headlamp,taillamp, front lightbar replacement
04-08-2006, 15:49
I have a '92 WB coach. Does anyone have the information on which Volvo
taillights are used. And which Headlamp Assembly is used (I think its a Ford application) Also, is the front light bar a Mercury Sable application? |
04-08-2006, 15:56
Its a Volvo part number:
Left lense: T V V 8171 Right lense: T V V 8172 You can buy them for about $90 each at 1-877-902-2600 Tom Warner Vernon Center,NY 1982 FC35 (for sale soon) 1985 PT 40 At 11:49 PM 4/8/2006, you wrote: >I have a '92 WB coach. Does anyone have the information on which Volvo >taillights are used. And which Headlamp Assembly is used (I think its >a Ford application) Also, is the front light bar a Mercury Sable >application? |
04-09-2006, 01:26
--- In WanderlodgeForum@yahoogroups.com, "rickdesilva"
> > I have a '92 WB coach. Does anyone have the information on which Volvo > taillights are used. And which Headlamp Assembly is used (I think its > a Ford application) Also, is the front light bar a Mercury Sable > application? > I repaced the the tail lights in my 91 with: Volvo part # 3518175 or TVV8171 (left) and 3518176 or TVV8172 (right). Apparently from 90-92 Volvo 740 Sedan. The head lights are Ford F150 assemblies, mid 90's I think. I seem to have misplaced the exact year and part numbers. Roger Webb - 91WL - Cedar Rapids, IA [Non-text portions of this message have been removed] |
04-09-2006, 03:43
The headlamp assemblies are Ford F150 85 to 88
you can buy them several ways,chrome trim or without with parklamp or without. the center piece is a Blue Bird invention Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WB41 |
04-09-2006, 04:35
Light bar is $35.00 from BB, I replaced it with Brushed SS ( $4.00).
The light socket pieces are $60 each (4 units total) from BB. I have some extra SS stock if you are in the area I can bend one up for you. A forum member , Curt is installing relays in the engine compartment on my bus for the tail lights and rewiring the harness on the lift door because we found several faults. I also want more juice back there for a trailer. The tail light connections are protected by the trunk interior on the Volvo cars but in the bus BB covered them with a un insulated piece of plastic. I suspect a prior owner cleaned the corroded connections and put the dielectric (?) grease on the connections which advanced the corrosion and caused poor electrical conductivity. Gregory O'Connor 94pt Romoland California --- In WanderlodgeForum@yahoogroups.com, "rickdesilva" > > I have a '92 WB coach. Does anyone have the information on which Volvo > taillights are used. And which Headlamp Assembly is used (I think its > a Ford application) Also, is the front light bar a Mercury Sable > application? > |
