35 FC Transmissions
04-17-2006, 16:11
35 FC Transmissions
Tom, a diesel or gasoline engine is an air breathing device. A turbo
charger increases the amount of air it can breath. If the boost pressure
provided is 14.7 PSI, the engine sees instead of the normal one atmosphere
of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses
considerations, now twice the size engine. It does of course as you noted,
take more fuel. The intercooler takes some of the heat out of the intake
air, providing a denser, heavier fuel air mixture. The magic as I see it is
the electronic controls and devices used today to not only lower emissions
but also create more power with less fuel.
Jerry
MS Gulf Coast
Looking for a BB
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner
Sent: Monday, April 17, 2006 10:27 PM
Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions
Hank thats about what I am getting with my 1982 FC35 with the Cat
3208NA. People forget that turbo chargers and intercoolers do not
make an engine more efficient they allow a denser fuel/air charge to
be pumped into the cylinder. More fuel pumped into the cylinder means
more fuel used. A horsepower increase from 210HP to 300HP in the same
engine can only be realized thru the use of more fuel. There is no
magic involved.
Tom Warner
Vernon Center,NY
1982 FC35 (for sale http://tinyurl.com/lotbdcan )
1985 PT40
At 09:55 PM 4/17/2006, you wrote:
>---Mike:
>That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg
>consistently while my 90SP36 gets only 6-7mpg!!! That's a true
>staement and NOT nuts!
>Regards,
>Hank Hannigan
>1990SP36
>In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein"
><MHOHNSTEIN@...> wrote:
> > That's nuts. Turbo charging and charge air coolers are methods to
>improve the efficiency of diesel engines. The 5 speed OD trans
>keeps engine speed down and increased horse power improves the power
>to weight ratio over the older NA/643 speed bumps. Most 87up FCs
>have two airs and the smaller lighter gen set, handling and
>acceleration are greatly enhanced. There is no way a NA gets better
>mileage than a turbo, level playing field.
> > I drove Millers 88 FC a while back and it was a night and day
>diffference compared to my well tuned 250 hp 83 rear bath.
> > Engine speed is the major issue when considering improving
>milage.
> > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at
>full throttle and don't need to go over 2500 rpm for max power. NAs
>need to spin faster due to the lack of forced induction and need
>more fuel to facilitate that.
> > Now I could be over looking something, so if you have some REAL
>experience that might lend some credibility to your aurgument I'm
>listening Warner. I'm interested in miles you have driven your NA,
>average speed, speed on grades, that sort of thing. I assume you
>have taken some trips, so lets hear what you have really seen for
>fuel use. Those considering your FC might want to know.
> > Mike Hohnstein
> > ----- Original Message -----
> > From: Tom Warner
> > Sent: Sunday, April 16, 2006 9:58 PM
> > I doubt very much if you will find an 87-89 FC that will even
>get
> > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I
>believe
> > the 4th gear is the same as the 5th or 6th gear in the 87-89.
> > Tom Warner
> > Vernon Center,NY
> > 1982 FC35 ( for sale at
><http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.photobucke
> > 1985 PT 40
> > At 09:55 PM 4/16/2006, you wrote:
> > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway"
> > > wrote:
> > > >i hear storys from 7-10 mpg on the fcs with the 4 speed
> > >tranny,now,thats not bad milage as i see it!
> > >randy dupree
> > > > Does anyone know if they ever put the 5 or 6 speed overdrive
> > > > transmission in the 35 FC? If so, what year did they
>start? I've
> > > > zeroed in on the 35FC as the correct Bird for my wife and I,
> > >however, I
> > > > really hesitate buying one that gets such poor fuel mileage
>as the 4
> > > > speed Allison. John & Pat - Wantabee's, Stuart
> > >SPONSORED LINKS
> > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?
>t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&
>w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr
>eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh
>n_ObWmSYTw>Recreational
> > >vehicles
>t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot
>ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v
>ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-
>8HJdysB3QLPj9U0JvqYQ>Wanderlodge
>t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge
>&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec
>reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm
>y34cC1O9CxA>Automotive
> > >maintenance
>t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander
>lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use
>d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah
>aeYHfELr6o72IW1A>Recreational
> > >vehicle dealer
>t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl
>odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used
>+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km
>4L-kXbDI4ZSadEw>Used
> > >recreational vehicles
>t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w
>3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre
>ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT
>nMq_4GlXA>Automotive
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
"<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr
oup/WanderlodgeForum>WanderlodgeForum"
>on the web.
> > > * To unsubscribe from this group, send an email to:
> > > >subject=Unsubscribe>WanderlodgeForum-unsubscribe@yahoogroups.com
> > > * Your use of Yahoo! Groups is subject to the
<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo!
> Terms of Service.
> > YAHOO! GROUPS LINKS
> > a.. Visit your group "WanderlodgeForum" on the web.
> > b.. To unsubscribe from this group, send an email to:
> > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms
>of Service.
>YAHOO! GROUPS LINKS
> * Visit your group
> "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the
web.
Wan
SPONSORED LINKS
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v
ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU
kCKkU7Dzhn_ObWmSYTw> vehicles
Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2
=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use
d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP
j9U0JvqYQ>
Automotive
<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de
aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF
4u_5wI8Pmy34cC1O9CxA> maintenance
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati
onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic
le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s
ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer
Used
<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio
nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl
e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si
g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles
Automotive
<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve
hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV
MmISsCWgTnMq_4GlXA> radiators
_____
YAHOO! GROUPS LINKS
* Visit your group "WanderlodgeForum
<http://groups.yahoo.com/group/WanderlodgeForum> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
04-17-2006, 16:28
35 FC Transmissions
Jerry the electronic controls on todays diesel engine were installed
to ensure that the engines meet the very stringent emission standards
of today. They have not become more efficient they have become
compliant with the laws at the expense of lowering their
efficiency. They achieve that by creating more heat and thus run at
higher temperatures, and they therefore need better lubricants and
increased maintenance, at the same time of operating at reduced
power. Remember there is always a tradeoff to everything. A gallon
of diesel fuel contains approximately 140,000 BTUs. One horsepower
equals 2545 BTUs per hour. Its easy to see that increased horsepower
is only achieved thru packing more fuel/air mixture into the
cylinders and efficiently exhausting it.
Tom Warner
Vernon Center,NY
1982 FC35 for sale ( http://tinyurl.com/zv2on )
1985 PT40
>Jerry
>MS Gulf Coast
>Looking for a BB
> _____
>From: WanderlodgeForum@yahoogroups.com
>magic involved.
>Tom Warner
>Vernon Center,NY
>1982 FC35 (for sale <http://tinyurl.com/lotbdcan>http://tinyurl.com/lotbdcan )
>1985 PT40
> >---Mike:
> >Regards,
> >Hank Hannigan
> >1990SP36
> >milage.
> > > Mike Hohnstein
> > > From: Tom Warner
> >get
> >believe
> > > Tom Warner
> > > Vernon Center,NY
> ><<http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.p
> > > 1985 PT 40
> > > >randy dupree
> >start? I've
> > > >however, I
> >as the 4
> > > >SPONSORED LINKS
><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://groups.ya\
hoo.com/gads?
> > > >vehicles
hoo.com/gads?
hoo.com/gads?
> > > >maintenance
hoo.com/gads?
> > > >vehicle dealer
hoo.com/gads?
hoo.com/gads?
> > > >radiators
> > > >YAHOO! GROUPS LINKS
> > > > * Visit your group
>"<<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/grou\
> >on the web.
><<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>http://d\
> > Terms of Service.
> > > YAHOO! GROUPS LINKS
> >of Service.
> >YAHOO! GROUPS LINKS
> > * Visit your group
"<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\
> on the
>web.
>Wan
> Terms of Service.
>SPONSORED LINKS
>Recreational
><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v>h\
>Wanderlodge
><<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2>h\
>j9U0JvqYQ>
>Automotive
><<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+>h\
>Recreational
><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati>h\
>Used
><<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio>h\
>Automotive
><<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve>h\
> _____
>YAHOO! GROUPS LINKS
WanderlodgeForum>
>" on the web.
>Terms of Service.
> _____
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
04-17-2006, 16:33
35 FC Transmissions
---Mike:
You said an NA is "not good at all." I have a Mercedes NA diesel
here in Australia and it is simply great! 4:11 diff and I get great
mileage too.
That ole 210NA CAT is great too!!I bet a lot of guys like their 210
CAT NA's!!
Wish I had my old 77FC33 back!! Simple, 8-9mpg, a "thrill" to
steer and noisy!! and...$100,000 less tied up in it!!
Regards,
Hank Hannigan
1990 SP36 (stored in VEGAS)
> And I said level playing field. You want to talk about weight
difference? How about speed? You are comparing apples to oranges
and that IS nuts. NAs are nasty smoky obsolete and over the hill,
at best. A diesel with out a turbo isn't good
> not good at all.
> MH
> From: Henry Jay Hannigan
> Sent: Monday, April 17, 2006 8:55 PM
> Subject: [WanderlodgeForum] Re: 35 FC Transmissions
> ---Mike:
> Regards,
> Hank Hannigan
> 1990SP36
methods to
power
FCs
better
> milage.
at
NAs
REAL
I'm
NA,
you
for
> > Mike Hohnstein
> > From: Tom Warner
even
> get
> believe
> > Tom Warner
> > Vernon Center,NY
> http://s69.photobucket.com/albums/i57/warbucks13477/ )
> > 1985 PT 40
> > >randy dupree
overdrive
> start? I've
and I,
> > >however, I
mileage
> as the 4
> > >SPONSORED LINKS
> > >vehicles
> > >maintenance
> > >vehicle dealer
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
> on the web.
> > YAHOO! GROUPS LINKS
Terms
> of Service.
> YAHOO! GROUPS LINKS
of Service.
04-17-2006, 17:06
35 FC Transmissions
I belive there is a diffrence in lenght and weight between the two
coaches, kind of like apples and oranges Wink
Thanks
Bruce Campbell
83FCSB "Blue Skies" slow,heavy,7-8mpg,running 60mph with gennie wide
open
--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
> ---Mike:
> Regards,
> Hank Hannigan
> 1990SP36
to
power
better
> milage.
NAs
> > Mike Hohnstein
> > From: Tom Warner
> get
> believe
> > Tom Warner
> > Vernon Center,NY
> > 1985 PT 40
> > >randy dupree
> start? I've
> > >however, I
> as the 4
> > >SPONSORED LINKS
> > >vehicles
> > >maintenance
> > >vehicle dealer
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
> on the web.
> > YAHOO! GROUPS LINKS
> of Service.
04-17-2006, 17:06
35 FC Transmissions
You sound bitter.
MH
Sent: Monday, April 17, 2006 11:33 PM
---Mike:
mileage too.
CAT NA's!!
Regards,
Hank Hannigan
> not good at all.
> MH
> ---Mike:
> Regards,
> Hank Hannigan
> 1990SP36
methods to
power
FCs
better
> milage.
at
NAs
REAL
I'm
NA,
you
for
> > Mike Hohnstein
> > From: Tom Warner
even
> get
> believe
> > Tom Warner
> > Vernon Center,NY
> > 1985 PT 40
> > >randy dupree
overdrive
> start? I've
and I,
> > >however, I
mileage
> as the 4
> > >SPONSORED LINKS
> > >vehicles
> > >maintenance
> > >vehicle dealer
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
> on the web.
> > YAHOO! GROUPS LINKS
Terms
> of Service.
> YAHOO! GROUPS LINKS
of Service.
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive
radiators
YAHOO! GROUPS LINKS
04-17-2006, 17:09
35 FC Transmissions
Naturally Warner will be detuning his PT.
MH
Sent: Monday, April 17, 2006 10:26 PM
magic involved.
Tom Warner
Vernon Center,NY
1985 PT40
>---Mike:
>Regards,
>Hank Hannigan
>1990SP36
>milage.
> > Mike Hohnstein
> > From: Tom Warner
>get
>believe
> > Tom Warner
> > Vernon Center,NY
><http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.photobucket.co\
> > 1985 PT 40
> > >randy dupree
>start? I've
> > >however, I
>as the 4
> > >SPONSORED LINKS
> > >vehicles
> > >maintenance
> > >vehicle dealer
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
>on the web.
> Terms of Service.
> > YAHOO! GROUPS LINKS
>of Service.
>YAHOO! GROUPS LINKS
> * Visit your group
web.
Wanderl\
radiators
YAHOO! GROUPS LINKS
04-17-2006, 17:16
35 FC Transmissions
You got that right Jerry.
MH
Sent: Monday, April 17, 2006 11:11 PM
Subject: RE: [WanderlodgeForum] Re: 35 FC Transmissions
Jerry
MS Gulf Coast
Looking for a BB
_____
magic involved.
Tom Warner
Vernon Center,NY
1985 PT40
>---Mike:
>Regards,
>Hank Hannigan
>1990SP36
>milage.
> > Mike Hohnstein
> > From: Tom Warner
>get
>believe
> > Tom Warner
> > Vernon Center,NY
> > 1985 PT 40
> > >randy dupree
>start? I've
> > >however, I
>as the 4
> > >SPONSORED LINKS
> > >vehicles
> > >maintenance
> > >vehicle dealer
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
>on the web.
> Terms of Service.
> > YAHOO! GROUPS LINKS
>of Service.
>YAHOO! GROUPS LINKS
> * Visit your group
web.
Wan
SPONSORED LINKS
Recreational
Wanderlodge
j9U0JvqYQ>
Automotive
Recreational
Used
Automotive
_____
YAHOO! GROUPS LINKS
_____
YAHOO! GROUPS LINKS
04-17-2006, 21:36
35 FC Transmissions
Mike:
u r rite about the wieght difference.
lol
Regards,
Hank Hannigan
90SP36
> You sound bitter.
> MH
> ---Mike:
diesel
great
> mileage too.
210
> CAT NA's!!
> Regards,
> Hank Hannigan
oranges
hill,
> > not good at all.
> > MH
> > ---Mike:
true
> > Regards,
> > Hank Hannigan
> > 1990SP36
> methods to
trans
> power
87up
> FCs
gets
> better
day
> > milage.
rpm
> at
power.
> NAs
need
> REAL
aurgument
> I'm
your
> NA,
assume
> you
seen
> for
> > > Mike Hohnstein
> > > From: Tom Warner
> even
> > get
coaches. I
> > believe
87-89.
> > > Tom Warner
> > > Vernon Center,NY
> > > 1985 PT 40
speed
> > > >randy dupree
> overdrive
they
> > start? I've
wife
> and I,
> > > >however, I
> mileage
> > as the 4
> > > >SPONSORED LINKS
> > > >vehicles
> > > >maintenance
> > > >vehicle dealer
> > > >radiators
> > > >YAHOO! GROUPS LINKS
> > > > * Visit your group
> > on the web.
Service.
> > > YAHOO! GROUPS LINKS
Yahoo!
> Terms
> > of Service.
> > YAHOO! GROUPS LINKS
Terms
> of Service.
maintenance
Automotive radiators
> YAHOO! GROUPS LINKS
of Service.
04-17-2006, 23:39
35 FC Transmissions
Jerry
MS Gulf Coast
Looking for a BB
_____
magic involved.
Tom Warner
Vernon Center,NY
1985 PT40
>---Mike:
>Regards,
>Hank Hannigan
>1990SP36
>milage.
> > Mike Hohnstein
> > From: Tom Warner
>get
>believe
> > Tom Warner
> > Vernon Center,NY
> > 1985 PT 40
> > >randy dupree
>start? I've
> > >however, I
>as the 4
> > >SPONSORED LINKS
> > >vehicles
> > >maintenance
> > >vehicle dealer
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
>on the web.
> Terms of Service.
> > YAHOO! GROUPS LINKS
>of Service.
>YAHOO! GROUPS LINKS
> * Visit your group
web.
Wan
SPONSORED LINKS
Recreational
Wanderlodge
j9U0JvqYQ>
Automotive
Recreational
Used
Automotive
_____
YAHOO! GROUPS LINKS
_____
YAHOO! GROUPS LINKS
04-18-2006, 01:38
35 FC Transmissions
Spoken like a true technical illiterate. Sophisticated contempary fuel controls
are responsible for the greatly extended service life of engines, gasoline and
diesel.
Extrordinary horse power per cubic inch production is common place these days,
dwarfing power levels of 20 years ago. There is a reason a 3208 10.3 litre
engine is limited to 300 hp in highway use and an 8.3 litre Cummins routinely
make in excess of 330, more if you can cool it.
We work on many hot rod trucks in the shop and it's unbelievable how much punch
these new fangled 5.9s can produce. Electronics are really magic. Expensive
but very very cool. I wish I could retrofit my throwaways (3208) with new fuel
controls.
MH
Sent: Monday, April 17, 2006 11:28 PM
Tom Warner
Vernon Center,NY
1985 PT40
>Jerry
>MS Gulf Coast
>Looking for a BB
> _____
>magic involved.
>Tom Warner
>Vernon Center,NY
>1985 PT40
> >---Mike:
> >Regards,
> >Hank Hannigan
> >1990SP36
> >milage.
> > > Mike Hohnstein
> > > From: Tom Warner
> >get
> >believe
> > > Tom Warner
> > > Vernon Center,NY
> > > 1985 PT 40
> > > >randy dupree
> >start? I've
> > > >however, I
> >as the 4
> > > >SPONSORED LINKS
hoo.com/gads?
> > > >vehicles
hoo.com/gads?
hoo.com/gads?
> > > >maintenance
hoo.com/gads?
> > > >vehicle dealer
hoo.com/gads?
hoo.com/gads?
> > > >radiators
> > > >YAHOO! GROUPS LINKS
> > > > * Visit your group
> >on the web.
> > Terms of Service.
> > > YAHOO! GROUPS LINKS
> >of Service.
> >YAHOO! GROUPS LINKS
> > * Visit your group
> on the
>web.
>Wan
> Terms of Service.
>SPONSORED LINKS
>Recreational
>Wanderlodge
>j9U0JvqYQ>
>Automotive
>Recreational
>Used
>Automotive
> _____
>YAHOO! GROUPS LINKS
WanderlodgeForum>
>" on the web.
>Terms of Service.
> _____
>YAHOO! GROUPS LINKS
> * Visit your group
web.
Wanderl\
YAHOO! GROUPS LINKS
