Toyo Tires?
05-16-2006, 07:54
Toyo Tires?
I am going to replace all the tires on "Crazy Birds" before heading to
Montana in July with the family. Toyo has a M120Z 11R22.5 Not usre of 14 or 16 ply and what load rating do I need? Thanks Mike Meister 80FC33NA Tayllor Mill, Ky. |
05-16-2006, 22:31
Toyo Tires?
Mike, I did not see a reply to your question, so for what it is
worth, I have Dunlop "H" rated / 16 ply tires on my 33FC. The key is of course to match the tire rating to your loaded coach weight. As far a specific tires...I look for a standard name tire that is black and round at a good price at the proper rating, and designed for the application (steer vs drive). You will likely have good luck with the TOYOS, my Dunlops ride fine, I am sure the big french brand is great too...but i question paying such a premium price for it. Frank 85FC33 Woodbridge, VA. --- In WanderlodgeForum@yahoogroups.com, "Mike Meister" <mike.meister@...> wrote: > > I am going to replace all the tires on "Crazy Birds" before heading to > Montana in July with the family. > > Toyo has a M120Z 11R22.5 > > Not usre of 14 or 16 ply and what load rating do I need? > > Thanks > > Mike Meister > 80FC33NA > Tayllor Mill, Ky. > |
05-17-2006, 10:51
Toyo Tires?
Mike I too replaced all my tires shortly after purchasing my BB. I was able
to save a few bucks. I wanted Michelin steers but didn't want to pay the premium price for the same brand on the back. For the drives and tags I chose BF Goodrich, a Michelin subsidary, and saved at least the price of a tire. I chose Michelin because I kept hearing that the roundest tire you can buy is a Michelin. I didn't want any of the trouble I had heard others having with poor handling, shaking, poor tracking etc etc. My choice has proven to be fine so far (2 years). Three or four more years and I will be replacing them and will let you know how they did. Whatever brand you select I would suggest that you can save money in the same fashion as I. Also you might consider saving another few bucks by not bothering to balance the rear tires. Worked for me. On 17/05/06, fwernlein > > Mike, I did not see a reply to your question, so for what it is > worth, I have Dunlop "H" rated / 16 ply tires on my 33FC. The key > is of course to match the tire rating to your loaded coach weight. > As far a specific tires...I look for a standard name tire that is > black and round at a good price at the proper rating, and designed > for the application (steer vs drive). > > You will likely have good luck with the TOYOS, my Dunlops ride fine, > I am sure the big french brand is great too...but i question paying > such a premium price for it. > > > Frank > 85FC33 > Woodbridge, VA. > > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Meister" > <mike.meister@...> wrote: > > > > I am going to replace all the tires on "Crazy Birds" before > heading to > > Montana in July with the family. > > > > Toyo has a M120Z 11R22.5 > > > > Not usre of 14 or 16 ply and what load rating do I need? > > > > Thanks > > > > Mike Meister > > 80FC33NA > > Tayllor Mill, Ky. > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-17-2006, 11:10
Toyo Tires?
With all due respect,
You may decide not to balance the rear tires, but I found that balancing makes the coach considerably smoother. I also run balanced drums, part number 3600AX. David '02 LXi, Smokey Va Rob Robinson wrote: >Also you >might consider saving another few bucks by not bothering to balance the rear >tires. Worked for me. > > > > > > -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.392 / Virus Database: 268.6.0/341 - Release Date: 5/16/2006 |
05-17-2006, 11:17
Toyo Tires?
Like I said.......worked for me.
On 17/05/06, David Brady > > With all due respect, > You may decide not to balance the rear tires, but I found that balancing > makes the coach considerably smoother. I also run balanced drums, > part number 3600AX. > > David > '02 LXi, Smokey > Va > > > Rob Robinson wrote: > > >Also you > >might consider saving another few bucks by not bothering to balance the > rear > >tires. Worked for me. > > > > > > > > > > > > > > > > -- > No virus found in this outgoing message. > Checked by AVG Free Edition. > Version: 7.1.392 / Virus Database: 268.6.0/341 - Release Date: 5/16/2006 > > > > > > Yahoo! Groups Links > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
