New Member
04-13-2005, 13:25
New Member
Hi Ernie,
Had to support you in this venture!! Bob,Dixie & Harley 92 WBSA (Black and Stainless) Jefferson,NC |
04-14-2005, 10:48
New Member
Mike- glad you are here. Just start asking away! Ernie-83PT40 in Texas
[Non-text portions of this message have been removed] |
04-14-2005, 14:44
New Member
Ernie: I just joined the group, i am mainly a lurker waiting to buy but
learning alot about bluebirds. Mike Sickles |
03-11-2007, 14:34
New Member
Hello group. My name is Jimmy Harvie, a new member. I purchased an 82 FC35, last
week. It's in great shape, been sitting for a few years. I have a few minor problems to address, (sucking some air in the fuel, small leak under the air filter. It may be the governor seals, in the pump, I haven't taken off the air filter housing yet) Michelin xza's all around, 1124.5. They look brand new, no dry rot, but the production date on the rears are 390, so I'm going to replace those. I have repaired a lot of other things already, thanks to all of your help on this forum. I have 30 years of diesel expierience, (UPS Journeyman/ Penske tech1.Plenty of expierience on Detroit 71/92/series60-DDECV Mack Factory training. I hope I can help anyone that needs it I'm planning on heading to Fla in a few weeks,(I'm just west of Boston), looking forward to meeting bird owners thanks.( Curt, not sure if this will help, but those 92 series had a restricted fitting, somewhere on the return side of the system,That fitting influences pump pressure. Just a thought, did you use all of the old fittings, when you replaced the pump?, I haven't seen too many problems with those 2 stroke pumps, most of the time, they're good for the life of the engine, --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. [Non-text portions of this message have been removed] |
03-11-2007, 15:49
New Member
James,
Welcome to the forum! Thank you for your input about the restriction fitting. I know where it is, at the start of the hard line return to the fuel tank. I can remove it, and I expect to find a small hole in it which should be good to go. Is there something else about the fitting that I should be aware of? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. James Harvie wrote: > Hello group. My name is Jimmy Harvie, a new member. I purchased an 82 > FC35, last week. It's in great shape, been sitting for a few years. I > have a few minor problems to address, (sucking some air in the fuel, > small leak under the air filter. It may be the governor seals, in the > pump, I haven't taken off the air filter housing yet) Michelin xza's > all around, 1124.5. They look brand new, no dry rot, but the > production date on the rears are 390, so I'm going to replace those. I > have repaired a lot of other things already, thanks to all of your > help on this forum. I have 30 years of diesel expierience, (UPS > Journeyman/ Penske tech1.Plenty of expierience on Detroit > 71/92/series60-DDECV Mack Factory training. I hope I can help anyone > that needs it I'm planning on heading to Fla in a few weeks,(I'm just > west of Boston), looking forward to meeting bird owners thanks.( Curt, > not sure if this will help, but those 92 series had a restricted > fitting, somewhere on the return side of the > system,That fitting influences pump pressure. Just a thought, did you > use all of the old fittings, when you replaced the pump?, I haven't > seen too many problems with those 2 stroke pumps, most of the time, > they're good for the life of the engine, > > --------------------------------- > TV dinner still cooling? > Check out "Tonight's Picks" on Yahoo! TV. > > [Non-text portions of this message have been removed] > > |
03-11-2007, 16:24
New Member
Curt, nothing more to know about the fitting, It's a fixed restriction,with no
adjustments.I thought I'd pass the thought to you seeing as you may have removed them, when you replaced the parts. The idea of isolating the fuel system, by running the lines into a gallon of diesel was a good one. not to get ahead of things but after looking at the areoquip fuel lines on the one I just bought, I'd say it's possible that some of the rubber hose that lines the inside could desinergrate causing a blockage. One other idea would be to make up a clear hose, add that inline and you can watch for air bubbles. I do know those tiny fuel pumps won't suck one drop if they're not primed but once they are, they'll blow fuel from here to the Moon Curt Sprenger Welcome to the forum! Thank you for your input about the restriction fitting. I know where it is, at the start of the hard line return to the fuel tank. I can remove it, and I expect to find a small hole in it which should be good to go. Is there something else about the fitting that I should be aware of? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. James Harvie wrote: > Hello group. My name is Jimmy Harvie, a new member. I purchased an 82 > FC35, last week. It's in great shape, been sitting for a few years. I > have a few minor problems to address, (sucking some air in the fuel, > small leak under the air filter. It may be the governor seals, in the > pump, I haven't taken off the air filter housing yet) Michelin xza's > all around, 1124.5. They look brand new, no dry rot, but the > production date on the rears are 390, so I'm going to replace those. I > have repaired a lot of other things already, thanks to all of your > help on this forum. I have 30 years of diesel expierience, (UPS > Journeyman/ Penske tech1.Plenty of expierience on Detroit > 71/92/series60-DDECV Mack Factory training. I hope I can help anyone > that needs it I'm planning on heading to Fla in a few weeks,(I'm just > west of Boston), looking forward to meeting bird owners thanks.( Curt, > not sure if this will help, but those 92 series had a restricted > fitting, somewhere on the return side of the > system,That fitting influences pump pressure. Just a thought, did you > use all of the old fittings, when you replaced the pump?, I haven't > seen too many problems with those 2 stroke pumps, most of the time, > they're good for the life of the engine, > > --------------------------------- > TV dinner still cooling? > Check out "Tonight's Picks" on Yahoo! TV. > > [Non-text portions of this message have been removed] > > --------------------------------- It's here! Your new message! Get new email alerts with the free Yahoo! Toolbar. [Non-text portions of this message have been removed] |
03-11-2007, 16:26
New Member
Welcome to the forum. Since you have a lot of experience with DD and DDEC, I
have a ton of questions. I am not in a hurry, all systems are go, but when you get time please e-mail me at http://www.jwasneski@... Leroy Eckert 1990 WB-40"Smoke N Mirrors' Niceville, Fl ----- Original Message ----- From: James Harvie To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 11, 2007 8:34 PM Subject: [WanderlodgeForum] New member Hello group. My name is Jimmy Harvie, a new member. I purchased an 82 FC35, last week. It's in great shape, been sitting for a few years. I have a few minor problems to address, (sucking some air in the fuel, small leak under the air filter. It may be the governor seals, in the pump, I haven't taken off the air filter housing yet) Michelin xza's all around, 1124.5. They look brand new, no dry rot, but the production date on the rears are 390, so I'm going to replace those. I have repaired a lot of other things already, thanks to all of your help on this forum. I have 30 years of diesel expierience, (UPS Journeyman/ Penske tech1.Plenty of expierience on Detroit 71/92/series60-DDECV Mack Factory training. I hope I can help anyone that needs it I'm planning on heading to Fla in a few weeks,(I'm just west of Boston), looking forward to meeting bird owners thanks.( Curt, not sure if this will help, but those 92 series had a restricted fitting, somewhere on the return side of the system,That fitting influences pump pressure. Just a thought, did you use all of the old fittings, when you replaced the pump?, I haven't seen too many problems with those 2 stroke pumps, most of the time, they're good for the life of the engine, --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
03-12-2007, 01:21
New Member
James- welcome to the group. Whose coach did you purchase?
Ernie Ekberg 83PT40 Livingston,Montana "POO-DOO-EXPRESS" ----- Original Message ----- From: James Harvie To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 11, 2007 6:34 PM Subject: [WanderlodgeForum] New member Hello group. My name is Jimmy Harvie, a new member. I purchased an 82 FC35, last week. It's in great shape, been sitting for a few years. I have a few minor problems to address, (sucking some air in the fuel, small leak under the air filter. It may be the governor seals, in the pump, I haven't taken off the air filter housing yet) Michelin xza's all around, 1124.5. They look brand new, no dry rot, but the production date on the rears are 390, so I'm going to replace those. I have repaired a lot of other things already, thanks to all of your help on this forum. I have 30 years of diesel expierience, (UPS Journeyman/ Penske tech1.Plenty of expierience on Detroit 71/92/series60-DDECV Mack Factory training. I hope I can help anyone that needs it I'm planning on heading to Fla in a few weeks,(I'm just west of Boston), looking forward to meeting bird owners thanks.( Curt, not sure if this will help, but those 92 series had a restricted fitting, somewhere on the return side of the system,That fitting influences pump pressure. Just a thought, did you use all of the old fittings, when you replaced the pump?, I haven't seen too many problems with those 2 stroke pumps, most of the time, they're good for the life of the engine, --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
03-12-2007, 16:44
New Member
Ernie The name next to the door says Fred and Louise Staiger. Not sure who they
are, or where they are from though. I bought this from a dealer in NH. It was on consignment. I'm either the third or fourth owner I believe. The FMCA# on the plate is 22658. So far from what I've checked, everything seems to be there, except for the side awning. It dosen't have the instant hot water dispenser but I may put one in. It has the ice maker, with looks to be an inverter over the passengers head. I may update my alternator (get rid of that 160 amp Motorola), and go with a Delco 320 amp, maybe change the inverterto 3500 watts, so I can run the ice maker, the hot water dispenser and one roof a/c going down the road without having to run the generator. It has 4 electric fans on the engine radiator. I thought this was stock untill I got it home, climbed on the roof, opened the rear storage pod and found a hub with an electric clutch a fan blade with the shaft missing and a shroud. I figured it out. It has the swing radiator, new belts/ hoses .along with a spare set of belts, and a complete set of spare filters for both the main engine and th generator ( Kohler 12.5- 600 hrs) I also got the screen house that you add water too. Had an exhust leak, I installed a new muffler, and although the tailpipe was recent I had a 5" chrome set of stacks off an old Peterbuilt, that was in good shape, so I threw one on for my tailpipe.This is my first motorhome, and although I have always thought about buying one I thought about this deal for about 20 minutes and snagged it. Today I started buffing it out, the paint's comming back like it's new. Ok I don't want to flood the forum too much, but I'm like a kid in a candy store, right now. Oh one more thing. I got what I'll say the main blue print ( it's one sheet covered in hard see through plastic), but I also got about 40 other detailed blueprints about 3'x5' in size, Did these come with the coach, or were these copied later? ernieekberg@... wrote: James- welcome to the group. Whose coach did you purchase? Ernie Ekberg 83PT40 Livingston,Montana "POO-DOO-EXPRESS" ----- Original Message ----- From: James Harvie To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 11, 2007 6:34 PM Subject: [WanderlodgeForum] New member Hello group. My name is Jimmy Harvie, a new member. I purchased an 82 FC35, last week. It's in great shape, been sitting for a few years. I have a few minor problems to address, (sucking some air in the fuel, small leak under the air filter. It may be the governor seals, in the pump, I haven't taken off the air filter housing yet) Michelin xza's all around, 1124.5. They look brand new, no dry rot, but the production date on the rears are 390, so I'm going to replace those. I have repaired a lot of other things already, thanks to all of your help on this forum. I have 30 years of diesel expierience, (UPS Journeyman/ Penske tech1.Plenty of expierience on Detroit 71/92/series60-DDECV Mack Factory training. I hope I can help anyone that needs it I'm planning on heading to Fla in a few weeks,(I'm just west of Boston), looking forward to meeting bird owners thanks.( Curt, not sure if this will help, but those 92 series had a restricted fitting, somewhere on the return side of the system,That fitting influences pump pressure. Just a thought, did you use all of the old fittings, when you replaced the pump?, I haven't seen too many problems with those 2 stroke pumps, most of the time, they're good for the life of the engine, --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] --------------------------------- Now that's room service! Choose from over 150,000 hotels in 45,000 destinations on Yahoo! Travel to find your fit. [Non-text portions of this message have been removed] |
06-10-2007, 02:29
New Member
Hi to all-
A few of you in South Florida know me, thought I'd make myself available online. Eric LaCruze ASE Master Truck tech |
