Microphor toilet
03-16-2006, 11:56
Microphor toilet
Folks,
There's an air valve under the sink in my
bathroom that seems to be leaking. The
valve is part of the control for the microphor
toilet. The valve has an input and an output
a pinhole and an adjustment thumb wheel.
Air seems to constantly leak from the pinhole.
When I ,the air leak for the pinhole
stops, after flushing is complete leaking
resumes. The valve seems to be some
sort of pressure regulator/bleed off valve.
Any idea what it does, how it should work,
and where I might find a replacement (if
indeed a steady bleeding of air is abnormal)?
TIA,
David Brady
'02 LXi, Smokey,
Va
03-16-2006, 12:50
Microphor toilet
Thanks George, I'll give Lee at Microphor a call
in the morning.
David Brady
'02 LXi, Smokey,
Va
George Lowry wrote:
> David,
> Contact Microphor at <http://www.microphor.com> IIRC the guy you want to
> talk to is Lee. They give excellent support. Good excuse for a trip
> to the west coast to visit the factory. You should have a manual
> which describes all the parts, etc. If not, you can get it from
> Microphor.
> George Lowry
> '06 Alpine Apex - Formerly '95 WBDA 4203
> Spearfish, SD - now at TTN Las Vegas
> David Brady wrote:
>> Folks,
>> TIA,
>> David Brady
>> '02 LXi, Smokey,
>> Va
>> Yahoo! Groups Links
> Yahoo! Groups Links
03-26-2006, 14:33
Microphor toilet
David,
Microphor.
George Lowry
David Brady wrote:
> Folks,
> TIA,
> David Brady
> '02 LXi, Smokey,
> Va
> Yahoo! Groups Links
03-26-2006, 15:41
Microphor toilet
BTW, David,
Both of your posts came thru with an old date on them. Recommend that
you check the date on your computer.
George Lowry
> in the morning.
> David Brady
> '02 LXi, Smokey,
> Va
> George Lowry wrote:
>>David,
>>Microphor.
>>George Lowry
>>David Brady wrote:
>>>Folks,
>>>TIA,
>>>David Brady
>>>'02 LXi, Smokey,
>>>Va
>>>Yahoo! Groups Links
>>Yahoo! Groups Links
> Yahoo! Groups Links
03-30-2006, 06:44
Microphor toilet
There is an air regulator that fits between the 12v toilet
air compressor and the toilet flush handle. The part is made
by Clippard and is blue-bird part number: 3824745.
This part was leaking causing my air compressor to be
on approx. 15% of the time. I installed a new regulator
and all is well again.
David Brady,
'02 LXi, Smokey,
Va
David Brady wrote:
> Folks,
> TIA,
> David Brady
> '02 LXi, Smokey,
> Va
> Yahoo! Groups Links
