New Allison Software
04-15-2006, 01:15
David, thank you for the information on the transmission. I didn't know that
they could be upgraded with software. Ernie-p83pt40 in louisiana- no
computers except my laptop
04-15-2006, 04:14
Folks,
While at Smith Power Products in Salt Lake City, Ut,
I had the HD4000 tranny reflashed with the latest software.
I was running 0C00ABF008N and upgraded to 0F00ABF005S.
The first 4 digits are the major number of the software. From
0C00 to 0F00 reflects a 3 level later revision. The last 4 digits
are the minor number of the software release. ABF means that
identifies the 4000 series transmission. My complaint with revision
0C00 was that it hunted for the proper gear when ascending
a hill. She cycled repeatedly thru downshifts and upshifts 'till I
tired of it and hit the down arrow to lock her into the proper
cog. Not so anymore, with 0F00 she downshifts once and stays
there, and the shift points keep the engine at 1750rpm or
above. Very pleased! Another benefit is that the shift quality
is much improved. The tranny learns how to shift by measuring
torque on the input and output shafts, and it changes the quality
of the shift by varying the pulse width of the hydraulic fluid into
each clutch pack. I can no longer feel the downshifts they are so
smooth, the only indication is that the rpms on the tach change.
Very pleased! We also did an a engine oil (synthetic) and tranny
oil (transynd synthetic) lab analysis - everything checked out
well. 70K miles on the LXi and she's just breaking in.
David Brady
'02 LXi, Smokey
Va
04-15-2006, 05:24
Along the same line, I learned at FMCA that the Allison software
defaults to a high RPM/Speed shift point for better performance in
acceleration. On mine, the shift point from 5th to 6th is right
around 60 mph. The tranny constantly shifts back and forth on
inclines.
If you push the Mode button, the shift points are lower and,
therefore, more economical for driving distances. The 5th/6th shift
point is 10 mph lower. No more hunting between the two at highway
speeds. So, unless you are at Maxton, they recommended pushing the
Mode button every startup to use the lower shift points.
Why is it this way? Allison actually had it reversed at first.
They received so many complaints from RV sales people that the
diesel engines did not rev high enough to impress buyers and the
speed off the line was too slow (unofficial inside story, not
verified and probably will not be confiremd by Allison), that they
acquiesced to the market. Allison will change your tranny to
default to the "economic" mode for a fee. From David's description
of his new software version, they might have done that as a default.
Tommy "Two Shoes" McCarthy
Poway, CA (San Diego)
--- In WanderlodgeForum@yahoogroups.com, David Brady
> Folks,
> David Brady
> '02 LXi, Smokey
> Va
04-15-2006, 05:32
With the upgraded tranny software the economy mode is preserved.
With economy enabled the shift points are lowered by 300 rpms. W/o
economy enabled the shift points are such that the engine rpms are
at or above 1750rpm, within reason of course. With economy enabled
the shift points fall down as low as 1400 rpms. The default is still
performance; economy must be selected by the user, and there is a clear
performance difference to them. I think what happened is that many
customers complained about the shift hunting and allison has produced
a fix. Trust me, the overall performance, acceleration in non-economy
mode, is profound. The "fee" for the hunting fix is quite worth it. Plus,
the shift quality is utter silk. One must truly look at the tach to even
notice
them.
David Brady,
'02 LXi, Smokey
Va
> inclines.
>> Folks,
>> David Brady
>> '02 LXi, Smokey
>> Va
> Yahoo! Groups Links
04-15-2006, 08:06
OK David, I've been "baited" - so what was the "quite
worth it" fee?
John Suter
2000LXi
> is preserved.
> 300 rpms. W/o
> engine rpms are
> economy enabled
> default is still
> at the tach to even
> notice
> them.
> David Brady,
> '02 LXi, Smokey
> Va
> Allison software
> to 6th is right
> and forth on
> > inclines.
> lower and,
> The 5th/6th shift
> the two at highway
> points.
> reversed at first.
> people that the
> buyers and the
> story, not
> Allison), that they
> your tranny to
> David's description
> that as a default.
> Brady
> > wrote:
> >> Folks,
> Ut,
> software.
> 0F00ABF005S.
> software. From
> The last 4 digits
> means that
> ascending
> upshifts 'till I
> into the proper
> once and stays
> 1750rpm or
> shift quality
> by measuring
> changes the quality
> the tach change.
> breaking in.
> >> David Brady
> >> '02 LXi, Smokey
> >> Va
> > Yahoo! Groups Links
Do You Yahoo!?
http://mail.yahoo.com
04-15-2006, 09:02
I don't have a computerized Allison transmission either. However,
Allison does maintain a database with past service performed
on your tranny by an Allison certified shop (not aammco). I was able
to check ours by having a tech. enter the tranny serial number in
their computer to find the history of service (no bads recorded).
Ron 85PT36 No. soggy, sloppy, sloshy, slippery, drenched N. California
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote:
>I didn't know that they could be upgraded with software.
>Ernie-p83pt40 in louisiana- no computers except my laptop
04-15-2006, 16:12
Hi John,
I don't know what the charge was for new tranny software but I
can say that for $380.00 I had the tranny topped off, the engine
oil and filters changed, the tranny software reved, engine oil and
tranny oil lab analysis performed, the engine and radiators
steam cleaned, and the engine, tranny, and abs checked for
error codes. So it could not have been much, took about 20
minutes.
Best Regards,
David Brady,
'02 LXi, Smokey,
Va
> worth it" fee?
> John Suter
> 2000LXi
04-16-2006, 03:16
With the new software, powering up a 6% grade, initial speed
75 mph, under full load, turbo pyrometer: 900 deg F, turbo
boost: 27 psi, she downshifts to 5th gear at 67 mph.
David Brady
'02 LXi, Smokey
Va
> inclines.
