a few quick BB questions
04-02-2006, 06:02
Why do the older FC's have a 12.5 KW generator? Our Bounder DP has a
7.5 and it sure seems adequate. Why do they use the powerline gen. as well? Did all the FC's use the motor driven gen. or was it an option? Why do many BB's have 3 A/C's? Most coaches use 2 and I have never needed more. I just know that BB had a good reason for more. Thanks: Bruce |
04-02-2006, 06:28
Can't really respond to the FC questions, but on the: Why do many BB's
have 3 A/C's? Some reasons include that the 80 models were set up as separate zones for heating and cooling so you could have different settings in the bedroom, galley and front of the coach, especially if the bedroom was closed off while someone was napping. Also, these are steel bodied coaches - in 100+ degree temps in south Texas in the summer, 3 ACs cool the entire coach a whole lot better than 2. The 12.5kw genset makes it easy to run all 3 Acs, plus ice maker, refrig/freezer, microwave, blender, TV, battery chargers when dry camping in aforementioned heat. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Why do the older FC's have a 12.5 KW generator? Our Bounder DP has a > 7.5 and it sure seems adequate. Why do they use the powerline gen. as > well? Did all the FC's use the motor driven gen. or was it an option? > Why do many BB's have 3 A/C's? Most coaches use 2 and I have never > needed more. I just know that BB had a good reason for more. > > Thanks: Bruce > |
04-02-2006, 10:49
My FC-35 1983 does not have a motor driven generator. the sale booklet says 33
foot and under has 2 AC's and anything over 35 has three AC's. Most Rv's have hot water heater that is propane fired ours are electric.We need the 12.5 to run three AC's, water heater, electric heaters,and charge our batteries back in quick time. RE BRAKE 1983 FC-35 SB "SAGECOACH" ALBANY,GA. -------------- Original message from "birdshill123" -------------- Why do the older FC's have a 12.5 KW generator? Our Bounder DP has a 7.5 and it sure seems adequate. Why do they use the powerline gen. as well? Did all the FC's use the motor driven gen. or was it an option? Why do many BB's have 3 A/C's? Most coaches use 2 and I have never needed more. I just know that BB had a good reason for more. Thanks: Bruce SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
04-02-2006, 12:41
> Bruce, You just really don't understand overkill, do you? :o) I swear, some of the Blue Bird Engineers must have worked on the space shuttle, they have so many backup systems. If you have 3 and lose one, it's not a trip-interrupting event. You also get to have separate temperature controls for different areas. Mine has the motor driven generator, I took it out and put in a Xantex invertor/charger. The motor driven unit was the best technology available at the time. Many owners update things with that in mind on the updates, going to the best available when the update is done. Blue Bird's engineering motto was: If some is good, more is better. ;o) My '81 is still an engineering marvel 25 years later and has many features even new "other brands" don't have. We had a little get-together here and had 5 Birds show up. We all gave tours of our coaches and wowed the group with the cool features each one had. It's just amazing to see what they put in these things. The one thing that stands out to me from a design standpoint is that it all makes sense and whoever designed these things must have used them a lot to come up with the neat ideas they had. One of my favorites is the ladder to the roof. The top bars go over 5 feet onto the roof. This lets you get horizontal safely before you hang one leg down searching for that first step on the ladder. Every other ladder I've seen makes you try to find that step while precariously perched almost upright with little to hang onto. The more Birds you look at, the more awed you'll be by the design. George Witt 81 FC 35 Lincoln, Nebraska > Why do the older FC's have a 12.5 KW generator? Our Bounder DP has a > 7.5 and it sure seems adequate. Why do they use the powerline gen. as > well? Did all the FC's use the motor driven gen. or was it an option? > Why do many BB's have 3 A/C's? Most coaches use 2 and I have never > needed more. I just know that BB had a good reason for more. > > Thanks: Bruce > |
04-02-2006, 12:49
--- In WanderlodgeForum@yahoogroups.com, "George Witt"
<mrdonut12@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > > > > Bruce, > You just really don't understand overkill, do you? :o) > I swear, some of the Blue Bird Engineers must have worked on the > space shuttle, they have so many backup systems. > If you have 3 and lose one, it's not a trip-interrupting event. > You also get to have separate temperature controls for different > areas. > Mine has the motor driven generator, I took it out and put in a > Xantex invertor/charger. The motor driven unit was the best > technology available at the time. Many owners update things with that > in mind on the updates, going to the best available when the update is > done. > Blue Bird's engineering motto was: If some is good, more is > better. ;o) > My '81 is still an engineering marvel 25 years later and has many > features even new "other brands" don't have. > We had a little get-together here and had 5 Birds show up. We > all gave tours of our coaches and wowed the group with the cool > features each one had. It's just amazing to see what they put in > these things. > The one thing that stands out to me from a design standpoint is > that it all makes sense and whoever designed these things must have > used them a lot to come up with the neat ideas they had. > One of my favorites is the ladder to the roof. The top bars go > over 5 feet onto the roof. This lets you get horizontal safely before > you hang one leg down searching for that first step on the ladder. > Every other ladder I've seen makes you try to find that step > while precariously perched almost upright with little to hang onto. > The more Birds you look at, the more awed you'll be by the design. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > > Why do the older FC's have a 12.5 KW generator? Our Bounder DP has a > > 7.5 and it sure seems adequate. Why do they use the powerline gen. as > > well? Did all the FC's use the motor driven gen. or was it an option? > > Why do many BB's have 3 A/C's? Most coaches use 2 and I have never > > needed more. I just know that BB had a good reason for more. > > > > Thanks: Bruce > > Question? why did they install a telephone in the bathroom? Was it in case the door got jamed and you couldn't open it from the inside? Jon Lechich 1978 Wanderlodge > |
04-02-2006, 14:24
Jon sometime in the middle 1970's the GMC motorhome set the worlds
land speed record for motorhome and it still stands for Class A motorhomes. My understanding is that the motorhome had to be fully equipped just like it did when it was sold. I believe someone was sitting on the toilet when it approached 99MPH. Could be that the Bluebird engineers in all of their genius and wanting a really safe motorhome wanted to communicate with the person in the "loo" when they tried to crack that barrier. Could that be possible? tom warner Vernon Center,NY 1982 FC35 1985 PT40 with a phone in the "loo" At 08:49 PM 4/2/2006, you wrote: >--- In WanderlodgeForum@yahoogroups.com, "George Witt" ><mrdonut12@...> wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > > > > > > > > Bruce, > > You just really don't understand overkill, do you? :o) > > I swear, some of the Blue Bird Engineers must have worked on >the > > space shuttle, they have so many backup systems. > > If you have 3 and lose one, it's not a trip-interrupting event. > > You also get to have separate temperature controls for >different > > areas. > > Mine has the motor driven generator, I took it out and put in a > > Xantex invertor/charger. The motor driven unit was the best > > technology available at the time. Many owners update things with >that > > in mind on the updates, going to the best available when the update >is > > done. > > Blue Bird's engineering motto was: If some is good, more is > > better. ;o) > > My '81 is still an engineering marvel 25 years later and has >many > > features even new "other brands" don't have. > > We had a little get-together here and had 5 Birds show up. We > > all gave tours of our coaches and wowed the group with the cool > > features each one had. It's just amazing to see what they put in > > these things. > > The one thing that stands out to me from a design standpoint is > > that it all makes sense and whoever designed these things must have > > used them a lot to come up with the neat ideas they had. > > One of my favorites is the ladder to the roof. The top bars go > > over 5 feet onto the roof. This lets you get horizontal safely >before > > you hang one leg down searching for that first step on the ladder. > > Every other ladder I've seen makes you try to find that step > > while precariously perched almost upright with little to hang onto. > > The more Birds you look at, the more awed you'll be by the >design. > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska > > > > > > > Why do the older FC's have a 12.5 KW generator? Our Bounder DP >has a > > > 7.5 and it sure seems adequate. Why do they use the powerline >gen. as > > > well? Did all the FC's use the motor driven gen. or was it an >option? > > > Why do many BB's have 3 A/C's? Most coaches use 2 and I have >never > > > needed more. I just know that BB had a good reason for more. > > > > > > Thanks: Bruce > > > > >Question? why did they install a telephone in the bathroom? Was it in >case the door got jamed and you couldn't open it from the inside? > > >Jon Lechich >1978 Wanderlodge > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
04-02-2006, 16:23
> > Why do the older FC's have a 12.5 KW generator? Our Bounder DP has a > 7.5 and it sure seems adequate. Why do they use the powerline gen. as > well? Did all the FC's use the motor driven gen. or was it an option? > Why do many BB's have 3 A/C's? Most coaches use 2 and I have never > needed more. I just know that BB had a good reason for more. > > Thanks: Bruce > My previous coach a 1983 Wanderlodge FC 33 had 2 roof A/C's and a Kohler 7500 gas generator. I know of another 87 FC 35 that has a 8K diesel Onan generator and 2 roof A/C's. Troy 1986 Newell 40' |
04-03-2006, 01:48
>sitting on the toilet when it approached 99MPH. Could be that the >Bluebird engineers in all of their genius and wanting a really safe >motorhome wanted to communicate with the person in the "loo" when >they tried to crack that barrier. Could that be possible? > >tom warner . Tom, At 99 mph? I know bird owners are nuts, but that crazy? I don't think so......well, maybe Randy... Blair in Oregon [Non-text portions of this message have been removed] |
04-03-2006, 05:48
wrote: > > Jon sometime in the middle 1970's the GMC motorhome set the worlds > land speed record for motorhome and it still stands for Class A > motorhomes. My understanding is that the motorhome had to be fully > equipped just like it did when it was sold. I believe someone was > sitting on the toilet when it approached 99MPH. Could be that the > Bluebird engineers in all of their genius and wanting a really safe > motorhome wanted to communicate with the person in the "loo" when > they tried to crack that barrier. Could that be possible? > > tom warner > Vernon Center,NY > 1982 FC35 > 1985 PT40 with a phone in the "loo" > > At 08:49 PM 4/2/2006, you wrote: > >--- In WanderlodgeForum@yahoogroups.com, "George Witt" > ><mrdonut12@> wrote: > > > > > > --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > > > > > > > > > > > > Bruce, > > > You just really don't understand overkill, do you? :o) > > > I swear, some of the Blue Bird Engineers must have worked on > >the > > > space shuttle, they have so many backup systems. > > > If you have 3 and lose one, it's not a trip-interrupting event. > > > You also get to have separate temperature controls for > >different > > > areas. > > > Mine has the motor driven generator, I took it out and put in a > > > Xantex invertor/charger. The motor driven unit was the best > > > technology available at the time. Many owners update things with > >that > > > in mind on the updates, going to the best available when the update > >is > > > done. > > > Blue Bird's engineering motto was: If some is good, more is > > > better. ;o) > > > My '81 is still an engineering marvel 25 years later and has > >many > > > features even new "other brands" don't have. > > > We had a little get-together here and had 5 Birds show up. We > > > all gave tours of our coaches and wowed the group with the cool > > > features each one had. It's just amazing to see what they put in > > > these things. > > > The one thing that stands out to me from a design standpoint is > > > that it all makes sense and whoever designed these things must have > > > used them a lot to come up with the neat ideas they had. > > > One of my favorites is the ladder to the roof. The top bars go > > > over 5 feet onto the roof. This lets you get horizontal safely > >before > > > you hang one leg down searching for that first step on the ladder. > > > Every other ladder I've seen makes you try to find that step > > > while precariously perched almost upright with little to hang onto. > > > The more Birds you look at, the more awed you'll be by the > >design. > > > > > > George Witt > > > 81 FC 35 > > > Lincoln, Nebraska > > > > > > > > > > Why do the older FC's have a 12.5 KW generator? Our Bounder DP > >has a > > > > 7.5 and it sure seems adequate. Why do they use the powerline > >gen. as > > > > well? Did all the FC's use the motor driven gen. or was it an > >option? > > > > Why do many BB's have 3 A/C's? Most coaches use 2 and I have > >never > > > > needed more. I just know that BB had a good reason for more. > > > > > > > > Thanks: Bruce > > > > > > > >Question? why did they install a telephone in the bathroom? Was it in > >case the door got jamed and you couldn't open it from the inside? > > > > > >Jon Lechich > >1978 Wanderlodge > > > > > > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > Oh yes and one thing the engineers did forget in that area of relief was a Bidet for our french owners. Hay that's a great idea for all those fokes that use that expensive toilet paper made for motor homes. Why didn't the design engineers think of that? Maybe I should contact them and ask them why? Jon |
04-03-2006, 05:52
--- In WanderlodgeForum@yahoogroups.com, "Jon"
> > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > Jon sometime in the middle 1970's the GMC motorhome set the worlds > > land speed record for motorhome and it still stands for Class A > > motorhomes. My understanding is that the motorhome had to be fully > > equipped just like it did when it was sold. I believe someone was > > sitting on the toilet when it approached 99MPH. Could be that the > > Bluebird engineers in all of their genius and wanting a really safe > > motorhome wanted to communicate with the person in the "loo" when > > they tried to crack that barrier. Could that be possible? > > > > tom warner > > Vernon Center,NY > > 1982 FC35 > > 1985 PT40 with a phone in the "loo" > > > > At 08:49 PM 4/2/2006, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "George Witt" > > ><mrdonut12@> wrote: > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > > > > > > > > > > > > > > > > Bruce, > > > > You just really don't understand overkill, do you? :o) > > > > I swear, some of the Blue Bird Engineers must have worked > on > > >the > > > > space shuttle, they have so many backup systems. > > > > If you have 3 and lose one, it's not a trip-interrupting > event. > > > > You also get to have separate temperature controls for > > >different > > > > areas. > > > > Mine has the motor driven generator, I took it out and put > in a > > > > Xantex invertor/charger. The motor driven unit was the best > > > > technology available at the time. Many owners update things > with > > >that > > > > in mind on the updates, going to the best available when the > update > > >is > > > > done. > > > > Blue Bird's engineering motto was: If some is good, more > is > > > > better. ;o) > > > > My '81 is still an engineering marvel 25 years later and > has > > >many > > > > features even new "other brands" don't have. > > > > We had a little get-together here and had 5 Birds show > up. We > > > > all gave tours of our coaches and wowed the group with the cool > > > > features each one had. It's just amazing to see what they put > in > > > > these things. > > > > The one thing that stands out to me from a design > standpoint is > > > > that it all makes sense and whoever designed these things must > have > > > > used them a lot to come up with the neat ideas they had. > > > > One of my favorites is the ladder to the roof. The top > bars go > > > > over 5 feet onto the roof. This lets you get horizontal safely > > >before > > > > you hang one leg down searching for that first step on the > ladder. > > > > Every other ladder I've seen makes you try to find that > step > > > > while precariously perched almost upright with little to hang > onto. > > > > The more Birds you look at, the more awed you'll be by the > > >design. > > > > > > > > George Witt > > > > 81 FC 35 > > > > Lincoln, Nebraska > > > > > > > > > > > > > Why do the older FC's have a 12.5 KW generator? Our Bounder DP > > >has a > > > > > 7.5 and it sure seems adequate. Why do they use the powerline > > >gen. as > > > > > well? Did all the FC's use the motor driven gen. or was it an > > >option? > > > > > Why do many BB's have 3 A/C's? Most coaches use 2 and I have > > >never > > > > > needed more. I just know that BB had a good reason for more. > > > > > > > > > > Thanks: Bruce > > > > > > > > > > >Question? why did they install a telephone in the bathroom? Was it > in > > >case the door got jamed and you couldn't open it from the inside? > > > > > > > > >Jon Lechich > > >1978 Wanderlodge > > > > > > > > > > > > > > > > > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > Oh yes and one thing the engineers did forget in that area of > relief was a Bidet for our french owners. Hay that's a great idea > for all those fokes that use that expensive toilet paper made for > motor homes. Why didn't the design engineers think of that? Maybe I > should contact them and ask them why? Jon Owell I've got one of these in my motor home and it was not and extra but an upgrade that I installed. http://i2.photobucket.com/albums/y4/1942...C01033.jpg Jon Rebel Bird Bremerton Washington > |
