alternator and inverter dc charge
04-21-2006, 05:11
David, don't feel like a newbie- i believe we aren't supposed to know about
some things.Ernie-83pt40- electrically challenged [Non-text portions of this message have been removed] |
04-21-2006, 09:07
Folks,
Maybe you can help me understand something. When the engine alternator is supplying electrical power and there's a source of 120V ac power (shore power or generator), and the house batteries require a charging current. Is the charge current coming from the inverters and the alternator or just from the alternator? If the charging current is coming from just one source, alternator or inverter, what makes that happen? For instance, if the charging current is from the alternator, is there an isolator somewhere that isolates the inverters, or do the inverters simply see a high voltage on the batteries and back off into a float charge state? Thanks, (Feel like a newbie all of a sudden) David Brady '02 LXi, Smokey Va |
04-21-2006, 10:39
David,
That's a reasonable question, sounds like the electrical sources are butting heads to charge the battery, doesn't it? The alternator has several poles in the stator windings that produce several cycles per revolution each slightly out-of-phase. This AC voltage is flattened out to a DC voltage by the use of a full-wave bridge rectifier then regulated to output a nominal 14.5 VDC. The alternator is not a smart charger so it tries to maintain the 14.5 volts DC and will unless the engine speed is reduced. Except for wire, the alternator post, positive battery terminal, and charger output terminal are at the same electrical potential, 14.5 VDC. The smart charger senses this voltage at the door, and, realizing a no work period, rolls over and goes back to sleep. Now if the engine stops, the alternator is on break. Provided the genset is running, it's time to go to work bringing the battery voltage to pre-defined set-points. A converter changes AC to DC, an inverter changes DC to AC. The word converter and charger are synonymous so what you have is a inverter/converter combination. Hope this answered your question. Bob Janes 77 FC 31 Greenville, SC --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Folks, > > Maybe you can help me understand something. When the > engine alternator is supplying electrical power and there's > a source of 120V ac power (shore power or generator), > and the house batteries require a charging current. Is the > charge current coming from the inverters and the alternator > or just from the alternator? If the charging current is coming > from just one source, alternator or inverter, what makes that > happen? For instance, if the charging current is from the > alternator, is there an isolator somewhere that isolates the > inverters, or do the inverters simply see a high voltage on > the batteries and back off into a float charge state? > > Thanks, (Feel like a newbie all of a sudden) > David Brady > '02 LXi, Smokey > Va > |
04-21-2006, 11:10
Thanks Bob, crystal clear.
David '02 LXi, Smokey, Va one_dusty_hoot wrote: > David, > That's a reasonable question, sounds like the electrical > sources are butting heads to charge the battery, doesn't it? > > > |
