Generator Relay?
05-08-2006, 11:50
Generator Relay?
We are having a problem finding the right starter relay for our Perkins
Kohler 12.5, it would cause the starter to chatter and not get full
power so we removed it to find a replacement. We where able to get
other relays from the box but not the starter relay,(center one of
three on back side of box) the suppler says it is a 6 volt unit and is
not available, it has been back ordered for over a month and told us
today it is not likely to ever come. Why or how is this a 6 volt relay
when the rest are 12 volt and easy to get, the Kohler repare company
said to buy a new controler because the one we have is to old to get
parts for. The generator starts fine if you jump the starter but does
nothing now with the old relay back in. Does anyone know where to
possibly get this relay or did someone put the wrong one in before we
became the owners.
The relay is a Portter&Brumfield #KUP14D55 6volt dc
Thankyou very much for any help!
Michelle and Jeff August
1980FC35RB
Plymouth Wi
05-08-2006, 12:04
Generator Relay?
Is the name Potter&Brumfield, not Portter. On the net there are Potter &
Brumfiled #KUP14D55 listed as 12 volt. Do a search on Potter & Brumfield
#KUP14D55 and you will get replies. Could be your parts guy has a problem.
> became the owners.
> 1980FC35RB
> Plymouth Wi
> SPONSORED LINKS
> Recreational vehicles
<http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\
les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\
onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\
c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>
> Recreational vehicle financing
<http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\
nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\
=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\
cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>
> Recreational vehicle repair
<http://groups.yahoo.com/gads?t=ms&k=Recr...ional\
+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\
creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\
+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>
> Recreational vehicle rental
+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>
> Recreational vehicle camper
+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>
> Recreational vehicle rate
<http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\
ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\
eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\
ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>
> YAHOO! GROUPS LINKS
> * Visit your group "WanderlodgeForum
> <http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
05-08-2006, 12:21
Generator Relay?
Update...I also found #KUP14D55 in what I think is a 6 volt. I'll spend
some time trying to get to the supplier for you. This site I found it on
I can not get in because I don't have an account number. More later, maybe.
> > became the owners.
> > 1980FC35RB
> > Plymouth Wi
> > SPONSORED LINKS
c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>>
cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>>
+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>>
+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>>
+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>>
ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>>
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
> YAHOO! GROUPS LINKS
05-08-2006, 12:27
Generator Relay?
More....
Try this...netCOMPONENTS, Inc. Delray Beach, FL 561-274-6780. Let us
know if this helped.
> maybe.
> problem.
> Perkins
> > > became the owners.
> > > 1980FC35RB
> > > Plymouth Wi
> > > SPONSORED LINKS
c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>>>
cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>>>
+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>>>
+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>>>
+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>>>
ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>>>
> > > YAHOO! GROUPS LINKS
> > SPONSORED LINKS
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
> YAHOO! GROUPS LINKS
05-08-2006, 12:37
Generator Relay?
More
Try http://www.usbid.com/catalog7/page.cfm/16605. They list that number
in many voltages including 6 volt.
> More....
> > maybe.
> Potter &
> Brumfield
> > problem.
> > Perkins
> and is
> relay
> does
> before we
> > > > became the owners.
> > > > 1980FC35RB
> > > > Plymouth Wi
> > > > SPONSORED LINKS
c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>>>>
cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>>>>
+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>>>>
+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>>>>
+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>>>>
ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>>>>
> > > > YAHOO! GROUPS LINKS
> > > SPONSORED LINKS
> > > YAHOO! GROUPS LINKS
> > SPONSORED LINKS
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
<[url]http:/
05-08-2006, 13:38
Generator Relay?
Jeff you have a 120VAC relay in the control box and it is a Potter
Brumfield KUP14A55-120 (digikey # PB164-ND and costs $12.19. It is
NOT a 6 volt one. This relay is activated when the generator starts
putting out voltage. Open up your control box (top cover is in two
pieces)and look on the back wall of it and give me the control
number, might be faint so show a bright light on it. It should look
something like thisA259972 (this is my control box for a 1982 FC35 BB
with a Kohler generator.). Take a look at the control box I rebuilt
at http://tinyurl.com/hefmm.
The control box is really quite simple and if you are good at
soldering and following a schematic I would upgrade it to a control
box of the 1985 FC models. That eliminates a lot of problems.
As far as replacing the 12.5KW Kohler generator with something more
"modern". I would not for you will be getting a generator that is not
as robust or as reliable. The 12.5KW Kohler generator is an
industrial generator that is designed to run 24/7 for long periods of
time with only preventative maintenance of oil and filters. The
generator portion itself is older technology but I would run it until
it gives out and then replace it with a New Age Stamford solid state
generator that costs about $1000 and connect it to the Perkins
diesel. The Perkins diesel is a wet sleeve engine that can be
rebuilt back to as new condition indefinetely unlike anything that
you will replace it with.
If you need help trouble shooting your control circuits or getting
the relays (which cost a total of about $15.) give me a email off forum.
Tom Warner
Vernon Center,NY
1985 PT 40
>became the owners.
>1980FC35RB
>Plymouth Wi
05-08-2006, 22:51
Generator Relay?
Thanks Curt and Tom, I will see what I can figure out after work
tonight.
Jeff
BB
rebuilt
not
of
until
state
forum.
> Tom Warner
> Vernon Center,NY
> 1985 PT 40
Perkins
and is
us
relay
company
get
does
we
> >became the owners.
> >1980FC35RB
> >Plymouth Wi
