cruise control
12-11-2006, 13:47
Post: #21
cruise control
Anyone have any idea when a 1983 fc-35 should bump into the next gear on level
ground. Since it appears my transmission conrtol was diconnected I will try to
figure out when to make it shift from 1 to 2, 2 to3 and 3 to 4
Thanks for all the information. I wish mine had Air cruise and throttle,but I
have to work with what I have
re brae 1983 FC _35 SB
> From: Doug Engel
> Date: 2006/12/11 Mon AM 10:15:55 EST
> Subject: Re: [WanderlodgeForum] Re: CRUISE CONTROL
> Doesn't seem like it should, but it did on Pokey. When it was too long, it
virtually skipped straight into 3&4 lockup, really lugged him down. Doug n'
Pokey
> Jeff Miller wrote: Although the downsift Bowden
cable will affect the shift points, I
> don't believe it will change the torque-converter lockup point.
> - Jeff Miller
> in Holland, MI
> --- In WanderlodgeForum@yahoogroups.com, Doug Engel
> > In theroy, if we are talking about the same thing, the longer it
> is, the faster the torque converter will go into lockup and the
> later you will get a downshift. The shorter you make it, the reverse
> should be true. I have mine shortened up somewhat to hold gears a
> little longer due to our mountianous terrain (read: lots of big
> hills that makes Pokey go real slow). Let me know how it works out.
> Doug n' Pokey
> > putneyflash@... wrote: I think you are right, I haveit
> all attached now and I can see if theres any change in the shift.
> > re brake 1983 fc-35 sb
> > > From: Doug Engel
> > > Date: 2006/12/09 Sat PM 04:54:32 EST
> > > Subject: RE: [WanderlodgeForum] Re: CRUISE CONTROL
> > > On our '81 FC, the ball chain is attatched to throttle linkage
> right above the throttle cable. If we are talking about the same
> part, the slide arm is part of the transmission kick down/shift
> point system. If it has never been attatched, I can't see how your
> tranny could have been shifting correctly, so maye this is something
> else.
> > > Dan Darst wrote: Hmmm BIG chassis dyno?
> > > dandarst86fc35rbhuntleyil.
> > > >From: "davidkerryedwards"
> > > >Reply-To: WanderlodgeForum@yahoogroups.com
> > > >Subject: [WanderlodgeForum] Re: CRUISE CONTROL
> > > >Date: Sat, 09 Dec 2006 20:14:41 -0000
> > > >No way to test it without driving it to my knowledge. I know
> the slide arm
> > > >of which you
> > > >speak but I don't know what it is attached to. My coach is in
> storage.
> > > >Which vacuum control
> > > >did you replace?
> > > >Kerry
> > > >82 Fc 35
> > > >Denver
> > > >--- In WanderlodgeForum@yahoogroups.com, "putneyflash"
> > > > >wrote:
> > > > > I am working on the cruise control, i have installed a new
> vacuum
> > > > > control. When looking at the cruise control i have a round
> disc
> > > > > attached to a chain which is connected to the cruise control
> which i
> > > > > believe attaches to the throttle lever..their is also a
> metal slide
> > > > > which is connected to a rod which also connects to the
> throttle lever.
> > > > > Does anyone know what it does? it has been disconnected. Is
> their any
> > > > > way to test the cruise control setting still?
> > > > > re brake 1983 FC-35 SB "sagecoach"
> > > __________________________________________________________
> > > Talk now to your Hotmail contacts with Windows Live Messenger.
> > > http://clk.atdmt.com/MSN/go/msnnkwme0020...irect/01/?
> href=http://get.live.com/messenger/overview
> > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey"
> > > Have a burning question? Go to Yahoo! Answers and get answers
> from real people who know.
> > > [Non-text portions of this message have been removed]
> > Check out the all-new Yahoo! Mail beta - Fire up a more powerful
> email and get things done faster.
> Want to start your own business? Learn how on Yahoo! Small Business.
12-11-2006, 14:11
Post: #22
cruise control
My 78FC33 upshifts around 22-2300 with the pedal to the metal. It
downshifts around 17-1800 while climbing under full throttle except
for 4th to 3rd, which happens around 12 to 1300. I always manually
downshift from 4th to 3rd during a climb because I think it is
better to keep the rpm's near 2000 and I don't want to lug the
engine. My FC had the gears changed from 5:something to 4:88 so my
shift points may not be standard.
Gardner
78FC33
gear on level ground. Since it appears my transmission conrtol was
diconnected I will try to figure out when to make it shift from 1 to
2, 2 to3 and 3 to 4
throttle,but I have to work with what I have
> > From: Doug Engel
too long, it virtually skipped straight into 3&4 lockup, really
lugged him down. Doug n' Pokey
Bowden cable will affect the shift points, I
> > - Jeff Miller
> > in Holland, MI
it
reverse
a
out.
> > Doug n' Pokey
> > > putneyflash@ wrote: I think you are right, I haveit
> > > > From: Doug Engel
linkage
your
something
> > else.
know
> > the slide arm
> > > > >of which you
in
> > storage.
> > > > >did you replace?
> > > > >Kerry
> > > > >82 Fc 35
> > > > >Denver
new
> > vacuum
round
> > disc
control
> > which i
> > metal slide
> > throttle lever.
Is
> > their any
Messenger.
answers
powerful
Business.
12-11-2006, 14:18
Post: #23
cruise control
While playing with the cable on our FC I discovered that it affected all
except the 1-2 shift which is always at 2650rpm. I ended up setting it up
like we used to set up the automobile transmissions before the computer
days, about 1/8" slack at full throttle. With that setting it will up shift
or lockup at 2650rpm and down shift at 2000. Under real light throttle,
other than 1-2, it will up shift about 2200rpm and downshift about 1700rpm.
If it is below 2000rpm and you apply more throttle it downshifts
immediately. Working fresh transmission into the transmission really seemed
to help performance also.
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Doug Engel
Sent: Monday, December 11, 2006 9:16 AM
Pokey
Jeff Miller net> wrote:
Although the downsift Bowden cable will affect the shift points, I
- Jeff Miller
in Holland, MI
Doug n' Pokey
> > From: Doug Engel
yahoogroups.com
else.
yahoogroups.com
yahoogroups.com
the slide arm
> > >of which you
storage.
> > >did you replace?
> > >Kerry
> > >82 Fc 35
> > >Denver
vacuum
disc
which i
metal slide
throttle lever.
their any
> > http://clk.atdmt.
<http://clk.atdmt.com/MSN/go/msnnkwme0020...irect/01/?>
com/MSN/go/msnnkwme0020000001msn/direct/01/?
href=http://get.live. <http://get.live.com/messenger/overview>
12-11-2006, 15:00
Post: #24
cruise control
locks in 3rd and stays on for the 3/4 shift. Engine and trans need the cable
travel fully extended or compressed at WOT.
MH
Sent: Monday, December 11, 2006 7:35 PM
Subject: Re: Re: [WanderlodgeForum] Re: CRUISE CONTROL
Does the transmission go intoTt/C lock up in each gear?
re brake 1983 FC_35 sb
> From: Doug Engel
Pokey
> Jeff Miller wrote: Although the downsift Bowden cable
> - Jeff Miller
> in Holland, MI
> Doug n' Pokey
> > > From: Doug Engel
> else.
> the slide arm
> > > >of which you
> storage.
> > > >did you replace?
> > > >Kerry
> > > >82 Fc 35
> > > >Denver
> vacuum
> disc
> which i
> metal slide
> throttle lever.
> their any
12-11-2006, 15:04
Post: #25
cruise control
The trans cable travel should be fully compressed at WOT.
MH
Sent: Monday, December 11, 2006 7:47 PM
> From: Doug Engel
Pokey
> - Jeff Miller
> in Holland, MI
> Doug n' Pokey
> > > From: Doug Engel
> else.
> the slide arm
> > > >of which you
> storage.
> > > >did you replace?
> > > >Kerry
> > > >82 Fc 35
> > > >Denver
> vacuum
> disc
> which i
> metal slide
> throttle lever.
> their any
12-11-2006, 15:07
Post: #26
cruise control
Yer doin' well.
MH
Sent: Monday, December 11, 2006 8:11 PM
Gardner
78FC33
2, 2 to3 and 3 to 4
> > From: Doug Engel
> > - Jeff Miller
> > in Holland, MI
it
reverse
a
out.
> > Doug n' Pokey
> > > > From: Doug Engel
linkage
your
something
> > else.
know
> > the slide arm
> > > > >of which you
in
> > storage.
> > > > >did you replace?
> > > > >Kerry
> > > > >82 Fc 35
> > > > >Denver
new
> > vacuum
round
> > disc
control
> > which i
> > metal slide
> > throttle lever.
Is
> > their any
Messenger.
answers
powerful
Business.
12-11-2006, 15:10
Post: #27
cruise control
your numbers are appropriate for a NA, turbos operate at less RPM.
MH
Sent: Monday, December 11, 2006 8:18 PM
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
Pokey
- Jeff Miller
in Holland, MI
Doug n' Pokey
> > From: Doug Engel
yahoogroups.com
else.
yahoogroups.com
yahoogroups.com
the slide arm
> > >of which you
storage.
> > >did you replace?
> > >Kerry
> > >82 Fc 35
> > >Denver
vacuum
disc
which i
metal slide
throttle lever.
their any
> > http://clk.atdmt.
12-11-2006, 15:14
Post: #28
cruise control
I believe the sequence is 1, 2, lockup, 3 and 4.
Kerry
82 FC 35
Denver
12-11-2006, 15:17
Post: #29
cruise control
The 3208 manual says the engine starts lugging at 1900rpms and not to run it in
this
condition for more than a short period of time. I can't recall the upshift
points on mine
but I think it is around 2400-2500.
Kerry
82 Fc 35
Denver-
> Gardner
> 78FC33
> 2, 2 to3 and 3 to 4
> > > From: Doug Engel
> > > - Jeff Miller
> > > in Holland, MI
> it
> reverse
> a
> out.
> > > Doug n' Pokey
> > > > > From: Doug Engel
> linkage
> your
> something
> > > else.
> know
> > > the slide arm
> > > > > >of which you
> in
> > > storage.
> > > > > >did you replace?
> > > > > >Kerry
> > > > > >82 Fc 35
> > > > > >Denver
> new
> > > vacuum
> round
> > > disc
> control
> > > which i
> > > metal slide
> > > throttle lever.
> Is
> > > their any
> Messenger.
> answers
> powerful
> Business.
12-11-2006, 15:37
Post: #30
cruise control
Mie does, almost feels like an 8 speed. Doug n' Pokey
putneyflash@... wrote: Does the transmission go intoTt/C lock
up in each gear?
> From: Doug Engel
Pokey
> - Jeff Miller
> in Holland, MI
> Doug n' Pokey
> > > From: Doug Engel
> else.
> the slide arm
> > > >of which you
> storage.
> > > >did you replace?
> > > >Kerry
> > > >82 Fc 35
> > > >Denver
> vacuum
> disc
> which i
> metal slide
> throttle lever.
> their any
Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get
things done faster.
