Vlv last adjustment
03-26-2006, 08:08
Vlv last adjustment
Well today I finally got under the old bird and looked around to see
that timing mark that's on the crank shaft and yes it there and I can see the pointer also but it might just take an inspection mirror to see that its in the proper position for vlv timing. Now has anyone ever here taken oft there vlv covers with the front end still on? It looks to like it can be done this was from the top but it will require a little bit of bending and knuckle busting. This afternoon I'm going to look under the dog house to see just how much room there is in there to do this operation. Again has anyone ever done this procedure before without taking out the radiator? Thanks Jon Rebel Bird Bremerton Washington |
03-26-2006, 09:16
Vlv last adjustment
I don't see how taking off the radiator will give any more access to
the valve covers. Removing the bottom part of the doghouse should give better access to the lower valve cover bolts, although they may be more accessible from below. You could do the job without looking at the timing mark if you look closely at the valves themselves and adjust the ones with no pressure on them. I think the only reason to use the timing mark is to follow the sequence specified by CAT as to which valves are not under pressure at specific points in the cycle. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Well today I finally got under the old bird and looked around to see > that timing mark that's on the crank shaft and yes it there and I can > see the pointer also but it might just take an inspection mirror to see > that its in the proper position for vlv timing. Now has anyone ever > here taken oft there vlv covers with the front end still on? It looks > to like it can be done this was from the top but it will require a > little bit of bending and knuckle busting. This afternoon I'm going to > look under the dog house to see just how much room there is in there to > do this operation. Again has anyone ever done this procedure before > without taking out the radiator? Thanks > > Jon > Rebel Bird > Bremerton Washington > |
03-26-2006, 09:47
Vlv last adjustment
> > I don't see how taking off the radiator will give any more access to > the valve covers. Removing the bottom part of the doghouse should > give better access to the lower valve cover bolts, although they may > be more accessible from below. You could do the job without looking > at the timing mark if you look closely at the valves themselves and > adjust the ones with no pressure on them. I think the only reason to > use the timing mark is to follow the sequence specified by CAT as to > which valves are not under pressure at specific points in the cycle. > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > Well today I finally got under the old bird and looked around to see > > that timing mark that's on the crank shaft and yes it there and I can > > see the pointer also but it might just take an inspection mirror to see > > that its in the proper position for vlv timing. Now has anyone ever > > here taken oft there vlv covers with the front end still on? It looks > > to like it can be done this was from the top but it will require a > > little bit of bending and knuckle busting. This afternoon I'm going to > > look under the dog house to see just how much room there is in there to > > do this operation. Again has anyone ever done this procedure before > > without taking out the radiator? Thanks > > > > Jon > > Rebel Bird > > Bremerton Washington First of all Kerry your right about those covers. Just went out and took a look at how they fit down there in the obelisk. Now I wonder how do you take the dog house oft from the body of the coach. Looks like that bottom part of dog house is bolted or screwed on someway. But I have a rug in the way and really don't know what to expect underneath that material. > > > |
03-26-2006, 10:09
Vlv last adjustment
You unbolt the hinges from the top cover, and unbolt the brace and the
top cover comes off. There are bolts going down into the floor around the lower section (there may also be some going forward into the 'firewall' then you lift up the lower section and remove it. The carpet should move enough to access the bolts. It's shown in the owner's manual. Kerry 82 FC35 Denver -- > First of all Kerry your right about those covers. Just went out and > took a look at how they fit down there in the obelisk. Now I wonder > how do you take the dog house oft from the body of the coach. Looks > like that bottom part of dog house is bolted or screwed on someway. > But I have a rug in the way and really don't know what to expect > underneath that material. > > > > > > |
03-26-2006, 13:36
Vlv last adjustment
> > You unbolt the hinges from the top cover, and unbolt the brace and the > top cover comes off. There are bolts going down into the floor around > the lower section (there may also be some going forward into the > 'firewall' then you lift up the lower section and remove it. The > carpet should move enough to access the bolts. It's shown in the > owner's manual. > > Kerry > 82 FC35 > Denver -- > > > First of all Kerry your right about those covers. Just went out and > > took a look at how they fit down there in the obelisk. Now I wonder > > how do you take the dog house oft from the body of the coach. Looks > > like that bottom part of dog house is bolted or screwed on someway. > > But I have a rug in the way and really don't know what to expect > > underneath that material. > > > > > > > > > > Thanks Kerry!!!! And now to go out to the bird and get that repair book. Jon 1978 Wanderlodge Brmerton Washington |
03-26-2006, 14:21
Vlv last adjustment
> > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > You unbolt the hinges from the top cover, and unbolt the brace and > the > > top cover comes off. There are bolts going down into the floor > around > > the lower section (there may also be some going forward into the > > 'firewall' then you lift up the lower section and remove it. The > > carpet should move enough to access the bolts. It's shown in the > > owner's manual. > > > > Kerry > > 82 FC35 > > Denver -- > > > > > First of all Kerry your right about those covers. Just went out > and > > > took a look at how they fit down there in the obelisk. Now I > wonder > > > how do you take the dog house oft from the body of the coach. > Looks > > > like that bottom part of dog house is bolted or screwed on > someway. > > > But I have a rug in the way and really don't know what to expect > > > underneath that material. > > > > > > > > > > > > > > > Thanks Kerry!!!! And now to go out to the bird and get that repair > book. > > Jon > 1978 Wanderlodge > Brmerton Washington > Oops no picture of dog house in my repair book, could someone E-mail me a photo copy of this area. I know I can go at it blindly but it sure would be nice to have a sketch or something to check out that bolt pattern that hold the bottom of the dog house down. Jon Lecich Bremerton Washington Rebel Bird |
03-26-2006, 15:08
Vlv last adjustment
Detailed instructions on doghouse removal under 'files' at the Yahoo
FC_Wanderlodge site. Kerry |
03-26-2006, 17:46
Vlv last adjustment
> > Detailed instructions on doghouse removal under 'files' at the Yahoo > FC_Wanderlodge site. > > Kerry Thanks Kerry I will check out my rig with the instruction and let this site know how it come along. I might just take oft the dog house and the transition piece and have my friend do the vlv adjustment. By meaning friend that is the shop and personnel who work on the Rebel Bird in the past. I think the big part of this job is just getting that dog house oft and the vlv covers ready to remove for inspection. The inspection shouldn't take more than one hour and say an hour to remove and install the vlv cover. The reason I'm thinking about letting Don my mechanic do it as he has a big shop and is familiar with 3208's. Oh just a plug for his shop as he has done great work for me in the past And is very safety conscious and back up his work with a full six month guarantee or six thousand miles which ever come first. The name of his business is Nor-Star Inc. and is based in Bremerton Washington and charges $75 and hour for RV repair. Jon Jipjob@... Bremerton Washington > |
