Temperature sensor thread size
04-30-2006, 11:40
I fired up the bus today and the engine coolant temperature gauge went up to
240F almost immediately. I shut down the bus and found that the oil was still
cold as were the radiator and the hoses.
I tested the sensor wire from the gauge to the sender and seems to be ok. The
gauge seems to be alright so I think I will swap out the sender next, it was
also cool to the touch.
The gauge is a Teleflex unit and the senders seem to be available at most
marine supply stores; I just didn't check what pipe thread size it was. Any help
would be appreciated.
Tim Hannink
Winter Park, FL
1981 FC-33SB
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+
countries) for 2¢/min or less.
