3208 excessive cold start start-up smoke
04-11-2006, 06:25
After sitting a couple of months I started up the 300hp 3208 and got
excessive white smoke and the engine was not as smooth as normal. This lasted only two or three miles and now all is back to normal smoke on the start ups. Any thoughts as to what might have caused this. Jack '87 FC35 "Traveller" Franklin, NC |
04-11-2006, 06:44
Sitting for a couple of months
I would think condensation etc so the white smoke is steam but what do i know guy smalley --- In WanderlodgeForum@yahoogroups.com, "b19801973" > > After sitting a couple of months I started up the 300hp 3208 and got > excessive white smoke and the engine was not as smooth as normal. This > lasted only two or three miles and now all is back to normal smoke on > the start ups. Any thoughts as to what might have caused this. > > Jack > '87 FC35 "Traveller" > Franklin, NC > |
04-11-2006, 07:46
Air in the fuel column. It will clear out with use.
Mike Hohnstein ----- Original Message ----- From: b19801973 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, April 11, 2006 1:25 PM Subject: [WanderlodgeForum] 3208 excessive cold start start-up smoke After sitting a couple of months I started up the 300hp 3208 and got excessive white smoke and the engine was not as smooth as normal. This lasted only two or three miles and now all is back to normal smoke on the start ups. Any thoughts as to what might have caused this. Jack '87 FC35 "Traveller" Franklin, NC ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-11-2006, 13:52
Jack that is a normal thing when the Coach has been down a bit. Also the
oi8l washed a little around the rings, not a problem. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 06:25 PM 4/11/2006 +0000, you wrote: >After sitting a couple of months I started up the 300hp 3208 and got >excessive white smoke and the engine was not as smooth as normal. This >lasted only two or three miles and now all is back to normal smoke on >the start ups. Any thoughts as to what might have caused this. > >Jack >'87 FC35 "Traveller" >Franklin, NC |
04-11-2006, 14:25
Perhaps some sticky valves causing incomplete combustion?
Kerry 82 FC 35 Denver |
