Hot Water Tank Flushout
04-30-2006, 10:35
Since the wife was stripping the bed I decided to remove the mattress and
unscrew the plywood covering the hot water heater and flush it out. This heater is a year old (Force 10 Eleven Gal) and I figured this was a good time and should probably be an annual event. Since it drains under the coach I couldn't see if there was any crude in it but if my previous RVs are any indication then I'm sure there had to be some. [Non-text portions of this message have been removed] |
