Onan 8.0 89sp glow plugs-how can you tell if good?
05-13-2006, 06:42
I have to crank my gen set a long time before it starts firing and
then it sputters a while before it finnaly runs smooth. I just read a post recentily that a glow plun can be bad and cause this problem. How can you check them to see if they are bad? With a meter? Do you have to pull them out? Thanks in advance for any help-- Im still working on the ideas from the forum on my telescoping , or non-telescoping steering wheel Ed 89sp Arlington Texas |
05-13-2006, 06:57
Ed,
Are you holding the switch to the 'stop' position to activate the glow plugs and fuel pump before going to the 'start' position? If not, I believe this is the proper technique. I normally count to between ten and twenty while holding the switch, depending on conditions. Gary Miller 83 FC 33 - Powertech 7.0 diesel Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" wrote: > > I have to crank my gen set a long time before it starts firing and > then it sputters a while before it finnaly runs smooth. I just read a > post recentily that a glow plun can be bad and cause this problem. How > can you check them to see if they are bad? With a meter? Do you have > to pull them out? > Thanks in advance for any help-- Im still working on the ideas from > the forum on my telescoping , or non-telescoping steering wheel > Ed 89sp > Arlington Texas > |
