CORRECTION NOTICE: Inverter placement In 1985 PT40
04-06-2006, 08:25
My Inverter is mounted on the shelf above where the Redi-Line was
mounted! I'm sure I have posted that the Inverter was mounted in the same spot as the Redi-Line. IT IS MOUNTED ON THE SHELF ABOVE THE REDILINE, NEAR THE TOP OF THE REDI-LINE COMPARTMENT! Sorry about that mis-post! I made a cardboard box the exact dimensions of the Xantrex and confirmed it would fit through the opening as its a little weird. suggest you do the same. Sorry about that Jay Darst 85PT40 Springfield, IL |
