Allison Transmission Retarder
04-20-2006, 12:22
Living in the West, I've had occasion to drive down as much as a 14%
grade, and we're descending 5% to 7% grades regularly here. I've not seen a discussion as how to use the retarder most effectively. Nor have I any manuals describing the proper operating procedure either. I would appreciate knowing how you use yours, and think it may interest some others as well. How do you use your retarder descending mountains? Specifically, how do you regulate the retarder lever for a particular degree of descent? Do you use it on the flats as well? Other than inclement weather, when would you not use it and why? Thanks .. Ron, 85PT36, No. California |
04-20-2006, 14:33
Ron,
The trans retarder on my Bird is tied right into the brake system. When I apply the brakes, the retarder commences as well. A little brake pedal activates the retarder. The brakes are doing almost nothing at this point. Apply more brake pedal, more retarder action and a little more service brake action. Problem with retarder is it gets the trans fluid REALLY hot quick. 99% of the time, I use the brake treadle to use the retarder. Maybe 1% of the time will I engage the trans retarder via the lever. Going down steep hills- slow way down at the top, use a lower gear, and use the brakes/retarder internittently heavy. When coming down Mont Eagle(a 6-7% grade) I used 4th gear and as speed reached 45mph, I would STAND on the brakes momentarily to bring speed back down to under 40 mph. Then release brake treadle to allow monmentary cooling of brakes, drums and trans fluid. Werks good for me... Jay Darst 85PT40 w/Allison MTB654CR Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Ron & Patty" > > Living in the West, I've had occasion to drive down as much as a 14% > grade, and we're descending 5% to 7% grades regularly here. I've not > seen a discussion as how to use the retarder most effectively. Nor > have I any manuals describing the proper operating procedure either. > I would appreciate knowing how you use yours, and think it may > interest some others as well. > > How do you use your retarder descending mountains? > Specifically, how do you regulate the retarder lever for a particular > degree of descent? > Do you use it on the flats as well? > Other than inclement weather, when would you not use it and why? > Thanks .. > > Ron, 85PT36, No. California > |
04-20-2006, 14:50
Okay, I can't resist, with the jake brakes on my series 60 I come
down those 6% grades at 70. Sorry for the indulgence, I know nobody likes a braggart! LOL David Brady '02 LXi, Smokey, Va Jay Darst wrote: > Going down steep hills- slow way down at the top, use a lower gear, > and use the brakes/retarder internittently heavy. When coming down > Mont Eagle(a 6-7% grade) I used 4th gear and as speed reached 45mph, > I would STAND on the brakes momentarily to bring speed back down to > under 40 mph. Then release brake treadle to allow monmentary cooling > of brakes, drums and trans fluid. > > > > > > > > > |
04-20-2006, 17:16
Dave, as a rule I never go down a grade any faster than the average
truck speed that is making the climb up. " The faster you can stop - - the faster you can go" rule only applies when gravity is not a expotential factor. I pray for the people in your path. Randy, Does Nascar have a DownHill Class Gregory O'Connor 94pt40 Romoland California --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Okay, I can't resist, with the jake brakes on my series 60 I come > down those 6% grades at 70. Sorry for the indulgence, I know > nobody likes a braggart! LOL > > David Brady > '02 LXi, Smokey, > Va > > Jay Darst wrote: > > Going down steep hills- slow way down at the top, use a lower gear, > > and use the brakes/retarder internittently heavy. When coming down > > Mont Eagle(a 6-7% grade) I used 4th gear and as speed reached 45mph, > > I would STAND on the brakes momentarily to bring speed back down to > > under 40 mph. Then release brake treadle to allow monmentary cooling > > of brakes, drums and trans fluid. > > > > > > > > > > > > > > > > > > > |
04-20-2006, 19:33
Twice in the two years that I have owned my DD 8V92 experienced owners have
praised my choice of engine and left me with a common singular comment....... DO NOT LET IT GET AWAY FROM YOU. OK they captured my interest and I am now very careful where hills and mountains are considered. Personally I use the retarder and brakes sparingly but make sure I never exceed 45mph on the hills I encounter because I believe what the old timers have to say. I have copies of the East and West Mountain Guides and rely on them frequently. Personaly there are grades advertised in the Mountain Guides that I won't take but that is a choice everyone has to make. IMHO leave the top of the hill in 2nd (maybe 3rd) and do not worry about holding anybody up behind you. I am serious here. This is not a time to be wishy washy. This is the time to SLOW DOWN to your comfort zone and NOT WORRY ABOUT THE AUTOS BEHIND YOU. Maintain the attitude that "you are bigger" and they can "go around". I will go as far as to say you should develop a Down hill "Kiss my Ass" attitude and always travel at the same speed as the trucks. I would never take my Bird down a grade greater than 10% unless it was under a mile. This is where the Moutain Guide comes into it's own. As Greg said, you should watch the Truck Drivers. Quoting Gregory OConnor > > > > Dave, as a rule I never go down a grade any faster than the average > > truck speed that is making the climb up. " The faster you can stop - > > - the faster you can go" rule only applies when gravity is not a > > expotential factor. I pray for the people in your path. > > > > Randy, Does Nascar have a DownHill Class > > > > Gregory O'Connor > > 94pt40 > > Romoland California > > > > > > --- In WanderlodgeForum@yahoogroups.com, David Brady > > wrote: > > > > > > Okay, I can't resist, with the jake brakes on my series 60 I come > > > down those 6% grades at 70. Sorry for the indulgence, I know > > > nobody likes a braggart! LOL > > > > > > David Brady > > > '02 LXi, Smokey, > > > Va > > > > > > Jay Darst wrote: > > > > Going down steep hills- slow way down at the top, use a lower > > gear, > > > > and use the brakes/retarder internittently heavy. When coming > > down > > > > Mont Eagle(a 6-7% grade) I used 4th gear and as speed reached > > 45mph, > > > > I would STAND on the brakes momentarily to bring speed back down > > to > > > > under 40 mph. Then release brake treadle to allow monmentary > > cooling > > > > of brakes, drums and trans fluid. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > > > > Recreational vehicles > > > Wanderlodge > > > Automotive maintenance > > > > > Recreational vehicle dealer > > > Used recreational vehicles > > > Automotive radiators > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > |
04-20-2006, 19:47
Bob loomas, 85PTT35, has been driving trucks for years. I asked him about
not having any retarder coming down a mountainn. He said the same thing- slow down at the top- which for me in my 6v is quite natural- can't get over 30 going up with all my loads. and come down in 4th gear. he also stated we didn't want to over-rev the engine. This will be an interesting trip to Montana this year, unless I get the Jake to work. Ernie-83pt40 in Louisiana [Non-text portions of this message have been removed] |
04-20-2006, 19:52
Ii've come down some of those grades ttoo fastt. Scares the crap outta me ,
especially when the speedometer reads close to 80. Ernie-83pt40 in louisiana [Non-text portions of this message have been removed] |
04-21-2006, 03:24
This subject is one that I see abused all the time. There is an old saying
among truckers; "You can go down a hill many time too slow but you can only go down ONCE too fast". Those who don't pay attention to their speeds on hills will have the opportunity to see if the superior construction of the Blue Bird will allow them to survive. George Lowry "06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD Now in Stockton, CA -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of rrob@... Sent: Friday, April 21, 2006 12:33 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Allison Transmission Retarder Twice in the two years that I have owned my DD 8V92 experienced owners have praised my choice of engine and left me with a common singular comment....... DO NOT LET IT GET AWAY FROM YOU. OK they captured my interest and I am now very careful where hills and mountains are considered. Personally I use the retarder and brakes sparingly but make sure I never exceed 45mph on the hills I encounter because I believe what the old timers have to say. I have copies of the East and West Mountain Guides and rely on them frequently. Personaly there are grades advertised in the Mountain Guides that I won't take but that is a choice everyone has to make. IMHO leave the top of the hill in 2nd (maybe 3rd) and do not worry about holding anybody up behind you. I am serious here. This is not a time to be wishy washy. This is the time to SLOW DOWN to your comfort zone and NOT WORRY ABOUT THE AUTOS BEHIND YOU. Maintain the attitude that "you are bigger" and they can "go around". I will go as far as to say you should develop a Down hill "Kiss my Ass" attitude and always travel at the same speed as the trucks. I would never take my Bird down a grade greater than 10% unless it was under a mile. This is where the Moutain Guide comes into it's own. As Greg said, you should watch the Truck Drivers. |
04-21-2006, 10:22
Thanks to all for the responses. I don't know if I'm using the
retarder in the best way, but I do start out very slow from the top of a grade and set my tranny in a lower gear, but I will toggle the retarder adjustment sometimes half way to maintain a lower RPM for a particular gear. Watching the heat gauge is imperative. I also use the Trucker's Mountain Guide after we took H-155 off H-99 from Delano California to Lake Isabella. Look it up - it's one of the scariest in the book (Western Edition). Thanks again, Ron 85PT36 No. California --- In WanderlodgeForum@yahoogroups.com, "George Lowry" wrote: > > This subject is one that I see abused all the time > George Lowry > "06 Alpine Apex - Formerly '95 WBDA 4203 > Spearfish, SD Now in Stockton, CA > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of rrob@... > Sent: Friday, April 21, 2006 12:33 AM > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Re: Allison Transmission Retarder > I would never take my Bird down a grade greater > than > 10% unless it was under a mile. This is where the Moutain Guide comes into > it's own. As Greg said, you should watch the Truck Drivers. |
04-21-2006, 15:38
If you want a scary hill, check out "The Hill" going into Bella Coola in British
Columbia. "The "Hill" is still the only land route in and out of the valley. It still has it's 18% grades and switchbacks that produce a measure of terror in most newcomers, but it is traveled daily (and nightly) by all kinds of motorized vehicles, including semi-trailers." This hill is 11.2km long. Bill Ron & Patty don't know if I'm using the retarder in the best way, but I do start out very slow from the top of a grade and set my tranny in a lower gear, but I will toggle the retarder adjustment sometimes half way to maintain a lower RPM for a particular gear. Watching the heat gauge is imperative. I also use the Trucker's Mountain Guide after we took H-155 off H-99 from Delano California to Lake Isabella. Look it up - it's one of the scariest in the book (Western Edition). Thanks again, Ron 85PT36 No. California --- In WanderlodgeForum@yahoogroups.com, "George Lowry" wrote: > > This subject is one that I see abused all the time > George Lowry > "06 Alpine Apex - Formerly '95 WBDA 4203 > Spearfish, SD Now in Stockton, CA > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of rrob@... > Sent: Friday, April 21, 2006 12:33 AM > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Re: Allison Transmission Retarder > I would never take my Bird down a grade greater > than > 10% unless it was under a mile. This is where the Moutain Guide comes into > it's own. As Greg said, you should watch the Truck Drivers. --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Share your photos with the people who matter at Yahoo! Canada Photos [Non-text portions of this message have been removed] |
