Wet Carpet
04-22-2006, 02:59
Wet Carpet
Ernie Checked water pump,no leak at the pump.Found a steady one drop
at a time leak at the accumeleter(i think thats right). Ralph I did remove the kick plate it does not seem to be the tank.It's a long way from the accumeleter to the switch for the hot water.Water travels in a strange way ? Can I bypass the accumeleter for a few days to check if that's the problem. I'm at 516 967 0913 L.I. New York.Would like to speak more about this problem..Thanks so much Mario 1985 FC 35 |
