94pt40 taillight relay upgrade
05-03-2006, 17:13
The tail lights on my 94 pt40 were so dim motorist would stop me or
use 'single digit' sign language to protest my failure to warn of a stop or turn. When I checked the lights at each function, all was OK but not par. I later learned that using both turn and brakes would reduce the light to a warm glow. The 94 uses a Volvo taillight assembly and the wire loom and pigtails that plug into the assembly are Bluebird. The assembly uses a galvanized steel circuit board in place of wires. the board connect to the loom with tiny galvanized tabs that got weathered and reduced to pins. The Volvo car that uses this taillight stores the assembly guts in its trunk whereas the bus exposes the assembly to the engine compartment. The 8 pins for the 4 units are individually plugged in. All wires in the loom had a black tarnish between strands further causing resistance and amp loss. I contacted a forum member - Curt S for help with the dim situation. He directed me to drive the bus to his house on a Saturday morning and quickly; reviewed the problem; repaired some crossed 8 pin connections; and designed a new relay fuse panel. With a new loom and taillight assemblies the relays are not necessary. But I didn't want to replace the wires all the way to the cockpit and the relays will help power my trailers. http://tinyurl.com/kguv3 or look in photos "miscellaneous " Curt designed the relay panel to mount behind the fuel filter but I dropped it below the false floor in the bedroom closet. I worked in the closet, bent over until I got a brokeback from all the splicing and screwing. The closet location will further protect the wire connections and relays from weather. All splices in the taillight loom are soldered and shrink tube wrapped. I globbed a semi solid rubber compound around the 8 pin connection at the light assemblies. Wires will have to be cut if the assembly is to be replaced because I did not want to complicate the install for a repair that wont happen if the connections are permanently sealed from weather. How these relays work. The relays are remote switches that take the juice from the batteries in the back of the bus and power the lights also in the back. As it was, power went 40 feet from the batteries to the cockpit then 40 feet back to the taillights. That 80 plus feet of wire has resistance and you lose amps which are required to make the lights bright. Now the turn signal lever in the cockpit sends a signal to the relay-switch in the rear closet (low amp required for this function), that relay-switch takes power from the batteries in the back and sends the power direct to the tail light with just 8 feet of wire (less resistance = more available amps). Thank you Curt for showing me the light Gregory O'Connor 94pt40 Romoland California |
