230V Generator Fan Motor
05-17-2006, 01:55
Folks,
Thought I'd remind everyone to lubricate the bearings in the 230V Single Induction Fan motor which sits on top of the generator's radiator. The fan motor states that after 3 years of use, the user must lube the bearings with 10 drops of 5w-30 motor oil. I learned the hard way... Anyone know how often the powertech can overheat before causing major engine damage? My unit has a thermal cutoff switch which seams to work, but when she cut off the water temp gauge was reading in excess of 230deg F. Thanks David Brady '02 LXi, Smokey Va -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.392 / Virus Database: 268.6.0/341 - Release Date: 5/16/2006 |
