Now Here's A Dumb Question...
04-15-2006, 09:37
My isle light, under the dinnet table, stoped working. I feel rather
dim-whitted but after buying a new bulb I can not make the light work.
I suspect that it is not grounded correctly. When I took the fitting
apart the ground wire just fell out like it was loose.
Does anyone know how this light works?
Man, I feel foolish!
Oh, there are two other isle lights on the same circuit and they both
work fine.
James
78FC33SB
LasVegas NV
04-15-2006, 13:03
James,
To make those lights work, you have to put that ground wire against
the metal part of the lamp holder. I made them work by putting the
ground wire where the metal "prongs" that hold the light to the
square metal and pressing it all together.
David Hollis Spfld,IL James has my bus
--- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions"
rather
work.
fitting
both
> work fine.
> James
> 78FC33SB
> LasVegas NV
04-15-2006, 17:31
Thanks Dave, that was easy. I'm having a blast with the bus !! I
hope all is well with you and yours, thanks for the reply.
James
78FC33SB
LasVegas NV
--- In WanderlodgeForum@yahoogroups.com, "dthollis1961"
> James,
against
> rather
> work.
> fitting
> both
> > work fine.
> > James
> > 78FC33SB
> > LasVegas NV
