1988 FC water coach heater question
05-24-2006, 10:04
Bruce,
I can't offer much help, but I'm sure other FC owners will chime in. I have a 86 PT, and there are plumbing-style gate valves in my engine compartment that can be manually cranked closed (similar to turning off the water to your home sprinkler system). This prohibits coolant/antifreeze from circulating to your heaters, and closes the engine coolant system to just the engine radiator. I would think the FC's have a similar system. The winter/summer switch on my PT opens or closes a Sporlan valve in my engine compartment which allows the coolant to flow into the chassis heater system, and the "Aux Pump" switch is a booster flow pump that helps push all that coolant through 70' of coolant hoses and heater cores. Look for that Sporlan valve (in-line brass device with a electromagnetic solenoid on top with two wires)...it can be rebuilt for about $15, or replaced for about $40. Since it's summer, if your BB has those gate valves, maybe you can just close off the chassis heaters from the BB's engine cooling system, and fix the Sporlan valve when it's convenient. How about some FC's owners...any suggestions or advice? Best of luck...I can only imagine what it's like competing against chassis heaters in 100 degree weather with the A/C. Kevin McKeown Yorba Linda, CA (about 85 beautiful degrees today!) 1986 38' PT [Non-text portions of this message have been removed] |
05-24-2006, 13:13
We are on our maiden voyage in the new to us Bird. I will post a story
of the trip later. Right now I have a small problem. I have the blue Box for our unit but section 10 with all the plumbing and electrical diagrams is missing. Our coach has a heater (engine hot water) under the kitchen drawers beside the fridge. We are in AZ. It was 101 today. My wife went to get something from the drawers and she said she almost burned herself. I checked and the heater core. It is damn hot. Checked the switch for summer/winter and it is set on summer. How do I stop the water from circulating to the heaters? I know the switch is supposed to activate a solenoid. Where is that solenoid located? Why couldnt they use a simple Ranco valve? Without the diagram for the heaters I am having trouble figuring how this works. Are there seperate lines going to the water heater? For now I would like to just install a simple gate valve to stop the water from entering the heater. I havent yet checked to see if the other heaters are also hot. Thanks: Bruce |
05-24-2006, 13:51
On my 82 FC there are two gate valves in heater hoses up behind the
driver's side wheel near the engine. I assume these shut off the flow to the coach. Kerry 82 FC 35 Denver- -- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > We are on our maiden voyage in the new to us Bird. I will post a story > of the trip later. Right now I have a small problem. I have the blue > Box for our unit but section 10 with all the plumbing and electrical > diagrams is missing. Our coach has a heater (engine hot water) under > the kitchen drawers beside the fridge. We are in AZ. It was 101 today. > My wife went to get something from the drawers and she said she almost > burned herself. I checked and the heater core. It is damn hot. Checked > the switch for summer/winter and it is set on summer. How do I stop > the water from circulating to the heaters? I know the switch is > supposed to activate a solenoid. Where is that solenoid located? Why > couldnt they use a simple Ranco valve? Without the diagram for the > heaters I am having trouble figuring how this works. Are there > seperate lines going to the water heater? For now I would like to just > install a simple gate valve to stop the water from entering the > heater. I havent yet checked to see if the other heaters are also hot. > > Thanks: Bruce > |
05-24-2006, 14:29
Under the sink against the back wall is a strip electric heater for
freeze-heat, and under the sink in the kickboard is an electric heater, sure it isn't one of these? The summer/winter switch should shut down flow to the heaters, if not then you need a sporlan valve rebuild kit as it apparently isn't shutting off, very common. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > We are on our maiden voyage in the new to us Bird. I will post a story > of the trip later. Right now I have a small problem. I have the blue > Box for our unit but section 10 with all the plumbing and electrical > diagrams is missing. Our coach has a heater (engine hot water) under > the kitchen drawers beside the fridge. We are in AZ. It was 101 today. > My wife went to get something from the drawers and she said she almost > burned herself. I checked and the heater core. It is damn hot. Checked > the switch for summer/winter and it is set on summer. How do I stop > the water from circulating to the heaters? I know the switch is > supposed to activate a solenoid. Where is that solenoid located? Why > couldnt they use a simple Ranco valve? Without the diagram for the > heaters I am having trouble figuring how this works. Are there > seperate lines going to the water heater? For now I would like to just > install a simple gate valve to stop the water from entering the > heater. I havent yet checked to see if the other heaters are also hot. > > Thanks: Bruce > |
05-24-2006, 14:31
On my coach (82 FC), there are two standard plumbing valves just like
your home garden hose spigot in what look like heater hoses running back from the radiator. They are behind the front left wheel. They cut off all water flow to the back. The summer/winter switch activates a solenoid that allows water to flow to the interior heat exchangers. Interestingly enough, even in "summer" mode, water should still flow back through the lines to heat the hot water heater for your over-the-road hot water. But there are two different return lines, one that goes through the heat exchangers, one that doesn't. That's what the solenoid controls. I chased the opposite problem on my FC, the interior heat exchangers would not receive water. I ultimately determined that a wire had come loose from the back of the winter/summer switch, once reattached, it worked perfectly. Good luck. Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > We are on our maiden voyage in the new to us Bird. I will post a story > of the trip later. Right now I have a small problem. I have the blue > Box for our unit but section 10 with all the plumbing and electrical > diagrams is missing. Our coach has a heater (engine hot water) under > the kitchen drawers beside the fridge. We are in AZ. It was 101 today. > My wife went to get something from the drawers and she said she almost > burned herself. I checked and the heater core. It is damn hot. Checked > the switch for summer/winter and it is set on summer. How do I stop > the water from circulating to the heaters? I know the switch is > supposed to activate a solenoid. Where is that solenoid located? Why > couldnt they use a simple Ranco valve? Without the diagram for the > heaters I am having trouble figuring how this works. Are there > seperate lines going to the water heater? For now I would like to just > install a simple gate valve to stop the water from entering the > heater. I havent yet checked to see if the other heaters are also hot. > > Thanks: Bruce > |
05-24-2006, 16:02
Same basic system on the FC Kevin. As I recall there 3 manual valves, which is
what I had on my FC also. If you close those, the Sporland valves associated with the "summer/summer" switch won't have any effect. You also won't have any hot water from the engine when running. So, one of those valves is for the hot water and maybe you wouldn't want to close that one. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 24, 2006 7:04 PM Subject: Re: [WanderlodgeForum] 1988 FC water coach heater question Bruce, I can't offer much help, but I'm sure other FC owners will chime in. I have a 86 PT, and there are plumbing-style gate valves in my engine compartment that can be manually cranked closed (similar to turning off the water to your home sprinkler system). This prohibits coolant/antifreeze from circulating to your heaters, and closes the engine coolant system to just the engine radiator. I would think the FC's have a similar system. The winter/summer switch on my PT opens or closes a Sporlan valve in my engine compartment which allows the coolant to flow into the chassis heater system, and the "Aux Pump" switch is a booster flow pump that helps push all that coolant through 70' of coolant hoses and heater cores. Look for that Sporlan valve (in-line brass device with a electromagnetic solenoid on top with two wires)...it can be rebuilt for about $15, or replaced for about $40. Since it's summer, if your BB has those gate valves, maybe you can just close off the chassis heaters from the BB's engine cooling system, and fix the Sporlan valve when it's convenient. How about some FC's owners...any suggestions or advice? Best of luck...I can only imagine what it's like competing against chassis heaters in 100 degree weather with the A/C. Kevin McKeown Yorba Linda, CA (about 85 beautiful degrees today!) 1986 38' PT [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> Recreational vehicle financing<http://groups.yahoo.com/gads?t=ms&k=Recr...g&w1=\ Recreational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+\ repair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati\ onal+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> Recreational vehicle repair<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> Recreational vehicle rental<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> Recreational vehicle camper<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> Recreational vehicle rate<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-24-2006, 16:28
That's right Dick.
What I did was to cut off the 1" lines at the radiator (two) and the one up front forward of the co-pilot seat. My concern was the original 1" lines would spring a leak and cause problems. It was to be a future project but the coach was sold. Just run the generator for 20 minutes and you will have hot water for the coach and if plugged in you get the same result...providing everything is in working order. You can always tackle the engine water circulation/heating system project in the future. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Richard Hayden wrote: > Same basic system on the FC Kevin. As I recall there 3 manual valves, > which is what I had on my FC also. If you close those, the Sporland > valves associated with the "summer/summer" switch won't have any > effect. You also won't have any hot water from the engine when > running. So, one of those valves is for the hot water and maybe you > wouldn't want to close that one. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: krminyl@... > To: > WanderlodgeForum@yahoogroups.com > Sent: Wednesday, May 24, 2006 7:04 PM > Subject: Re: [WanderlodgeForum] 1988 FC water coach heater question > > > Bruce, > > I can't offer much help, but I'm sure other FC owners will chime > in. I have > a 86 PT, and there are plumbing-style gate valves in my engine > compartment > that can be manually cranked closed (similar to turning off the > water to your > home sprinkler system). This prohibits coolant/antifreeze from > circulating > to your heaters, and closes the engine coolant system to just the > engine > radiator. > > I would think the FC's have a similar system. The winter/summer > switch on > my PT opens or closes a Sporlan valve in my engine compartment > which allows > the coolant to flow into the chassis heater system, and the "Aux > Pump" switch > is a booster flow pump that helps push all that coolant through 70' > of coolant > hoses and heater cores. > > Look for that Sporlan valve (in-line brass device with a > electromagnetic > solenoid on top with two wires)...it can be rebuilt for about $15, > or replaced > for about $40. Since it's summer, if your BB has those gate valves, > maybe you > can just close off the chassis heaters from the BB's engine cooling > system, > and fix the Sporlan valve when it's convenient. > > How about some FC's owners...any suggestions or advice? > > Best of luck...I can only imagine what it's like competing against > chassis > heaters in 100 degree weather with the A/C. > > Kevin McKeown > Yorba Linda, CA (about 85 beautiful degrees today!) > 1986 38' PT > > > > > [Non-text portions of this message have been removed] > > > > SPONSORED LINKS Recreational > vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>> > Recreational vehicle > financing<http://groups.yahoo.com/gads?t=ms&k=Recr...g&w1=\ Recreational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+\ repair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati\ onal+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>> > Recreational vehicle > repair<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>> > > Recreational vehicle > rental<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>> > Recreational vehicle > camper<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>> > Recreational vehicle > rate<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>> > > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group > "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on > the web. > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service<http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
05-24-2006, 17:28
Twenty minutes to get hot water - that's exactly what I it took on ours, both
the old one and this new (to us) one. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 24, 2006 9:28 PM Subject: Re: [WanderlodgeForum] 1988 FC water coach heater question That's right Dick. What I did was to cut off the 1" lines at the radiator (two) and the one up front forward of the co-pilot seat. My concern was the original 1" lines would spring a leak and cause problems. It was to be a future project but the coach was sold. Just run the generator for 20 minutes and you will have hot water for the coach and if plugged in you get the same result...providing everything is in working order. You can always tackle the engine water circulation/heating system project in the future. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Richard Hayden wrote: > Same basic system on the FC Kevin. As I recall there 3 manual valves, > which is what I had on my FC also. If you close those, the Sporland > valves associated with the "summer/summer" switch won't have any > effect. You also won't have any hot water from the engine when > running. So, one of those valves is for the hot water and maybe you > wouldn't want to close that one. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: krminyl@... > To: > WanderlodgeForum@yahoogroups.com > Sent: Wednesday, May 24, 2006 7:04 PM > Subject: Re: [WanderlodgeForum] 1988 FC water coach heater question > > > Bruce, > > I can't offer much help, but I'm sure other FC owners will chime > in. I have > a 86 PT, and there are plumbing-style gate valves in my engine > compartment > that can be manually cranked closed (similar to turning off the > water to your > home sprinkler system). This prohibits coolant/antifreeze from > circulating > to your heaters, and closes the engine coolant system to just the > engine > radiator. > > I would think the FC's have a similar system. The winter/summer > switch on > my PT opens or closes a Sporlan valve in my engine compartment > which allows > the coolant to flow into the chassis heater system, and the "Aux > Pump" switch > is a booster flow pump that helps push all that coolant through 70' > of coolant > hoses and heater cores. > > Look for that Sporlan valve (in-line brass device with a > electromagnetic > solenoid on top with two wires)...it can be rebuilt for about $15, > or replaced > for about $40. Since it's summer, if your BB has those gate valves, > maybe you > can just close off the chassis heaters from the BB's engine cooling > system, > and fix the Sporlan valve when it's convenient. > > How about some FC's owners...any suggestions or advice? > > Best of luck...I can only imagine what it's like competing against > chassis > heaters in 100 degree weather with the A/C. > > Kevin McKeown > Yorba Linda, CA (about 85 beautiful degrees today!) > 1986 38' PT > > > > > [Non-text portions of this message have been removed] > > > > SPONSORED LINKS Recreational > vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w<http://groups.yahoo.com/gads?t=ms&\ k=Recreational+vehicles&w1=Recreational+vehicles&w2=Recreational+vehicle+financi\ ng&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreational\ +vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir\ 3w> > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w<http://groups.yahoo.com/gads?t=ms&k=Recrea\ tional+vehicles&w1=Recreational+vehicles&w2=Recreational+vehicle+financing&w3=Re\ creational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle\ +camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>>> > Recreational vehicle > financing<http://groups.yahoo.com/gads?t=ms&k=Recr...g&w1=\ Recreational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+\ repair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati\ onal+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg<http://groups.yahoo.com/\ gads?t=ms&k=Recreational+vehicle+financing&w1=Recreational+vehicles&w2=Recreatio\ nal+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+ren\ tal&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=f\ _xgT1AKZsKXD6CT0_3nwg> > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg<http://groups.yahoo.com/gads?t=ms\ &k=Recreational+vehicle+financing&w1=Recreational+vehicles&w2=Recreational+vehic\ le+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Re\ creational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZs\ KXD6CT0_3nwg>>> > Recreational vehicle > repair<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ<http://groups.yahoo.com/gads?t\ =ms&k=Recreational+vehicle+repair&w1=Recreational+vehicles&w2=Recreational+vehic\ le+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Re\ creational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=0EDYS_wXU1\ aorG4893QXpQ> > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ<http://groups.yahoo.com/gads?t=ms&k=\ Recreational+vehicle+repair&w1=Recreational+vehicles&w2=Recreational+vehicle+fin\ ancing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreati\ onal+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG48\ 93QXpQ>>> > > Recreational vehicle > rental<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA<http://groups.yahoo.com/gads?t\ =ms&k=Recreational+vehicle+rental&w1=Recreational+vehicles&w2=Recreational+vehic\ le+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Re\ creational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=LNSmSf785I\ F1UlbWHRIOLA> > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA<http://groups.yahoo.com/gads?t=ms&k=\ Recreational+vehicle+rental&w1=Recreational+vehicles&w2=Recreational+vehicle+fin\ ancing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreati\ onal+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbW\ HRIOLA>>> > Recreational vehicle > camper<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ<http://groups.yahoo.com/gads?t\ =ms&k=Recreational+vehicle+camper&w1=Recreational+vehicles&w2=Recreational+vehic\ le+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Re\ creational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=LoIo4UxSgN\ x-IyPMRku1lQ> > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ<http://groups.yahoo.com/gads?t=ms&k=\ Recreational+vehicle+camper&w1=Recreational+vehicles&w2=Recreational+vehicle+fin\ ancing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreati\ onal+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPM\ Rku1lQ>>> > Recreational vehicle > rate<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw<http://groups.yahoo.com/gads?t=ms&\ k=Recreational+vehicle+rate&w1=Recreational+vehicles&w2=Recreational+vehicle+fin\ ancing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreati\ onal+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJ\ hwD4dw> > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw<http://groups.yahoo.com/gads?t=ms&k=Re\ creational+vehicle+rate&w1=Recreational+vehicles&w2=Recreational+vehicle+financi\ ng&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreational\ +vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4\ dw>>> > > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group > "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum<http://groups.y\ ahoo.com/group/WanderlodgeForum>>" on > the web. > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service<http://docs.yahoo.com/info/terms/<http://docs.yahoo.com/info/terms/>>. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w<http://groups.yahoo.com/gads?t=ms&k=Recrea\ tional+vehicles&w1=Recreational+vehicles&w2=Recreational+vehicle+financing&w3=Re\ creational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle\ +camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg<http://groups.yahoo.com/gads?t=ms\ &k=Recreational+vehicle+financing&w1=Recreational+vehicles&w2=Recreational+vehic\ le+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Re\ creational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZs\ KXD6CT0_3nwg>> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ<http://groups.yahoo.com/gads?t=ms&k=\ Recreational+vehicle+repair&w1=Recreational+vehicles&w2=Recreational+vehicle+fin\ ancing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreati\ onal+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG48\ 93QXpQ>> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA<http://groups.yahoo.com/gads?t=ms&k=\ Recreational+vehicle+rental&w1=Recreational+vehicles&w2=Recreational+vehicle+fin\ ancing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreati\ onal+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbW\ HRIOLA>> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ<http://groups.yahoo.com/gads?t=ms&k=\ Recreational+vehicle+camper&w1=Recreational+vehicles&w2=Recreational+vehicle+fin\ ancing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreati\ onal+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPM\ Rku1lQ>> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw<http://groups.yahoo.com/gads?t=ms&k=Re\ creational+vehicle+rate&w1=Recreational+vehicles&w2=Recreational+vehicle+financi\ ng&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Recreational\ +vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4\ dw>> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum<http://groups.yahoo.com/group/Wa\ nderlodgeForum>>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/<http://docs.yahoo.com/info/terms/>>. > > > ------------------------------------------------------------------------ > SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> Recreational vehicle financing<http://groups.yahoo.com/gads?t=ms&k=Recr...g&w1=\ Recreational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+\ repair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati\ onal+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> Recreational vehicle repair<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> Recreational vehicle rental<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> Recreational vehicle camper<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair\ &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v\ ehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> Recreational vehicle rate<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=\ Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehic\ le+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-25-2006, 01:47
Bruce,
Good to here the new Bird is running strong. I will attempt to answer a few of your questions. I agree with all the following posting responses. But would like to add: The Turbo wines, watch the gages, Pyro and boost and listen to the wine. You will get the feel for it. There are three Red handled gate valves. two under the drivers seat floor, this will turn off all hot coolant in the loop through the rear of the coach. Another on the passenger side to turn off the coolant to the front driver/passenger chassis heater. There is also a solenoid valve in this loop, switch is on dash labeled (Front heat) There are two Sporlan valves in the rear loop. One is under the rear street side bumper, Reach up and feel the grease and road dirt, Have someone press the winter/sumer switch. You should hear the click and feel the valve open close. Do the same with the other sporlan valve. This one took me a long time to locate. It is rearward of the two gate valves, high above the left front tire wrapped inside a bundle of wire and hosing. Again you can hear the click and feel the valve operate. These two valves need a repair kit, the coolant badly deteriorates the rubber diaphrams. WHen you fine a supplier for the Sporlan repair Kits # KS-BR18, purchase at least three, you will need them. The valve is part # K-BR184. Jeff is correct on the brakes, They do use a lot of air. Air up stomp and hold the brake pedal, for a minute or two, After the initial air loss, a leak will show on the gage. Your to do repair list is starting. Bill 88 FC Mihcigan --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > We are on our maiden voyage in the new to us Bird. I will post a story > of the trip later. Right now I have a small problem. I have the blue > Box for our unit but section 10 with all the plumbing and electrical > diagrams is missing. Our coach has a heater (engine hot water) under > the kitchen drawers beside the fridge. We are in AZ. It was 101 today. > My wife went to get something from the drawers and she said she almost > burned herself. I checked and the heater core. It is damn hot. Checked > the switch for summer/winter and it is set on summer. How do I stop > the water from circulating to the heaters? I know the switch is > supposed to activate a solenoid. Where is that solenoid located? Why > couldnt they use a simple Ranco valve? Without the diagram for the > heaters I am having trouble figuring how this works. Are there > seperate lines going to the water heater? For now I would like to just > install a simple gate valve to stop the water from entering the > heater. I havent yet checked to see if the other heaters are also hot. > > Thanks: Bruce > |
05-25-2006, 02:06
BRuce,
Another thought: If you are curious as to what a Sporlan Valve looks like. The fresh water tank fill Sporlan valve is located under the bed, left of the hotwater tank, near the fresh water pump. THis also will need cleaned or repaired eventually. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > We are on our maiden voyage in the new to us Bird. I will post a story > of the trip later. Right now I have a small problem. I have the blue > Box for our unit but section 10 with all the plumbing and electrical > diagrams is missing. Our coach has a heater (engine hot water) under > the kitchen drawers beside the fridge. We are in AZ. It was 101 today. > My wife went to get something from the drawers and she said she almost > burned herself. I checked and the heater core. It is damn hot. Checked > the switch for summer/winter and it is set on summer. How do I stop > the water from circulating to the heaters? I know the switch is > supposed to activate a solenoid. Where is that solenoid located? Why > couldnt they use a simple Ranco valve? Without the diagram for the > heaters I am having trouble figuring how this works. Are there > seperate lines going to the water heater? For now I would like to just > install a simple gate valve to stop the water from entering the > heater. I havent yet checked to see if the other heaters are also hot. > > Thanks: Bruce > |
