FUEL TANK SENDING UNIT REMOVE AND REPLACE
05-18-2006, 17:32
I have aquestion concerning replacing, the fuel tank sending unit on
my '82 FC35RB, please check out the photos at; http://www.pbase.com/image/60408087 "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA |
05-18-2006, 17:47
Looks pretty tight John. Would a right angle screwdriver get in there? Will
the sending unit length be a problem because it will have to come out at an angle. I had a similar tight situation earlier this year and had to enlarge an access hole through eighth inch plate steel using one of Randy's hole saws. On 18/05/06, John > > I have aquestion concerning replacing, the fuel tank sending unit on > my '82 FC35RB, please check out the photos at; > > http://www.pbase.com/image/60408087 > > "REMEMBER SEPTEMBER 11, 2001" > John Finn > '82 35FCRB > BLUEBIRD WANDERLODGE > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > GO TO; > http://www.pbase.com/image/24977457 > HOPKINS, SOUTH CAROLINA > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-18-2006, 23:29
Been there, drop front of tank a little. Floor jack does the trick.
MH ----- Original Message ----- From: John To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 19, 2006 12:32 AM Subject: [WanderlodgeForum] FUEL TANK SENDING UNIT REMOVE AND REPLACE I have aquestion concerning replacing, the fuel tank sending unit on my '82 FC35RB, please check out the photos at; http://www.pbase.com/image/60408087 "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-19-2006, 01:29
John, Drill a hole above the screw, larger than the driver,but I wonder
if there is room to lift the sender out? Gregory O'Connor 94pt40 Romoland CA |
05-19-2006, 01:36
Thanks Mike,
That will be a job for another time, when the tank is not full and just continue to refuel at between 500 and 600 miles just to make sure that I don't run out of fuel, so far that has worked OK. I might also look at enlarging the access hole as Rob suggested and making a new cover for it afterward, that would not be that hard to do either using a sawsall, with a shortened blade. I got the idea to change it after I had the dash apart and found out that the fuel gauge was in working order at the dash, but I want to finish the dash first and I'll be leaving here in less than a month. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA //////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Been there, drop front of tank a little. Floor jack does the trick. > MH > ----- Original Message ----- > From: John > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, May 19, 2006 12:32 AM > Subject: [WanderlodgeForum] FUEL TANK SENDING UNIT REMOVE AND REPLACE > > > I have aquestion concerning replacing, the fuel tank sending unit on > my '82 FC35RB, please check out the photos at; > > http://www.pbase.com/image/60408087 > > "REMEMBER SEPTEMBER 11, 2001" > John Finn > '82 35FCRB > BLUEBIRD WANDERLODGE > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > GO TO; > http://www.pbase.com/image/24977457 > HOPKINS, SOUTH CAROLINA > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair > Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > |
05-19-2006, 01:58
Make sure there is no frame member under the floor. Seems to me there is,
that's why the hole is off a little. MH ----- Original Message ----- From: John To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 19, 2006 8:36 AM Subject: [WanderlodgeForum] Re: FUEL TANK SENDING UNIT REMOVE AND REPLACE Thanks Mike, That will be a job for another time, when the tank is not full and just continue to refuel at between 500 and 600 miles just to make sure that I don't run out of fuel, so far that has worked OK. I might also look at enlarging the access hole as Rob suggested and making a new cover for it afterward, that would not be that hard to do either using a sawsall, with a shortened blade. I got the idea to change it after I had the dash apart and found out that the fuel gauge was in working order at the dash, but I want to finish the dash first and I'll be leaving here in less than a month. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA //////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Been there, drop front of tank a little. Floor jack does the trick. > MH > ----- Original Message ----- > From: John > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, May 19, 2006 12:32 AM > Subject: [WanderlodgeForum] FUEL TANK SENDING UNIT REMOVE AND REPLACE > > > I have aquestion concerning replacing, the fuel tank sending unit on > my '82 FC35RB, please check out the photos at; > > http://www.pbase.com/image/60408087 > > "REMEMBER SEPTEMBER 11, 2001" > John Finn > '82 35FCRB > BLUEBIRD WANDERLODGE > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > GO TO; > http://www.pbase.com/image/24977457 > HOPKINS, SOUTH CAROLINA > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair > Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-19-2006, 03:25
John,
A pneumatic auto body saw works well for cutting the floor plate. The stroke is shorter/faster than the sawsall. I use a regular hand hacksaw blade, cut in thirds...they last longer than the blades sold specifically for the air saw. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. John wrote: > Thanks Mike, > > That will be a job for another time, when the tank is not full and > just continue to refuel at between 500 and 600 miles just to make > sure that I don't run out of fuel, so far that has worked OK. I might > also look at enlarging the access hole as Rob suggested and making a > new cover for it afterward, that would not be that hard to do either > using a sawsall, with a shortened blade. > > I got the idea to change it after I had the dash apart and found out > that the fuel gauge was in working order at the dash, but I want to > finish the dash first and I'll be leaving here in less than a month. > > "REMEMBER SEPTEMBER 11, 2001" > John Finn > '82 35FCRB > BLUEBIRD WANDERLODGE > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > GO TO; > http://www.pbase.com/image/24977457 > HOPKINS, SOUTH CAROLINA > > //////////////////////////////////////////////////////////////// > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@...> wrote: > > > > Been there, drop front of tank a little. Floor jack does the trick. > > MH > > ----- Original Message ----- > > From: John > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, May 19, 2006 12:32 AM > > Subject: [WanderlodgeForum] FUEL TANK SENDING UNIT REMOVE AND > REPLACE > > > > > > I have aquestion concerning replacing, the fuel tank sending unit > on > > my '82 FC35RB, please check out the photos at; > > > > http://www.pbase.com/image/60408087 > > > > "REMEMBER SEPTEMBER 11, 2001" > > John Finn > > '82 35FCRB > > BLUEBIRD WANDERLODGE > > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > > GO TO; > > http://www.pbase.com/image/24977457 > > HOPKINS, SOUTH CAROLINA > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle > financing Recreational vehicle repair > > Recreational vehicle rental Recreational vehicle camper > Recreational vehicle rate > > > > > > -------------------------------------------------------------------- > ---------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > -------------------------------------------------------------------- > ---------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
05-19-2006, 05:42
Thanks again Mike,
You are right again, there is a cross member located just aft of the access hole, that I can feel when I stick my fingers under there, so lowering the front of the tank will be the way to do the remove and replace whenever I decide to do that, but when I have a lot less fuel in the tank, to deal with weight wise. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA ////////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Make sure there is no frame member under the floor. Seems to me there is, that's why the hole is off a little. > MH > ----- Original Message ----- > From: John > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, May 19, 2006 8:36 AM > Subject: [WanderlodgeForum] Re: FUEL TANK SENDING UNIT REMOVE AND REPLACE > > > Thanks Mike, > > That will be a job for another time, when the tank is not full and > just continue to refuel at between 500 and 600 miles just to make > sure that I don't run out of fuel, so far that has worked OK. I might > also look at enlarging the access hole as Rob suggested and making a > new cover for it afterward, that would not be that hard to do either > using a sawsall, with a shortened blade. > > I got the idea to change it after I had the dash apart and found out > that the fuel gauge was in working order at the dash, but I want to > finish the dash first and I'll be leaving here in less than a month. > > "REMEMBER SEPTEMBER 11, 2001" > John Finn > '82 35FCRB > BLUEBIRD WANDERLODGE > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > GO TO; > http://www.pbase.com/image/24977457 > HOPKINS, SOUTH CAROLINA > > //////////////////////////////////////////////////////////////// > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > Been there, drop front of tank a little. Floor jack does the trick. > > MH > > ----- Original Message ----- > > From: John > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, May 19, 2006 12:32 AM > > Subject: [WanderlodgeForum] FUEL TANK SENDING UNIT REMOVE AND > REPLACE > > > > > > I have aquestion concerning replacing, the fuel tank sending unit > on > > my '82 FC35RB, please check out the photos at; > > > > http://www.pbase.com/image/60408087 > > > > "REMEMBER SEPTEMBER 11, 2001" > > John Finn > > '82 35FCRB > > BLUEBIRD WANDERLODGE > > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > > GO TO; > > http://www.pbase.com/image/24977457 > > HOPKINS, SOUTH CAROLINA > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle > financing Recreational vehicle repair > > Recreational vehicle rental Recreational vehicle camper > Recreational vehicle rate > > > > > > ---------------------------------------------------------------- ---- > ---------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ---------------------------------------------------------------- ---- > ---------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair > Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > |
05-20-2006, 00:46
Curt, is there a tool you dont have
Greg 94PT Romoland CA --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > John, > A pneumatic auto body saw works well for cutting the floor plate. The > stroke is shorter/faster than the sawsall. I use a regular hand hacksaw > blade, cut in thirds...they last longer than the blades sold > specifically for the air saw. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
05-20-2006, 06:25
In a message dated 5/20/2006 4:19:25 P.M. Eastern Daylight Time,
billpatty@... writes: Bill That's pretty good a through away funnel. That is always the way with a funnel it is always dirty when you need it & you have to clean it. Don 89 SP 36' Butler, PA Here is a tool that Curt may not have. http://www.fastfunnel.com/ They are great, 3 for $.99 Bill 88 FC [Non-text portions of this message have been removed] |
