Heater replacement suggestions needed
03-28-2006, 16:21
I need to replace 2 of the LP heaters in my coach. I am considering
installing a hydronic diesel fired heater and junking the LP units. Anyone made this change? Any experience with the Proheat model, this looks like the simplest option. Troy Waconia, MN Newell 40FT Widebody |
03-28-2006, 16:33
--- In WanderlodgeForum@yahoogroups.com, "ttikalsky"
wrote: > > I need to replace 2 of the LP heaters in my coach. I am considering > installing a hydronic diesel fired heater and junking the LP units. > Anyone made this change? Any experience with the Proheat model, this > looks like the simplest option. > > Troy > Waconia, MN > Newell 40FT Widebody > Sorry, forgot to mention that last week we traded our Bird for a Newell. Found a coach that had 90% of the features we wanted so we made the deal. Since the knowledge on this forum is the best I've found anywhere I hope you don't mind me asking for additional help. Troy |
03-28-2006, 18:27
Troy- no problem with asking questions whatever coach you have. Ernie-83pt40
in Texas That ideea sounds like a good project. If you have the space to add that system, that would be the only limitation I can think about. [Non-text portions of this message have been removed] |
03-28-2006, 23:17
I installed Proheats in my toter and FC. Cost about the same for the boiler as
two LP heaters. You can make your own convectors with automotive heater cores and computer cooling fans to save money. I use the convectors provided by Red Dot, they have extensive HVAC options, you might want to check their offerings. The Red Dot convectors start at 125 bucks and go up 500 for a 50k btu. Fuel Systems in Brookfield WI is a good supplier for both product lines 262 781 4353. Dan or Shawn are knowledgeable fellows. As a side light, got the truck out of the barn yesterday, sitting there since October 05, Trace inverter plugged in. Started the proheat in the morning, fired it up after lunch, heat gage on 150 degrees, ran like I used it day before. I hate starting a cold engine, and boilers do a better job than electric pre heaters as they heat the whole system. MH ----- Original Message ----- From: ttikalsky To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 28, 2006 11:33 PM Subject: [WanderlodgeForum] Re: Heater replacement suggestions needed --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > > I need to replace 2 of the LP heaters in my coach. I am considering > installing a hydronic diesel fired heater and junking the LP units. > Anyone made this change? Any experience with the Proheat model, this > looks like the simplest option. > > Troy > Waconia, MN > Newell 40FT Widebody > Sorry, forgot to mention that last week we traded our Bird for a Newell. Found a coach that had 90% of the features we wanted so we made the deal. Since the knowledge on this forum is the best I've found anywhere I hope you don't mind me asking for additional help. Troy SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
03-30-2006, 02:57
Did you install the Proheat into the existing motoraid heaters or
build a complete new loop? If installed in the existing loop does anything special need to be done when the big motor is running and heating the coolant? The computer cooling fans is a geat idea, they can be very quite and move a decent amount of air. Troy Newell --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > I installed Proheats in my toter and FC. Cost about the same for the boiler as two LP heaters. You can make your own convectors with automotive heater cores and computer cooling fans to save money. I use the convectors provided by Red Dot, they have extensive HVAC options, you might want to check their offerings. The Red Dot convectors start at 125 bucks and go up 500 for a 50k btu. Fuel Systems in Brookfield WI is a good supplier for both product lines 262 781 4353. Dan or Shawn are knowledgeable fellows. > As a side light, got the truck out of the barn yesterday, sitting there since October 05, Trace inverter plugged in. Started the proheat in the morning, fired it up after lunch, heat gage on 150 degrees, ran like I used it day before. I hate starting a cold engine, and boilers do a better job than electric pre heaters as they heat the whole system. > MH > ----- Original Message ----- > From: ttikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, March 28, 2006 11:33 PM > Subject: [WanderlodgeForum] Re: Heater replacement suggestions needed > > > --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" > wrote: > > > > I need to replace 2 of the LP heaters in my coach. I am considering > > installing a hydronic diesel fired heater and junking the LP units. > > Anyone made this change? Any experience with the Proheat model, this > > looks like the simplest option. > > > > Troy > > Waconia, MN > > Newell 40FT Widebody > > > > > Sorry, forgot to mention that last week we traded our Bird for a > Newell. Found a coach that had 90% of the features we wanted so we > made the deal. Since the knowledge on this forum is the best I've > found anywhere I hope you don't mind me asking for additional help. > > Troy > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > |
03-30-2006, 06:04
Added it to the engine supply/return loop. Placed the boiler in the RF
compartment, right under the front dash heater core. Parallel with the electric engine heater, or it could replace the plug in heater. Learn where your engine supply and return coolant points are, that's critical. I have had good luck with my boilers, just don't make the fuel supply line too long. I feed mine off the gen set with check valves for the gen set and the boiler. When I run the gen set the boiler sucks air and shuts off. I think I need to increase the diameter of the supply pipe to the boiler, only running 1/4", I'll try going up to half or 5/8 to see if that helps. If you have the option keep the boiler as close as possible to the fuel tank and have a dedicated fuel supply line. Using the booster pump it easily keeps the stock heater loop up to temp. The Proheat has a circulation pump and with the coach unit it provides plenty of coolant flow. MH ----- Original Message ----- From: ttikalsky To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 30, 2006 9:57 AM Subject: [WanderlodgeForum] Re: Heater replacement suggestions needed Did you install the Proheat into the existing motoraid heaters or build a complete new loop? If installed in the existing loop does anything special need to be done when the big motor is running and heating the coolant? The computer cooling fans is a geat idea, they can be very quite and move a decent amount of air. Troy Newell --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > I installed Proheats in my toter and FC. Cost about the same for the boiler as two LP heaters. You can make your own convectors with automotive heater cores and computer cooling fans to save money. I use the convectors provided by Red Dot, they have extensive HVAC options, you might want to check their offerings. The Red Dot convectors start at 125 bucks and go up 500 for a 50k btu. Fuel Systems in Brookfield WI is a good supplier for both product lines 262 781 4353. Dan or Shawn are knowledgeable fellows. > As a side light, got the truck out of the barn yesterday, sitting there since October 05, Trace inverter plugged in. Started the proheat in the morning, fired it up after lunch, heat gage on 150 degrees, ran like I used it day before. I hate starting a cold engine, and boilers do a better job than electric pre heaters as they heat the whole system. > MH > ----- Original Message ----- > From: ttikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, March 28, 2006 11:33 PM > Subject: [WanderlodgeForum] Re: Heater replacement suggestions needed > > > --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" > wrote: > > > > I need to replace 2 of the LP heaters in my coach. I am considering > > installing a hydronic diesel fired heater and junking the LP units. > > Anyone made this change? Any experience with the Proheat model, this > > looks like the simplest option. > > > > Troy > > Waconia, MN > > Newell 40FT Widebody > > > > > Sorry, forgot to mention that last week we traded our Bird for a > Newell. Found a coach that had 90% of the features we wanted so we > made the deal. Since the knowledge on this forum is the best I've > found anywhere I hope you don't mind me asking for additional help. > > Troy > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
