83 FC - Is my engine 225 or 250 horse?
04-17-2006, 09:20
Hello Everyone,
I'm a new owner of an 83' FC-35, manufactured in July of that year. How do I tell if the engine is a 225 or 250 horse turbo 3208? I was told that the coaches built in the later months in 83' had 250 horse engines from the factory. I have looked the engine over, read through my box of manuals, and checked every ID plate on the vehicle. No record anywhere. Even the previous owner had no idea! Does the Bluebird factory provide you with a build sheet if you request it? Any help is always appreciated! Andy Coleman 83 FC35 Spring Lake Heights, NJ |
04-17-2006, 09:48
I also have an '83 mine was built in oct '82 and titled as an '83.
Mine is a 225HP it should be on the head covers, passenger side rear of the cover mine also has the max RPM 2600 on it. As I understand it they switched to 250HP late in '83 only the last 10 or 20 units of the year, or something like that. It's a good bet it's a 225HP, but who knows some have been changed out, and if that has happened most likely it's a 250HP. I know it makes a diffrence on it parts you will need to buy. Maybe someone here knows how to look at them to tell the diffrence. Thanks Bruce Campbell 83'FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > Hello Everyone, > > I'm a new owner of an 83' FC-35, manufactured in July of that year. > How do I tell if the engine is a 225 or 250 horse turbo 3208? > > I was told that the coaches built in the later months in 83' had 250 > horse engines from the factory. > > I have looked the engine over, read through my box of manuals, and > checked every ID plate on the vehicle. No record anywhere. > > Even the previous owner had no idea! > > Does the Bluebird factory provide you with a build sheet if you > request it? > > Any help is always appreciated! > > Andy Coleman > 83 FC35 > Spring Lake Heights, NJ > |
04-17-2006, 13:58
My 83 was built in August of 82, so it would of had the 225hp cat
originally. I was told it has a rebuilt 250 hp cat in it when I got it in 2004. Does anyone know how to tell which engine it is? Phil Olson 83FC35SB Appleton, WI --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > I also have an '83 mine was built in oct '82 and titled as an '83. > Mine is a 225HP it should be on the head covers, passenger side rear > of the cover mine also has the max RPM 2600 on it. As I understand it > they switched to 250HP late in '83 only the last 10 or 20 units of > the year, or something like that. It's a good bet it's a 225HP, but > who knows some have been changed out, and if that has happened most > likely it's a 250HP. I know it makes a diffrence on it parts you will > need to buy. Maybe someone here knows how to look at them to tell the > diffrence. > > Thanks > Bruce Campbell > 83'FCSB "Blue Skies" > > --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > > > > Hello Everyone, > > > > I'm a new owner of an 83' FC-35, manufactured in July of that year. > > How do I tell if the engine is a 225 or 250 horse turbo 3208? > > > > I was told that the coaches built in the later months in 83' had 250 > > horse engines from the factory. > > > > I have looked the engine over, read through my box of manuals, and > > checked every ID plate on the vehicle. No record anywhere. > > > > Even the previous owner had no idea! > > > > Does the Bluebird factory provide you with a build sheet if you > > request it? > > > > Any help is always appreciated! > > > > Andy Coleman > > 83 FC35 > > Spring Lake Heights, NJ > > > |
04-17-2006, 14:34
Read the valve cover tag. Arrangement number is everything on a Cat. If that
is missing you need to find the stamped numbers on the pump. That can be hard to decipher but it is possible to learn the hp of the engine from that info. I hope you have a valve cover tag. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: olson_phil To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 17, 2006 8:58 PM Subject: [WanderlodgeForum] Re: 83 FC - Is my engine 225 or 250 horse? My 83 was built in August of 82, so it would of had the 225hp cat originally. I was told it has a rebuilt 250 hp cat in it when I got it in 2004. Does anyone know how to tell which engine it is? Phil Olson 83FC35SB Appleton, WI --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > I also have an '83 mine was built in oct '82 and titled as an '83. > Mine is a 225HP it should be on the head covers, passenger side rear > of the cover mine also has the max RPM 2600 on it. As I understand it > they switched to 250HP late in '83 only the last 10 or 20 units of > the year, or something like that. It's a good bet it's a 225HP, but > who knows some have been changed out, and if that has happened most > likely it's a 250HP. I know it makes a diffrence on it parts you will > need to buy. Maybe someone here knows how to look at them to tell the > diffrence. > > Thanks > Bruce Campbell > 83'FCSB "Blue Skies" > > --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > > > > Hello Everyone, > > > > I'm a new owner of an 83' FC-35, manufactured in July of that year. > > How do I tell if the engine is a 225 or 250 horse turbo 3208? > > > > I was told that the coaches built in the later months in 83' had 250 > > horse engines from the factory. > > > > I have looked the engine over, read through my box of manuals, and > > checked every ID plate on the vehicle. No record anywhere. > > > > Even the previous owner had no idea! > > > > Does the Bluebird factory provide you with a build sheet if you > > request it? > > > > Any help is always appreciated! > > > > Andy Coleman > > 83 FC35 > > Spring Lake Heights, NJ > > > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-17-2006, 15:30
Phil when you open the doghouse, look down on the right valve cover
at the rear and you should see a stick on label about 4" long that lists the arrangement number, horsepower etc. Tom Warner Vernon Center,NY 1982 FC35 (for sale http://tinyurl.com/lotbd ) 1985 PT40 At 09:58 PM 4/17/2006, you wrote: >My 83 was built in August of 82, so it would of had the 225hp cat >originally. I was told it has a rebuilt 250 hp cat in it when I got >it in 2004. Does anyone know how to tell which engine it is? > >Phil Olson >83FC35SB >Appleton, WI > > >--- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > I also have an '83 mine was built in oct '82 and titled as an '83. > > Mine is a 225HP it should be on the head covers, passenger side rear > > of the cover mine also has the max RPM 2600 on it. As I understand it > > they switched to 250HP late in '83 only the last 10 or 20 units of > > the year, or something like that. It's a good bet it's a 225HP, but > > who knows some have been changed out, and if that has happened most > > likely it's a 250HP. I know it makes a diffrence on it parts you will > > need to buy. Maybe someone here knows how to look at them to tell the > > diffrence. > > > > Thanks > > Bruce Campbell |
04-17-2006, 18:29
Hi Tom,
I have that sticker on my motor, but it gives ratings and stats on 4 different engines available in 03 from 170 to 250 HP. It does not say specifically which one I have. All it tells me about my motor is that it was manufactured in 82. Anywhere else I can look? Andy --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > Phil when you open the doghouse, look down on the right valve cover > at the rear and you should see a stick on label about 4" long that > lists the arrangement number, horsepower etc. > > Tom Warner > Vernon Center,NY > 1982 FC35 (for sale http://tinyurl.com/lotbd ) > 1985 PT40 > > At 09:58 PM 4/17/2006, you wrote: > >My 83 was built in August of 82, so it would of had the 225hp cat > >originally. I was told it has a rebuilt 250 hp cat in it when I got > >it in 2004. Does anyone know how to tell which engine it is? > > > >Phil Olson > >83FC35SB > >Appleton, WI > > > > > >--- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > > > > I also have an '83 mine was built in oct '82 and titled as an '83. > > > Mine is a 225HP it should be on the head covers, passenger side rear > > > of the cover mine also has the max RPM 2600 on it. As I understand it > > > they switched to 250HP late in '83 only the last 10 or 20 units of > > > the year, or something like that. It's a good bet it's a 225HP, but > > > who knows some have been changed out, and if that has happened most > > > likely it's a 250HP. I know it makes a diffrence on it parts you will > > > need to buy. Maybe someone here knows how to look at them to tell the > > > diffrence. > > > > > > Thanks > > > Bruce Campbell > |
04-17-2006, 22:58
Andy isnt there a black dot near one of the HP ratings?
tom warner Vernon Center,NY At 02:29 AM 4/18/2006, you wrote: >Hi Tom, > >I have that sticker on my motor, but it gives ratings and stats on 4 >different engines available in 03 from 170 to 250 HP. It does not say >specifically which one I have. All it tells me about my motor is that >it was manufactured in 82. Anywhere else I can look? > >Andy > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner > > > > Phil when you open the doghouse, look down on the right valve cover > > at the rear and you should see a stick on label about 4" long that > > lists the arrangement number, horsepower etc. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 (for sale <http://tinyurl.com/lotbd>http://tinyurl.com/lotbd ) > > 1985 PT40 > > > > At 09:58 PM 4/17/2006, you wrote: > > >My 83 was built in August of 82, so it would of had the 225hp cat > > >originally. I was told it has a rebuilt 250 hp cat in it when I got > > >it in 2004. Does anyone know how to tell which engine it is? > > > > > >Phil Olson > > >83FC35SB > > >Appleton, WI > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > > > > > > > I also have an '83 mine was built in oct '82 and titled as an '83. > > > > Mine is a 225HP it should be on the head covers, passenger side rear > > > > of the cover mine also has the max RPM 2600 on it. As I >understand it > > > > they switched to 250HP late in '83 only the last 10 or 20 units of > > > > the year, or something like that. It's a good bet it's a 225HP, but > > > > who knows some have been changed out, and if that has happened most > > > > likely it's a 250HP. I know it makes a diffrence on it parts you >will > > > > need to buy. Maybe someone here knows how to look at them to >tell the > > > > diffrence. > > > > > > > > Thanks > > > > Bruce Campbell > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
05-01-2006, 08:34
Hello Everyone,
I was going through my box of records and came across a "Service Parts Sheet" for my 83' FC-35. It lists the engine as a 3208TA W/L. The serial No has a "Z" in it. It also has a 4.89 axle ratio. Does this help me to determine if I have a 225 or 250? I need to start ordering parts and it sure would be helpful! My 83' was built in the later part of the year. I'm hoping it is among the last 10 - 20 that came out with the 250 version. Does anybody know? Phil - did you ever find out what engine you have in your 83? Andy --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Read the valve cover tag. Arrangement number is everything on a Cat. If that is missing you need to find the stamped numbers on the pump. That can be hard to decipher but it is possible to learn the hp of the engine from that info. I hope you have a valve cover tag. > Mike Hohnstein > Germantown, WI > 83FC35 > ----- Original Message ----- > From: olson_phil > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 17, 2006 8:58 PM > Subject: [WanderlodgeForum] Re: 83 FC - Is my engine 225 or 250 horse? > > > My 83 was built in August of 82, so it would of had the 225hp cat > originally. I was told it has a rebuilt 250 hp cat in it when I got > it in 2004. Does anyone know how to tell which engine it is? > > Phil Olson > 83FC35SB > Appleton, WI > > > --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > I also have an '83 mine was built in oct '82 and titled as an '83. > > Mine is a 225HP it should be on the head covers, passenger side rear > > of the cover mine also has the max RPM 2600 on it. As I understand it > > they switched to 250HP late in '83 only the last 10 or 20 units of > > the year, or something like that. It's a good bet it's a 225HP, but > > who knows some have been changed out, and if that has happened most > > likely it's a 250HP. I know it makes a diffrence on it parts you will > > need to buy. Maybe someone here knows how to look at them to tell the > > diffrence. > > > > Thanks > > Bruce Campbell > > 83'FCSB "Blue Skies" > > > > --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > > > > > > > Hello Everyone, > > > > > > I'm a new owner of an 83' FC-35, manufactured in July of that year. > > > How do I tell if the engine is a 225 or 250 horse turbo 3208? > > > > > > I was told that the coaches built in the later months in 83' had 250 > > > horse engines from the factory. > > > > > > I have looked the engine over, read through my box of manuals, and > > > checked every ID plate on the vehicle. No record anywhere. > > > > > > Even the previous owner had no idea! > > > > > > Does the Bluebird factory provide you with a build sheet if you > > > request it? > > > > > > Any help is always appreciated! > > > > > > Andy Coleman > > > 83 FC35 > > > Spring Lake Heights, NJ > > > > > > > > > > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > |
05-01-2006, 09:27
If you have the service parts sheet, then you should have the
serial# and the arrangement# on the sheet. I say 'should' because you will want to verify this information on the valve cover tags as Mike mentioned. There's a tag on each valve cover. They each have different information, but this is the only place I know of to verify the horsepower. Parts-wise, I don't believe there's much difference between the 225 and 250. What I 'heard' (unverified) is that the turbo was introduced at 225 because of the torque converter from the 210 engine. Once the stock of old torque converters was used up, the horsepower was ramped up to 250. I dunno, wasn't there. Like Mike said, you can describe your engine 'til you're blue in the face and when you're done, the guy at CAT will say, "what's the arrangement number?" Gary Miller 83 FC 33 Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > Hello Everyone, > > I was going through my box of records and came across a "Service Parts > Sheet" for my 83' FC-35. > > It lists the engine as a 3208TA W/L. The serial No has a "Z" in it. > > It also has a 4.89 axle ratio. > > Does this help me to determine if I have a 225 or 250? I need to > start ordering parts and it sure would be helpful! > > My 83' was built in the later part of the year. I'm hoping it is > among the last 10 - 20 that came out with the 250 version. > > Does anybody know? > > Phil - did you ever find out what engine you have in your 83? > > Andy > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > Read the valve cover tag. Arrangement number is everything on a > Cat. If that is missing you need to find the stamped numbers on the > pump. That can be hard to decipher but it is possible to learn the hp > of the engine from that info. I hope you have a valve cover tag. > > Mike Hohnstein > > Germantown, WI > > 83FC35 > > ----- Original Message ----- > > From: olson_phil > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, April 17, 2006 8:58 PM > > Subject: [WanderlodgeForum] Re: 83 FC - Is my engine 225 or 250 horse? > > > > > > My 83 was built in August of 82, so it would of had the 225hp cat > > originally. I was told it has a rebuilt 250 hp cat in it when I got > > it in 2004. Does anyone know how to tell which engine it is? > > > > Phil Olson > > 83FC35SB > > Appleton, WI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > > > > I also have an '83 mine was built in oct '82 and titled as an '83. > > > Mine is a 225HP it should be on the head covers, passenger side > rear > > > of the cover mine also has the max RPM 2600 on it. As I > understand it > > > they switched to 250HP late in '83 only the last 10 or 20 units of > > > the year, or something like that. It's a good bet it's a 225HP, but > > > who knows some have been changed out, and if that has happened most > > > likely it's a 250HP. I know it makes a diffrence on it parts you > will > > > need to buy. Maybe someone here knows how to look at them to > tell the > > > diffrence. > > > > > > Thanks > > > Bruce Campbell > > > 83'FCSB "Blue Skies" > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > > > > > > > > > > Hello Everyone, > > > > > > > > I'm a new owner of an 83' FC-35, manufactured in July of that > year. > > > > How do I tell if the engine is a 225 or 250 horse turbo 3208? > > > > > > > > I was told that the coaches built in the later months in 83' > had 250 > > > > horse engines from the factory. > > > > > > > > I have looked the engine over, read through my box of manuals, and > > > > checked every ID plate on the vehicle. No record anywhere. > > > > > > > > Even the previous owner had no idea! > > > > > > > > Does the Bluebird factory provide you with a build sheet if you > > > > request it? > > > > > > > > Any help is always appreciated! > > > > > > > > Andy Coleman > > > > 83 FC35 > > > > Spring Lake Heights, NJ > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------- ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > ------------------------------------------------------------------- ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > |
05-02-2006, 07:07
I have not checked mine out yet to tell which engine it might be. I
know it came from the factory with a 225hp, but was told it was replaced with a rebuilt 250hp, but don't have any documentation on it. Getting it out of storage tonight for the summer so now I will have it at the house to play with and try to figure these things out. Just ordered a new back up camera system from rvcams.com, so that will be this weekends project. Phil Olson Appleton, WI 83FC35SB --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > Hello Everyone, > > I was going through my box of records and came across a "Service Parts > Sheet" for my 83' FC-35. > > It lists the engine as a 3208TA W/L. The serial No has a "Z" in it. > > It also has a 4.89 axle ratio. > > Does this help me to determine if I have a 225 or 250? I need to > start ordering parts and it sure would be helpful! > > My 83' was built in the later part of the year. I'm hoping it is > among the last 10 - 20 that came out with the 250 version. > > Does anybody know? > > Phil - did you ever find out what engine you have in your 83? > > Andy > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > Read the valve cover tag. Arrangement number is everything on a > Cat. If that is missing you need to find the stamped numbers on the > pump. That can be hard to decipher but it is possible to learn the hp > of the engine from that info. I hope you have a valve cover tag. > > Mike Hohnstein > > Germantown, WI > > 83FC35 > > ----- Original Message ----- > > From: olson_phil > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, April 17, 2006 8:58 PM > > Subject: [WanderlodgeForum] Re: 83 FC - Is my engine 225 or 250 horse? > > > > > > My 83 was built in August of 82, so it would of had the 225hp cat > > originally. I was told it has a rebuilt 250 hp cat in it when I got > > it in 2004. Does anyone know how to tell which engine it is? > > > > Phil Olson > > 83FC35SB > > Appleton, WI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > > > > I also have an '83 mine was built in oct '82 and titled as an '83. > > > Mine is a 225HP it should be on the head covers, passenger side > rear > > > of the cover mine also has the max RPM 2600 on it. As I > understand it > > > they switched to 250HP late in '83 only the last 10 or 20 units of > > > the year, or something like that. It's a good bet it's a 225HP, but > > > who knows some have been changed out, and if that has happened most > > > likely it's a 250HP. I know it makes a diffrence on it parts you > will > > > need to buy. Maybe someone here knows how to look at them to > tell the > > > diffrence. > > > > > > Thanks > > > Bruce Campbell > > > 83'FCSB "Blue Skies" > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > > > > > > > > > > Hello Everyone, > > > > > > > > I'm a new owner of an 83' FC-35, manufactured in July of that > year. > > > > How do I tell if the engine is a 225 or 250 horse turbo 3208? > > > > > > > > I was told that the coaches built in the later months in 83' > had 250 > > > > horse engines from the factory. > > > > > > > > I have looked the engine over, read through my box of manuals, and > > > > checked every ID plate on the vehicle. No record anywhere. > > > > > > > > Even the previous owner had no idea! > > > > > > > > Does the Bluebird factory provide you with a build sheet if you > > > > request it? > > > > > > > > Any help is always appreciated! > > > > > > > > Andy Coleman > > > > 83 FC35 > > > > Spring Lake Heights, NJ > > > > > > > > > > > > > > > > > > > > > > -------------------------------------------------------------------- ---------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > -------------------------------------------------------------------- ---------- > > > > > > > > [Non-text portions of this message have been removed] > > > |
