best way to operate electric trailer brakes from BB pt-40
04-13-2006, 15:51
What type and make controller would be best to controll elec. brakes
on two axel trailer towed behind a pt-40?
I notice there are electric operated or air- elec. operated. What
would be the advantageof the air controled?
Also I see that Reese has an hand- remote control. Would this be good
or bad.
Is there any reason you could not power the controler from the gen.
set battery?
thanks,marvin
1984 pt-40
04-14-2006, 02:21
On some brake controllers the controller unit under the dash is a kinda
rheostat that uses inertia to regulate the braking force. these
controllers are enabled by the bus tail brake light throwing a switch
after the controller ( if you go down hill the controller feels
inertia and will signal trailer braking). I know of air over hydrolic
brakes for trailers which is like a surge unit on the trailer operated
by airpress from the tow veh. If there is a controller that uses air
press as a force regulater for trailers , oder me one.
In California you need a battery on the trailer for the brakeaway safty
brake system. E brakes on a trailer do not react well with antilock
tow brakes. I disable the antilock when towing with a pickup.
94 pt40 Romoland California--- In
> or bad.
> set battery?
> thanks,marvin
> 1984 pt-40
04-14-2006, 05:51
Yes Hayes makes an air operated electric brake controller, just don't know what
the advantage would be.K1100400B is the part ph 800 892 2676Marvin
SkaggsBuffalo, Ky. 427161984 PT40--- On Fri 04/14, Gregory OConnor <
Gregoryoc@... > wrote:From: Gregory OConnor [mailto:
Gregoryoc@...]To: WanderlodgeForum@...: Fri, 14 Apr 2006
14:21:03 -0000Subject: [WanderlodgeForum] Re: best way to operate electric
trailer brakes from BB pt-40On some brake controllers the controller unit under
the dash is a kinda rheostat that uses inertia to regulate the braking force.
these controllers are enabled by the bus tail brake light throwing a switch
after the controller ( if you go down hill the controller feels inertia and
will signal trailer braking). I know of air over hydrolic brakes for trailers
which is like a surge unit on the trailer operated by airpress from the tow veh.
If there is a controller that uses air press as a force regulater for trailers ,
oder
me one. In California you need a battery on the trailer for the brakeaway safty
brake system. E brakes on a trailer do not react well with antilock tow brakes.
I disable the antilock when towing with a pickup.Gregory O'Connor94 pt40
Romoland California--- In WanderlodgeForum@yahoogroups.com, "sam09_99"
wrote:>> > What type and make controller would be best to controll
elec. brakes > on two axel trailer towed behind a pt-40?> > I notice
there are electric operated or air- elec. operated. What > would be the
advantageof the air controled?> > Also I see that Reese has an hand-
remote control. Would this be good > or bad.> > Is there any reason you
could not power the controler from the gen. > set battery?>
thanks,marvin> 1984 pt-40>
YAHOO! GROUPS LINKS
Visit your group "WanderlodgeForum" on the web.
To unsubscribe from this group, send an email to:
_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
04-14-2006, 13:15
Marvin, I placed an order for the controller. The advantage I see is
that it will send a signal to the trailer true to the operators force
on the brake pedal. The harder the operator pushes the brake pedal the
more juice it will send to the e trailer brakes( even at 5 mph). The
inertia controllers are finiky and braking force is a factor of too
many variables, even mounting position and mounting angle of the
inertia-controller can change or disable braking force.
94pt40 Romoland California
"The faster you can stop, the faster you can go"
don't know what the advantage would be.K1100400B is the part ph 800 892
2676Marvin SkaggsBuffalo, Ky. 427161984 PT40---
04-15-2006, 06:23
George,
What were the $ for that controller, if you don't mind my asking? Including
shipping and tax if you know yet.
Thanx
Dick Hayden - '87 PT 38 - Lk Stevens, WA
Sent: Friday, April 14, 2006 6:15 PM
Subject: [WanderlodgeForum] Re: best way to operate electric trailer brakes
from BB pt-40
SPONSORED LINKS Recreational
vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\
al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKk\
U7Dzhn_ObWmSYTw>
Wanderlodge<http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\
9U0JvqYQ> Automotive
maintenance<http://groups.yahoo.com/gads?t=ms&k=Auto...ecrea\
tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\
+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4\
u_5wI8Pmy34cC1O9CxA>
Recreational vehicle
dealer<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\
+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_\
XahaeYHfELr6o72IW1A> Used recreational
vehicles<http://groups.yahoo.com/gads?t=ms&k=Used...Recre\
ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\
e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UG\
EY5km4L-kXbDI4ZSadEw> Automotive
radiators<http://groups.yahoo.com/gads?t=ms&k=Auto...ation\
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmI\
SsCWgTnMq_4GlXA>
YAHOO! GROUPS LINKS
a.. Visit your group
"WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
WanderlodgeForum-unsubscribe@yahoogroups.com @yahoogroups.com?subject=Unsubscribe>
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service<http://docs.yahoo.com/info/terms/>.
04-15-2006, 16:06
The air to electric brake-controller is from SouthWest Wheel . 150.00
no shipping charge and I will pay 7.75% local Riverside County sales
Tax as it is for a dumptruck business purchase.
http://www.brakecontroller.com/
I have purchased axles, hubs and trailer parts from SW Trailer in the
past with no problems.
94pt40 DT
--- In WanderlodgeForum@yahoogroups.com, "Richard Hayden"
> George,
Including shipping and tax if you know yet.
