We made it home with our Bird -now I have a few tech. questions.
04-27-2006, 14:43
We flew into Minneapolis last Thursday and picked up the 1984 35SB
that we had bought in Dec. Drove it straight back to Northern CA right at 2000 miles. It ran great all the way,checked the fuel milage once,Des Moines Ia to Evanston WY 1000 miles with several 7000ft passes we got 8.46mpg. Several problems showed up and I could use some advice We cannot get any water flow from the hot side of any faucet,also both L & R wipers work fine but the mist control only works on the right side (Pass side) Thanks Jim & Wanda Matus Rescue CA 1984 35SB |
04-28-2006, 09:47
--- In WanderlodgeForum@yahoogroups.com, "jim matus"
> > We flew into Minneapolis last Thursday and picked up the 1984 35SB > that we had bought in Dec. Drove it straight back to Northern CA right > at 2000 miles. It ran great all the way,checked the fuel milage > once,Des Moines Ia to Evanston WY 1000 miles with several 7000ft passes > we got 8.46mpg. Several problems showed up and I could use some advice > We cannot get any water flow from the hot side of any faucet,also both > L & R wipers work fine but the mist control only works on the right > side (Pass side) Thanks Jim & Wanda Matus Rescue CA 1984 35SB Did you check the hot water tank? inflow value drain value closed? the mister is problably clogged take the rubber hose off and put a thin wire ti clearout the value sounds like you have a good rig if thats all the problems so far! guy smalley 86 pt 40 > |
04-28-2006, 10:08
Jim,
The minnie black hose on the mister could be disconnected, behind the panel, Sounds like something was done to shut the water off at the hotwater tank. These old hotwater tanks leak, I am guessing a new hotwater tank. Sounds like it runs great, These are minor repair problems. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "jim matus" wrote: > > We flew into Minneapolis last Thursday and picked up the 1984 35SB > that we had bought in Dec. Drove it straight back to Northern CA right > at 2000 miles. It ran great all the way,checked the fuel milage > once,Des Moines Ia to Evanston WY 1000 miles with several 7000ft passes > we got 8.46mpg. Several problems showed up and I could use some advice > We cannot get any water flow from the hot side of any faucet,also both > L & R wipers work fine but the mist control only works on the right > side (Pass side) Thanks Jim & Wanda Matus Rescue CA 1984 35SB > |
04-28-2006, 13:50
--- In WanderlodgeForum@yahoogroups.com, "guysmalley"
> > --- In WanderlodgeForum@yahoogroups.com, "jim matus" wrote: > > > > We flew into Minneapolis last Thursday and picked up the 1984 35SB > > that we had bought in Dec. Drove it straight back to Northern CA right > > at 2000 miles. It ran great all the way,checked the fuel milage > > once,Des Moines Ia to Evanston WY 1000 miles with several 7000ft passes > > we got 8.46mpg. Several problems showed up and I could use some advice > > We cannot get any water flow from the hot side of any faucet,also both > > L & R wipers work fine but the mist control only works on the right > > side (Pass side) Thanks Jim & Wanda Matus Rescue CA 1984 35SB > > Did you check the hot water tank? inflow value drain value closed? > the mister is problably clogged take the rubber hose off and put a thin wire ti clearout the > value > > sounds like you have a good rig if thats all the problems so far! > > guy smalley > 86 pt 40 > > I cycled the air operated drain valve several times no water runs out under the coach,also i manually opened the T & P safety valve on the hot water heater with the 12v water pump on and no water came out. The wiper problem is the intermittent system not the washers. Are they electric or are these air operated so they have hoses to them. Jim Matus FC35SB RescueCA |
04-28-2006, 14:31
Jim: What year is your Coach?
At the bottom of the water heater, input side, there is a valve. This valve is a 3 way with an air line going to it. It is part of the air blow out for winterizing. It is known to stick in the "drain" position. On the end of the valve facing toward the front of the Coach, remove the 4 screws holding the end cap on. Be careful as there may be a return spring located there. With the end cap off, you should see the end of the shuttle, this is the part that is suck. With a pair of needle nose pliers, pull on the end of the shuttle until it moves toward the front of the Coach. Replace the end cap and try the hot water once again. I have taken those valves apart, cleaned and lubed them and return them to service ready to go. It is a PITA to remove the valve though. The wiper delay is a PMMI control. You can get in touch with Doug Hampton of PMMI and see if they are doing any repair on that system. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:50 AM 4/29/2006 +0000, you wrote: >--- In WanderlodgeForum@yahoogroups.com, "guysmalley" > > > > > --- In WanderlodgeForum@yahoogroups.com, "jim matus" >wrote: > > > > > > We flew into Minneapolis last Thursday and picked up the 1984 >35SB > > > that we had bought in Dec. Drove it straight back to Northern CA >right > > > at 2000 miles. It ran great all the way,checked the fuel milage > > > once,Des Moines Ia to Evanston WY 1000 miles with several 7000ft >passes > > > we got 8.46mpg. Several problems showed up and I could use some >advice > > > We cannot get any water flow from the hot side of any >faucet,also both > > > L & R wipers work fine but the mist control only works on the >right > > > side (Pass side) Thanks Jim & Wanda Matus Rescue CA 1984 35SB > > > > Did you check the hot water tank? inflow value drain value closed? > > the mister is problably clogged take the rubber hose off and put a >thin wire ti clearout the > > value > > > > sounds like you have a good rig if thats all the problems so far! > > > > guy smalley > > 86 pt 40 > > > >I cycled the air operated drain valve several times no water runs >out under the coach,also i manually opened the T & P safety valve on >the hot water heater with the 12v water pump on and no water came >out. The wiper problem is the intermittent system not the washers. >Are they electric or are these air operated so they have hoses to >them. > Jim Matus FC35SB RescueCA > > > |
04-30-2006, 17:21
> > Jim: What year is your Coach? > > At the bottom of the water heater, input side, there is a valve. This valve > is a 3 way with an air line going to it. It is part of the air blow out for > winterizing. It is known to stick in the "drain" position. On the end of > the valve facing toward the front of the Coach, remove the 4 screws holding > the end cap on. Be careful as there may be a return spring located there. > With the end cap off, you should see the end of the shuttle, this is the > part that is suck. With a pair of needle nose pliers, pull on the end of > the shuttle until it moves toward the front of the Coach. Replace the end > cap and try the hot water once again. I have taken those valves apart, > cleaned and lubed them and return them to service ready to go. It is a PITA > to remove the valve though. > > The wiper delay is a PMMI control. You can get in touch with Doug Hampton > of PMMI and see if they are doing any repair on that system. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > RALPH you were right on about the shuttle valve being stuck.I pulled off the actuator housing and got it to move. Thanks for the good advice and your right I wouldn't want to remove the whole valve assy. unless I had to. Jim Matus FC35SB Rescue CA > > > > > > > > > > > |
