Safe-T-Plus
05-13-2007, 11:26
Post: #21
Safe-T-Plus
I agree the Steer Safe solution is a little scary looking.
David B
'02 LXi, Smokey
NC
Gregory OConnor wrote:
> Rob, Thanks, If I commented about bandaid fixes and using TrueValue
> springs and clamp bolts to reengineere a design issue, It would have
> come across as an attact to the folks who fell for the sales pitch,
> or drove the flawed product.
> I do like the blow out propaganda, hopefully both springs pop off at
> the same time from the tire cords and belts. one spring remaining
> would pull a quick circle. I think the testimonials are from
> survivers of a rear tire blow out.
> GregoryO'Connor
> 94ptRomolandCa
> --- In WanderlodgeForum@yahoogroups.com
> , "Rob Robinson"
> > Several years ago I remember a thread on steering devices that
> generally
> > said if you were buying one to correct 'wandering' you should first
> have
> > your steering checked out to see if you are just applying a bandaid
> solution
> > to a worn or out of adjustment system. Further, if my memory serves
> me
> > correctly, several responses warned against buying any sytem that
> reduced
> > wandering by adding resistance to the steering systerm. It was
> expressed
> > that the extra force required by the power steering pump to
> overcome the
> > added resistance could cause premature wear and tear on the PS pump.
> > On 13/05/07, Pete Masterson wrote:
> > > The previous owner of my coach installed a Blue Ox True Center
> system
> > > with adjustable centering. I guess it's effective as I find no
> > > problems with the steering -- but I have no basis of comparison as
> > > this is the first and only BB I've ever driven.
> > > I will observe that the BB steering is a little less precise than
> > > some other larger vehicles I've driven, but the BB is the largest
> > > vehicle I've driven since I was in the Army some 40 years ago
> (where
> > > I was licensed up through 18 wheelers) -- various rental trucks
> I've
> > > driven intermediate to that time were all considerably smaller/
> > > lighter than the BB. Someone commented that the BB steering
> design is
> > > a little less precise than some other designs...
> > > Pete Masterson
> > > '95 Blue Bird Wanderlodge WBDA 42
> > > aeonix1@...
> > > On the road at Lockhart Texas
> > > On May 13, 2007, at 12:51 PM, msecoolcal@... <msecoolcal%
> 40aol.com>wrote:
> > > > Can anyone tell me if there is a difference in the final driving
> > > > result
> > > > between one safety steering attachment and another. The
> safeTplus
> > > > has a shock
> > > > absorber and the other one on the market has springs.
> > Rob, Sue & Merlin Robinson
> > 94 WLWB
> > [Non-text portions of this message have been removed]
> Version: 7.5.467 / Virus Database: 269.7.0/803 - Release Date: 5/13/2007 12:17
PM
05-13-2007, 11:46
Post: #22
Safe-T-Plus
I hear ya.
> GregoryO'Connor
> 94ptRomolandCa
> --- In WanderlodgeForum@yahoogroups.com,
> "Rob Robinson"
> generally
> have
> solution
> me
> reduced
> expressed
> overcome the
> system
> (where
> I've
> design is
> > > Pete Masterson
> > > aeonix1@...
> > > > result
> safeTplus
> > > > has a shock
> > 94 WLWB
94 WLWB
05-13-2007, 11:50
Post: #23
Safe-T-Plus
Sent: Sunday, May 13, 2007 6:26 PM
Subject: Re: [WanderlodgeForum] Re: safe-t-plus
If it were so good fleet trucks would have it.
Bob Loomas 1985 PT36
David B
'02 LXi, Smokey
NC
> GregoryO'Connor
> 94ptRomolandCa
> , "Rob Robinson"
> generally
> have
> solution
> me
> reduced
> expressed
> overcome the
> system
> (where
> I've
> design is
> > > Pete Masterson
> > > aeonix1@...
> > > > result
> safeTplus
> > > > has a shock
> > 94 WLWB
12:17 PM
05-13-2007, 12:01
Post: #24
Safe-T-Plus
I think they do. Most run some sort of Howard Steer
or Safe-T-Plus. Look, these systems greatly reduce
driver fatigue. Less fatigue equals an alert driver and
fewer misshaps.
David B
'02 LXi, Smokey
NC
> From: David Brady
> David B
> '02 LXi, Smokey
> NC
> > GregoryO'Connor
> > 94ptRomolandCa
> > , "Rob Robinson"
> > generally
> > have
> > solution
> > me
> > reduced
> > expressed
> > overcome the
> > system
> > (where
> > I've
> > design is
> > > > Pete Masterson
> > > > aeonix1@...
> > > > > result
> > safeTplus
> > > > > has a shock
> > > 94 WLWB
> 5/13/2007 12:17 PM
PM
05-13-2007, 13:51
Post: #25
Safe-T-Plus
Sent: Sunday, May 13, 2007 7:01 PM
I gust quick driving over the road for one of the lagers
company's in the US we dam sure did not have any thing
like howard power steering or steer safe.Just for the recorded I removed a
howard power steering unit from my bird because it suck.
Bob Loomas 1985 PT
fewer misshaps.
David B
'02 LXi, Smokey
NC
> From: David Brady
> David B
> '02 LXi, Smokey
> NC
> > GregoryO'Connor
> > 94ptRomolandCa
> > , "Rob Robinson"
> > generally
> > have
> > solution
> > me
> > reduced
> > expressed
> > overcome the
> > system
> > (where
> > I've
> > design is
> > > > Pete Masterson
> > > > aeonix1@...
> > > > > result
> > safeTplus
> > > > > has a shock
> > > 94 WLWB
> 5/13/2007 12:17 PM
12:17 PM
05-13-2007, 14:11
Post: #26
Safe-T-Plus
Ahhh, what do I know Bob. As long as your bird
steers good that's all that matters.
Happy Mother's Day
David Brady
'02 LXi, Smokey
NC
> From: David Brady
> removed a howard power steering unit from my bird because it suck.
> Bob Loomas 1985 PT
> fewer misshaps.
> David B
> '02 LXi, Smokey
> NC
> > From: David Brady
> > David B
> > '02 LXi, Smokey
> > NC
> > > GregoryO'Connor
> > > 94ptRomolandCa
> > > , "Rob Robinson"
> > > generally
> > > have
> > > solution
> > > me
> > > reduced
> > > expressed
> > > overcome the
> > > system
> > > (where
> > > I've
> > > design is
> > > > > Pete Masterson
> > > > > aeonix1@...
> > > > > > result
> > > safeTplus
> > > > > > has a shock
> > > > 94 WLWB
> > 5/13/2007 12:17 PM
> 5/13/2007 12:17 PM
PM
