Remote water shutoff valve
04-06-2006, 13:29
If one would like to replace
a cable - push/pull type or twist like the water heater drain (open/close) where would you order such? I have serched google, ect with no luck. Stephen 81 FC 33-SB Plant CIty, FL |
04-06-2006, 14:04
You have two options one electrical and one manual.
Electrical.use a 12Volt sporlan valve to control the fresh water. Manual......Use a valve like the one that controls the draining of your hot water tank. It is actuated by a cable. Pull up the bed and you can read the part number and manufacturer off the side of the lever. tom warner Vernon Center,NY 1982 FC35 (for sale soon) 1985 PT40 At 09:29 PM 4/6/2006, you wrote: >If one would like to replace >a cable - push/pull type or twist like the water heater drain >(open/close) where would you order such? I have serched google, ect >with no luck. > >Stephen >81 FC 33-SB >Plant CIty, FL > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
