to give him a call that he might be able to help. So I will call him when we go outside to look at the system again. Julie Bonser 1992 WLWB PT 40' On Mar 23, 2006, at 9:03 AM, ronmarabito2002 wrote: > By the way: When you said the rear boiler will operate as long as > called on; please explain. Does it ever shut off? While in full > operation does it not give even heat along the entire coach driver's > side? You can go the full length of the coach and feel the heat along > the baseboard. Make sure that it is even all the way. Is your fan > working in the galley? By running the fan on higher speeds, you can > heat the coach more. Let me know the answers. |
03-23-2006, 11:23
Are you sure the fan under the couch is connected to the Primus.
As far as I knew, there was only one fan per side. Do you happen to have an electric heater under the couch that is on? Since it is shutting down at 70 degrees, either the Thermistor is going bad or you need to turn the knob on the controller, further clockwise to get the heat up more. There is also a rheostat in the galley that controls the fan speed. Is it turned up fully? R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Julia Bonser > > I meant as long as heat is required it operates. It stops when it > gets to about 70 in the front where the sensor is. > Heat is going the full length of the coach on the driver's side. The > fan in the galley is turned up to full but doesn't operate as often > as we would like. The fan under the couch operates frequently. > > The curb side heat circulates when we are running down the road with > the moto raid on so we are pretty sure the pump is working. > > By the way the temperature in the front this morning was 65 which is > 5 degrees warmer than yesterday's 60. I suspect it didn't get quite > as cold last night. > > Steve Birtles said to give him a call that he might be able to help. > So I will call him when we go outside to look at the system again. > > Julie Bonser > 1992 WLWB PT 40' > > > > On Mar 23, 2006, at 9:03 AM, ronmarabito2002 wrote: > > > By the way: When you said the rear boiler will operate as long as > > called on; please explain. Does it ever shut off? While in full > > operation does it not give even heat along the entire coach driver's > > side? You can go the full length of the coach and feel the heat along > > the baseboard. Make sure that it is even all the way. Is your fan > > working in the galley? By running the fan on higher speeds, you can > > heat the coach more. Let me know the answers. > |
03-23-2006, 12:27
Yes I am sure the fan under the couch is connected to the Primus it
comes on when the heat gets high. The electric heater is under the front console. The Primus is shutting down at 70 because that is where we have it set. It cycles on and off according to where the temperature is set. The rheostat for the couch is between the couch and the drivers seat and is turned up to maximum and the rheostat in the galley is turned up all the way. We usually just use the rear controlled Primus because that was plenty to keep us warm. We used it in Dec. and part of January and then decided electricity was cheaper than propane where we were staying. My concern is the heat output doesn't seem as hot as it used to. We found the high temp switches for both burners today. The rear burner/driver's side heat was operating we pushed the button for the curb side heat but when I turned on the heat it tried to ignite but didn't and the red light came on. I think the next thing to try and clear any air out of the lines. It was snowing all day today so we didn't want to take the time to go through the process of getting rid of air in the lines. We are getting by the way we are because we run the generator to recharge the batteries and run the electric heaters a couple of times a day. I don't mind the air being cool in the morning as long as it isn't much below 64. There have been a couple of morning where the temperature in the front is in the 50's. Julie Bonser 1992 WLWB PT 40' On Mar 23, 2006, at 5:23 PM, ronmarabito2002 wrote: > Are you sure the fan under the couch is connected to the Primus. > As far as I knew, there was only one fan per side. Do you happen to > have an electric heater under the couch that is on? Since it is > shutting down at 70 degrees, either the Thermistor is going bad or you > need to turn the knob on the controller, further clockwise to get the > heat up more. > > There is also a rheostat in the galley that controls the fan > speed. Is it turned up fully? > |
