Replacing tires
04-02-2006, 09:32
Replacing tires
Hello all,
I have just noticed that my left front tire is beginning to show signs of cracking and will need replacement before too much longer. Is there a rule about replacing the steer tires together rather than just one? Both are identical Michelins now, I will replace with the same. Thanks Scott Forman 82 FC35RB Memphis |
04-02-2006, 09:52
Replacing tires
Hi Scott, good timely question. The most important aspect of selecting
replacement tires for an RV is that they be totally matched by diameter both on the front and rear. So I my opinion from years in the tire industry and as an RV is to definitely replace both front tires together. You are also wise in staying with the identical tire as they have given you good service thus far and are therefore likely to do so in the future. Regards, Neil Author, "The RVer's Ultimate Survival Guide" http://www.rvsafetyinfo.com author@... Hello all, I have just noticed that my left front tire is beginning to show signs of cracking and will need replacement before too much longer. Is there a rule about replacing the steer tires together rather than just one? Both are identical Michelins now, I will replace with the same. |
04-02-2006, 16:16
Replacing tires
Anyone know how to remove the top dash in a 1985 PT40? ON the FC
models the left screw for the top dash is behind the top light socket. Where is it on the PT? tom warner Vernon Center,NY 1982 FC35 1985 PT40 |
