B lack Water Tank Valve
03-27-2006, 13:30
Folks,
I have a leaky black water tank Dupree valve. After a day of traveling about a cup of fluid seeps past the seals - not a total failure. Is there any maintenance I can do to try to get a better seal. Is there a rebuild kit available, or do I replace the entire valve. Thanks, David Brady '02 LXi, Smokey, Va |
03-27-2006, 13:40
Call Jeff at Dupree products there is a kit available
616 355 9811 email jamiller@... Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > I have a leaky black water tank Dupree valve. After a day of > traveling about a cup of fluid seeps past the seals - not > a total failure. Is there any maintenance I can do to > try to get a better seal. Is there a rebuild kit available, > or do I replace the entire valve. > > Thanks, > David Brady > '02 LXi, Smokey, > Va > |
03-27-2006, 13:55
David:
As Stephen said, Jeff Miller has the repair parts you need. If you belong to the WOO site, there is are step by step pictures detailing the procedure for the maintenance. It is very easy to do. You need to check the paddle surfaces for rubber distortion. Jeff has all the parts you need. William Jensen 1993 PT40 WBWL Deerfield Beach, FL |
03-27-2006, 14:02
Hey there David, We missed you in MB for the rally. Hope all is well
with you and Suzie! The tank valves sometimes leak because of pressure built up between the cap and valve. Sometimes simply loosening the cap (the small one for the garden hose) will help. BUT the rebuild kits are available and VERY EASY to replace...Jeff has them and will chime in here I am sure.. Take care, hope to see you both sooner rather than later... ScottB 86FC35 Sc --- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > I have a leaky black water tank Dupree valve. After a day of > traveling about a cup of fluid seeps past the seals - not > a total failure. Is there any maintenance I can do to > try to get a better seal. Is there a rebuild kit available, > or do I replace the entire valve. > > Thanks, > David Brady > '02 LXi, Smokey, > Va > |
03-27-2006, 14:36
Hi Scott,
Thanks for the reply and good to hear from you. Suzy and I are 3500 miles into a 3 month trip thru the south and the west. We're currently in Tucson Az - Saguaro National Park is unbelievable. The Saquaro, Occotillo, and Cholla cacti form a landscape that seems otherworldly. The bus is performing beautifully and is a real pleasure to drive and live in. I'm even getting used to the attention that she attracts... Sorry we missed MB, we passed thru Hilton head just 2 weeks prior, sounds like an incredible event and a great tradition. Say hi to Judy. David and Suzana '02 LXi, Smokey, Va Scott wrote: > Hey there David, We missed you in MB for the rally. Hope all is well > with you and Suzie! > The tank valves sometimes leak because of pressure built up between the > cap and valve. Sometimes simply loosening the cap (the small one for > the garden hose) will help. BUT the rebuild kits are available and VERY > EASY to replace...Jeff has them and will chime in here I am sure.. > Take care, hope to see you both sooner rather than later... > > ScottB > 86FC35 > Sc > > --- In WanderlodgeForum@yahoogroups.com, David Brady > >> Folks, >> >> I have a leaky black water tank Dupree valve. After a day of >> traveling about a cup of fluid seeps past the seals - not >> a total failure. Is there any maintenance I can do to >> try to get a better seal. Is there a rebuild kit available, >> or do I replace the entire valve. >> >> Thanks, >> David Brady >> '02 LXi, Smokey, >> Va >> >> > > > > > > > > Yahoo! Groups Links > > > > > > > > > |
03-28-2006, 13:30
Remove the two screws (with an empty and rinsed tank), pull the valve
cartrige out of the housing. If the seal looks damaged/worn, we have plenty of replacement paddles. If not, check the housing where the seal slides in, could be something lodged in there. Should take around 5-10 minutes to check. The word "inlet" should face the tank. Waterproof grease will help it to work easier and longer. Lube the O- ring to make re-installation easier. - Jeff Miller Dupree Products Inc. American Made, in Holland, MI --- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > I have a leaky black water tank Dupree valve. After a day of > traveling about a cup of fluid seeps past the seals - not > a total failure. Is there any maintenance I can do to > try to get a better seal. Is there a rebuild kit available, > or do I replace the entire valve. > > Thanks, > David Brady > '02 LXi, Smokey, > Va > |
03-28-2006, 23:21
Hope business is brisk! How did your battery issue
turn out? John --- Jeff Miller > Remove the two screws (with an empty and rinsed > tank), pull the valve > cartrige out of the housing. If the seal looks > damaged/worn, we have > plenty of replacement paddles. If not, check the > housing where the seal > slides in, could be something lodged in there. > Should take around 5-10 > minutes to check. The word "inlet" should face the > tank. > > Waterproof grease will help it to work easier and > longer. Lube the O- > ring to make re-installation easier. > > - Jeff Miller > Dupree Products Inc. > American Made, > in Holland, MI __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
