basement air conditioners
05-23-2006, 05:09
I notice a lack of performace on my acs so I took out the filters which I clean
normally. no
different, so I look back into the air return its dark so I used my flash light
to see up close
and realized theres a sreen mesh inserted next to the cooling coils which were
completely
blocked with years of crud. now I can hang meat inside the BB, what a
difference.
I didn;t know the screens were there!
guy smalley
chilling out in UT
86 pt 40
05-27-2006, 01:54
Guy,
Do you have the central air in the basement. Did you access these screens inside
the coach or in the basement. How many screens did you find. Do you think this
was a factory install item.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Tuesday, May 23, 2006 1:09 PM
Subject: [WanderlodgeForum] basement air conditioners
clean normally. no
light to see up close
completely
difference.
guy smalley
chilling out in UT
86 pt 40
SPONSORED LINKS Recreational vehicles Recreational vehicle financing
Recreational vehicle repair
Recreational vehicle rental Recreational vehicle camper Recreational
vehicle rate
YAHOO! GROUPS LINKS
05-27-2006, 04:49
The basement air's are Cruise Air units. They are a split system, condenser
in the basement and the evaporator in the Coach. There are 3 of these
systems in the Coaches. The screens are original with the systems and are
important as it keeps dust/pet hair and the rest out of the coils. Or
rather helps to anyway. I removed mine, cleaned them then I did wrap tape
around the edges to help put them back in the proper place. Air flow keeps
the icing down of course so cleaning them is essential. The are charged
with R-22 and a little more fussy when servicing them but when done right,
you can hang meat in the Coach
Safe travels,
At 09:54 AM 5/27/2006 -0400, you wrote:
>Guy,
>inside the coach or in the basement. How many screens did you find. Do you
>think this was a factory install item.
>Howard Truitt
>Camilla, Ga.
>86 PT40
> From: guysmalley
> I clean normally. no
> flash light to see up close
> which were completely
> difference.
> guy smalley
> chilling out in UT
> 86 pt 40
05-27-2006, 22:23
Howard, on my cruise airs, my filters were way up inside the air cavity. You
can see them when you remove the first filter. Use a good flashlite.
Ernie-83pt40 in Montana, snow in the mountains, no air conditioning required
05-28-2006, 02:20
Ralph,
I have replaced the square metal filters because the foam had deteriorated. Am I
to understand that there is another set of filters or screens in front of the
evaporators. Where do I find the evaporators and how do I access the filters at
the evaporators.
Thanks,
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Saturday, May 27, 2006 12:49 PM
Subject: Re: [WanderlodgeForum] basement air conditioners
Safe travels,
>Guy,
>Howard Truitt
>Camilla, Ga.
>86 PT40
> From: guysmalley
> difference.
> guy smalley
> chilling out in UT
> 86 pt 40
vehicle rate
YAHOO! GROUPS LINKS
05-28-2006, 02:37
Howard:
When you open the return air grills with the wafered foam filters, look
deep inside and you will see the evaporator. In front of that coil there
should be a mesh screen that needs to be pulled, replaced or cleaned then
put back. This same screen will be on all 3 of your units.
Safe travels,
At 10:20 AM 5/28/2006 -0400, you wrote:
>Ralph,
>deteriorated. Am I to understand that there is another set of filters or
>screens in front of the evaporators. Where do I find the evaporators and
>how do I access the filters at the evaporators.
>Thanks,
>Howard Truitt
>Camilla, Ga.
>86 PT40
> From: Ralph L. Fullenwider
> condenser
