Need Help With 12 Volt Water System...
05-12-2006, 07:02
I also had my outside switch go bad. Don't know why it went bad- just 23
years old. I was forrever hunting down that probleem. Erniie-83pt40 in Texas [Non-text portions of this message have been removed] |
05-12-2006, 09:26
My water pump runs and pumps water, but very slowly. I could not find
any leaks or lose connections. It seems like the pump does not prime it's self for some reason. The pump will run constantly. I'm digging into it now. Does anyone have any advice to offer? Thanks in advance. James 78FC33SB Kingman AZ (But not for long) |
05-12-2006, 09:39
A couple thoughts. Does your Bird have the 12v water tank fill switch
that controls a Sporlan valve...that switch might be set to 'fill' and should be set to 'off'...or the Sporlan valve is filled with junk and needs to be cleaned out. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. orbitalsolutions wrote: > My water pump runs and pumps water, but very slowly. I could not find > any leaks or lose connections. It seems like the pump does not prime > it's self for some reason. The pump will run constantly. > > I'm digging into it now. Does anyone have any advice to offer? > > Thanks in advance. > > > James > 78FC33SB > Kingman AZ (But not for long) > > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
05-12-2006, 09:54
Thanks for the reply, Curt.
I don't think it's a switch as it has worked properly for a long time and I have not thrown any switches or turned any valves. What I have discovered is that when I run the pump water begins to exit out ot the water tank over flow. I do not know what a Sporland valve is, however something being fouled by junk is a possibility. Could you expand on your thoughts for me so I can look for that valve? Thanks. James 78FC33SB Kingman AZ --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > A couple thoughts. Does your Bird have the 12v water tank fill switch > that controls a Sporlan valve...that switch might be set to 'fill' and > should be set to 'off'...or the Sporlan valve is filled with junk and > needs to be cleaned out. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > orbitalsolutions wrote: > > > My water pump runs and pumps water, but very slowly. I could not find > > any leaks or lose connections. It seems like the pump does not prime > > it's self for some reason. The pump will run constantly. > > > > I'm digging into it now. Does anyone have any advice to offer? > > > > Thanks in advance. > > > > > > James > > 78FC33SB > > Kingman AZ (But not for long) > > > > > > > > > > > > > > ----------------------------------------------------------------- ------- > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ----------------------------------------------------------------- ------- > > > |
05-12-2006, 10:08
James,
A Sporlan valve is a 12V flow control valve. From what you have said I don't believe you have that valve in your coach. Let me think about what you have said. If I come up with something more I'll get back to you. Good luck! Enjoy your trip East. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. orbitalsolutions wrote: > Thanks for the reply, Curt. > > I don't think it's a switch as it has worked properly for a long > time and I have not thrown any switches or turned any valves. > > What I have discovered is that when I run the pump water begins to > exit out ot the water tank over flow. > > I do not know what a Sporland valve is, however something being > fouled by junk is a possibility. > > Could you expand on your thoughts for me so I can look for that > valve? > > Thanks. > > > James > 78FC33SB > Kingman AZ > |
05-12-2006, 10:12
Here's another thing...
When I put city water into the commercial intake, water immediately starts to run out of the water tank overflow. I may be wrong but the over flow appears to come out of the hot water tank. Does that make any sense? James 78FC33SB Kingman AZ --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Thanks for the reply, Curt. > > I don't think it's a switch as it has worked properly for a long > time and I have not thrown any switches or turned any valves. > > What I have discovered is that when I run the pump water begins to > exit out ot the water tank over flow. > > I do not know what a Sporland valve is, however something being > fouled by junk is a possibility. > > Could you expand on your thoughts for me so I can look for that > valve? > > Thanks. > > > James > 78FC33SB > Kingman AZ > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > A couple thoughts. Does your Bird have the 12v water tank fill > switch > > that controls a Sporlan valve...that switch might be set to 'fill' > and > > should be set to 'off'...or the Sporlan valve is filled with junk > and > > needs to be cleaned out. > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > orbitalsolutions wrote: > > > > > My water pump runs and pumps water, but very slowly. I could > not find > > > any leaks or lose connections. It seems like the pump does not > prime > > > it's self for some reason. The pump will run constantly. > > > > > > I'm digging into it now. Does anyone have any advice to offer? > > > > > > Thanks in advance. > > > > > > > > > James > > > 78FC33SB > > > Kingman AZ (But not for long) > > > > > > > > > > > > > > > > > > > > > --------------------------------------------------------------- -- > ------- > > > YAHOO! GROUPS LINKS > > > > > > * Visit your group "WanderlodgeForum > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the > web. > > > > > > * To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms > of > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > --------------------------------------------------------------- -- > ------- > > > > > > |
05-12-2006, 10:44
James,
There is a pressure relief valve on the hot water heater overflow. Maybe it popped open and didn't seat itself. I think you should be able to tap the stem of the overflow valve and see if that makes a difference. The valve is mounted directly to the heater and the overflow pipe is attached to it. David Hollis Springfield,IL NO Bird --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Here's another thing... > > When I put city water into the commercial intake, water immediately > starts to run out of the water tank overflow. I may be wrong but > the over flow appears to come out of the hot water tank. Does that > make any sense? > > > James > 78FC33SB > Kingman AZ > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > Thanks for the reply, Curt. > > > > I don't think it's a switch as it has worked properly for a long > > time and I have not thrown any switches or turned any valves. > > > > What I have discovered is that when I run the pump water begins to > > exit out ot the water tank over flow. > > > > I do not know what a Sporland valve is, however something being > > fouled by junk is a possibility. > > > > Could you expand on your thoughts for me so I can look for that > > valve? > > > > Thanks. > > > > > > James > > 78FC33SB > > Kingman AZ > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > > A couple thoughts. Does your Bird have the 12v water tank fill > > switch > > > that controls a Sporlan valve...that switch might be set > to 'fill' > > and > > > should be set to 'off'...or the Sporlan valve is filled with > junk > > and > > > needs to be cleaned out. > > > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > orbitalsolutions wrote: > > > > > > > My water pump runs and pumps water, but very slowly. I could > > not find > > > > any leaks or lose connections. It seems like the pump does > not > > prime > > > > it's self for some reason. The pump will run constantly. > > > > > > > > I'm digging into it now. Does anyone have any advice to offer? > > > > > > > > Thanks in advance. > > > > > > > > > > > > James > > > > 78FC33SB > > > > Kingman AZ (But not for long) > > > > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------- -- > -- > > ------- > > > > YAHOO! GROUPS LINKS > > > > > > > > * Visit your group "WanderlodgeForum > > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the > > web. > > > > > > > > * To unsubscribe from this group, send an email to: > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! > Terms > > of > > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > > > > ------------------------------------------------------------- -- > -- > > ------- > > > > > > > > > > |
05-12-2006, 11:02
James,
If you need it, look in the "Files" for the Sporlan Valve document that gives diagrams, parts numbers and instructions on repairing them. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Thanks for the reply, Curt. > > I don't think it's a switch as it has worked properly for a long > time and I have not thrown any switches or turned any valves. > > What I have discovered is that when I run the pump water begins to > exit out ot the water tank over flow. > > I do not know what a Sporland valve is, however something being > fouled by junk is a possibility. > > Could you expand on your thoughts for me so I can look for that > valve? > > Thanks. > > > James > 78FC33SB > Kingman AZ > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > A couple thoughts. Does your Bird have the 12v water tank fill > switch > > that controls a Sporlan valve...that switch might be set to 'fill' > and > > should be set to 'off'...or the Sporlan valve is filled with junk > and > > needs to be cleaned out. > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > orbitalsolutions wrote: > > > > > My water pump runs and pumps water, but very slowly. I could > not find > > > any leaks or lose connections. It seems like the pump does not > prime > > > it's self for some reason. The pump will run constantly. > > > > > > I'm digging into it now. Does anyone have any advice to offer? > > > > > > Thanks in advance. > > > > > > > > > James > > > 78FC33SB > > > Kingman AZ (But not for long) > > > > > > > > > > > > > > > > > > > > > ----------------------------------------------------------------- > ------- > > > YAHOO! GROUPS LINKS > > > > > > * Visit your group "WanderlodgeForum > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the > web. > > > > > > * To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms > of > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > ----------------------------------------------------------------- > ------- > > > > > > |
05-12-2006, 11:07
Hello, Dave!
I found the pressure relief valve. There is what looks to be a plug coming out of the end of it. I rapped lightly on it with a bearing hammer but no luck so far. Is the valve internal, or would I see the end (plug looking thing) retract if it seats? The bus is running great. I have more fun driving in this 'Bird than I would in a Ferrari. Honestly. Drove 163W this morning in 95 degree heat, went up some major uprgrades, and the old 'Bird never flinched, stayed nice and cool and ran strong all day. Thanks again for selling me such a nice Wanderlodge. Practically everyone that sees it stops and stares as if they were looking at a space ship from Mars! Oh well, back to do some more plumbing work. James 78FC33SB Kingman AZ --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" > > James, > > There is a pressure relief valve on the hot water heater overflow. > Maybe it popped open and didn't seat itself. I think you should be > able to tap the stem of the overflow valve and see if that makes a > difference. The valve is mounted directly to the heater and the > overflow pipe is attached to it. > > David Hollis Springfield,IL NO Bird > > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > Here's another thing... > > > > When I put city water into the commercial intake, water > immediately > > starts to run out of the water tank overflow. I may be wrong but > > the over flow appears to come out of the hot water tank. Does > that > > make any sense? > > > > > > James > > 78FC33SB > > Kingman AZ > > > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > > > > Thanks for the reply, Curt. > > > > > > I don't think it's a switch as it has worked properly for a long > > > time and I have not thrown any switches or turned any valves. > > > > > > What I have discovered is that when I run the pump water begins > to > > > exit out ot the water tank over flow. > > > > > > I do not know what a Sporland valve is, however something being > > > fouled by junk is a possibility. > > > > > > Could you expand on your thoughts for me so I can look for that > > > valve? > > > > > > Thanks. > > > > > > > > > James > > > 78FC33SB > > > Kingman AZ > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > > > > > A couple thoughts. Does your Bird have the 12v water tank fill > > > switch > > > > that controls a Sporlan valve...that switch might be set > > to 'fill' > > > and > > > > should be set to 'off'...or the Sporlan valve is filled with > > junk > > > and > > > > needs to be cleaned out. > > > > > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > > > > > orbitalsolutions wrote: > > > > > > > > > My water pump runs and pumps water, but very slowly. I > could > > > not find > > > > > any leaks or lose connections. It seems like the pump does > > not > > > prime > > > > > it's self for some reason. The pump will run constantly. > > > > > > > > > > I'm digging into it now. Does anyone have any advice to > offer? > > > > > > > > > > Thanks in advance. > > > > > > > > > > > > > > > James > > > > > 78FC33SB > > > > > Kingman AZ (But not for long) > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ----------------------------------------------------------- -- > -- > > -- > > > ------- > > > > > YAHOO! GROUPS LINKS > > > > > > > > > > * Visit your group "WanderlodgeForum > > > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on > the > > > web. > > > > > > > > > > * To unsubscribe from this group, send an email to: > > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! > > Terms > > > of > > > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > > > > > > > ----------------------------------------------------------- -- > -- > > -- > > > ------- > > > > > > > > > > > > > > > |
05-12-2006, 11:10
Sounds like a fill valve like Curt said and sounds like the water is
comming out of the overflow for the fresh water tank. If your hotwater drain is open, the drain will run when you turn the 12V pump on. The 12v Pump wont push water out of the tank overflow because it takes and replaces it. The water is drawn from the fresh tank by the pump, then the pump pushes the water in the plumbing pipes to pressurise the system. The Freshwater storage tank (FWST)is a appliance connected to the presurized system. If the fill valve is open the FWST will be trying to fill up but it is using the water it takes from the tank. This Recycling will not allow pressure to build so other appliances like sinks will only show a trickle. You may see other Motorhomes have a tank fill port for the fresh water and another one for city water port. MY BB has one hookup for citywater and I must flip a electric switch to open the valve on the FWST appliance when I want to fill the tank. Sounds like a fill valve like Curt said and sounds like the water is coming out of the overflow for the fresh water tank. If your hotwater drain is open, the drain will run when you turn the 12V pump on. The water is drawn from the fresh tank by the pump, then the pump pushes the water in the plumbing pipes to pressurize the system. The Freshwater storage tank (FWST)is a appliance connected to the pressurized system. If the fill valve is open the FWST will be trying to fill up but it is using the water it takes from the tank. This Recycling will not allow pressure to build so other appliances like sinks will only show a trickle. You may see other Motorhomes have a tank fill port for the fresh water and another one for city water port. MY BB has one hookup for citywater and I must flip an electric switch to open the valve on the FWST appliance when I want to fill the tank. If it is a FillValve. the Sporlan Valve in my 94 is under the bed which is behind the fill port. The valve is a diaphragm type and requires water pressure to close it off (much like a sprinkler valve). When the bus sits without a city hookup and/or pump pressure, the valve floats open and debris or calcium builds up on the diaphragm this will not allow it to seat and close. The valves are called "normal closed" but it is not passive. You need a charged solenoid to open it up (toggle fill switch). The valve may differ on your coach When this happened to me I hooked up to city water and flipped the fill switch several times while the tank was filling. It worked but later JM cautioned me of waterhammer damage from a quick close. In the future if I need to flip flip the switch under pressure, I will open a sink valve in the coach Gregory O'Connor 94pt40 Romoland CA --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Here's another thing... > > When I put city water into the commercial intake, water immediately > starts to run out of the water tank overflow. I may be wrong but > the over flow appears to come out of the hot water tank. Does that > make any sense? > > > James > 78FC33SB > Kingman AZ > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > Thanks for the reply, Curt. > > > > I don't think it's a switch as it has worked properly for a long > > time and I have not thrown any switches or turned any valves. > > > > What I have discovered is that when I run the pump water begins to > > exit out ot the water tank over flow. > > > > I do not know what a Sporland valve is, however something being > > fouled by junk is a possibility. > > > > Could you expand on your thoughts for me so I can look for that > > valve? > > > > Thanks. > > > > > > James > > 78FC33SB > > Kingman AZ > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > > A couple thoughts. Does your Bird have the 12v water tank fill > > switch > > > that controls a Sporlan valve...that switch might be set > to 'fill' > > and > > > should be set to 'off'...or the Sporlan valve is filled with > junk > > and > > > needs to be cleaned out. > > > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > orbitalsolutions wrote: > > > > > > > My water pump runs and pumps water, but very slowly. I could > > not find > > > > any leaks or lose connections. It seems like the pump does > not > > prime > > > > it's self for some reason. The pump will run constantly. > > > > > > > > I'm digging into it now. Does anyone have any advice to offer? > > > > > > > > Thanks in advance. > > > > > > > > > > > > James > > > > 78FC33SB > > > > Kingman AZ (But not for long) > > > > > > > > > > > > > > > > > > > > > > > > > > > > -------------------------------------------------------------- - > -- > > ------- > > > > YAHOO! GROUPS LINKS > > > > > > > > * Visit your group "WanderlodgeForum > > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the > > web. > > > > > > > > * To unsubscribe from this group, send an email to: > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! > Terms > > of > > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > > > > -------------------------------------------------------------- - > -- > > ------- > > > > > > > > > > |
