Gen water temp guage fuse
05-09-2006, 08:43
Anybody know if there is a fuse between the generator water temp
sender and the co-pilot guage on the 85PT40?
The guage worked normally in previous operation, and quit showing the
temp reading after the last startup. I don't want to start replacing
parts until I've checked the obvious.
Thanks,
Phil
85PT40
Left Coast-Central
overcast (June gloom early)
05-09-2006, 08:51
First thing to check is the connection on the sender. Ground the wire
to see what the gauge does.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "iwander_85pt40"
replacing
> Thanks,
> Phil
> 85PT40
> Left Coast-Central
05-10-2006, 06:08
Engine cold, sending unit wire disconnected: 12 volts thru a
voltmeter->wire to ground; no resistance->sender terminal to ground;
guage pegs far right when terminal wire grounded.
Engine at operating temperature (half hour+ run), sending unit wire
disconnected: no voltage thru voltmeter (wire was connected to
sending unit during warmup); no resistance->sender terminal to ground;
guage does not move when terminal wire grounded.
There is a jumper wire from the oil pressure guage to water temp guage
that I assume is 12 volts(I haven't tested it). The oil pressure
guage operation is normal.
Phil
85PT40
Left Coast-Central
> - Jeff Miller
> in Holland, MI
> the
> replacing
> > Thanks,
> > Phil
> > 85PT40
> > Left Coast-Central
05-10-2006, 06:44
Phil,
Teleflex has a great troubleshooting guide,
Go to
http://ww2.tflx.com/ then tech support.
Most of the gages in the BB are on this web site.
This will guide you through the circuit until you find the problem
Sounds like a sensor or ground wire.
BIll 88 FC Michigan
ground;
ground;
guage
> Phil
> 85PT40
> Left Coast-Central
wire
> > - Jeff Miller
> > in Holland, MI
temp
showing
> > the
> > replacing
> > > Thanks,
> > > Phil
> > > 85PT40
> > > Left Coast-Central
05-10-2006, 07:27
Thanks, Bill
Great website. Took a quick look and saw three issues I have to
check/fix before I proceed. All affect the readings I'm getting.
Phil
85PT40
--- In WanderlodgeForum@yahoogroups.com, "pattypape"
> Phil,
> Go to
> BIll 88 FC Michigan
> ground;
> ground;
> guage
> > Phil
> > 85PT40
> > Left Coast-Central
> wire
> > > - Jeff Miller
> > > in Holland, MI
> temp
> showing
> > > the
> > > replacing
> > > > Thanks,
> > > > Phil
> > > > 85PT40
> > > > Left Coast-Central
