Remote water shutoff valve
04-06-2006, 13:29
If one would like to replace a fresh water valve, and make it
a cable - push/pull type or twist like the water heater drain
(open/close) where would you order such? I have serched google, ect
with no luck.
Stephen
81 FC 33-SB
Plant CIty, FL
04-06-2006, 14:04
You have two options one electrical and one manual.
Electrical.use a 12Volt sporlan valve to control the fresh water.
Manual......Use a valve like the one that controls the draining of
your hot water tank. It is actuated by a cable. Pull up the bed and
you can read the part number and manufacturer off the side of the lever.
tom warner
Vernon Center,NY
1982 FC35 (for sale soon)
1985 PT40
>with no luck.
>Stephen
>81 FC 33-SB
>Plant CIty, FL
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
