Chassis Heat?
03-23-2006, 05:53
Chassis Heat?
Hi Henry,
Do you have a "Summer/Winter" switch? Do you have an "Aux Pump" switch? If
so, it needs to be switched to "Winter" and the aux pump assists in getting
all that hot coolant (contrary terms) into the coach heater cores. There are
Sporlan Valves in that system, so one might be stuck, too, if the
aforementioned don't work.
Heaters not needed here in SoCal right now.....just got done mowing both
lawns, and I'm tired!!
Kevin McKeown
Yorba Linda, CA
1986 38' PT
03-23-2006, 05:55
Chassis Heat?
Henry,
Forgot to mention...your engine coolant has to be up to operating temp if
you expect any heat from the chassis heaters. But, you probably already know
that...right?
Kevin
YL CA
86 38 PT
03-23-2006, 10:30
Chassis Heat?
My chasis heat thermostat turns on all three blowers so I figure that
it's working. I opened the round valves in the hoses under the engine
to allow hot water to flow to the back of the coach. All I get is cold
air from the registers. What should I check next?
Henry@... In Austin, Tx., 1979 FC 35.
03-23-2006, 11:53
Chassis Heat?
You need to verify the circulation pump is on, my rear bath FC likes the pump
even running down the road. There is a lot of coolant to move and the engine
water pump can't do it all. That is the reason the accessory pump was added.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Thursday, March 23, 2006 4:55 PM
Subject: Re: [WanderlodgeForum] Chassis Heat?
Henry,
that...right?
Kevin
YL CA
86 38 PT
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive
radiators
YAHOO! GROUPS LINKS
03-23-2006, 12:28
Chassis Heat?
Near the floor in the rear are two push-pull cables. For rear heat, one
out one in, for no rear heat and domestic-water heat only (motoraid),
the other cable out/other cable in. The valves can be seen at the other
end of the cables by lifting the mattress and plywood under the bed,
next to the water heater.
- Jeff Miller
in Holland, MI
engine
cold
03-23-2006, 20:21
Chassis Heat?
Kevin. I have both switches but only turned on the "Summer/Winter" switch
because I didn't know what the "Aux Pump" switch was for. I'll try turning both
switches on, next time, and see what happens. Thanks. Henry@...
in Austin, Tx. 1979 FC 35.
Message: 22
Date: Thu, 23 Mar 2006 17:53:52 EST
Subject: Re: Chassis Heat?
Hi Henry,
Kevin McKeown
Yorba Linda, CA
1986 38' PT
