Maiden Voyage report
05-24-2006, 13:51
We finally picked up our 88 FC35 on Friday. It was located in
Chillicothe Ohio. Arrived late afternoon and verything went smooth until we hooked up the lights to our toad. Someone had changed all the coach wires. Red was left, Blue was right?? After playing around for an hour I got mad and cut all the wires and spliced into my umbilical cord. We hit the road and spent the nite at a Wal Mart. A few minor glitches. When I road tested this baby there was a whistle whenever you tromped the throttle. I figured a turbo leak. He took it to some shop and they had tightened the clamps. First time I had to climb the whistle was still there. I discovered a hose that was on at an angle. But it was stuck to the turbo housing. I finally removed all the clamps but it would not budge. Duck tape to the rescue (shame). Worked OK. So many guages and switches!! I was surprised at how it handled my 4500 lb. Toyota Tacoma. Not a hot rod but alright. The roads on our route were terrible: Ohio.Illinois, Indiana and the worst was Oklahoma.We hitTexas yesterday and it was 90 degrees. The dash air works surprisingly well. But there is a lot of air infiltration on the drivers side. Appears to be down by the steering column. Today we arrived in AZ. It was 101. Engine temp went to 210 to 215. But the fan overide brings it down to 180.Our original 3801 Dometic is cold as freezer in this heat. But I dont trust it. New fridge is on order. We changed the original mattress and it is now heavenly. I must have some air leaks as the iar drops overnite. I also noticed that if you hit the brakes 3 or 4 times in a row the pressure drops way too fast to less than 90. I cannot believe this is normal?? I have more questions but will post them seperately.. Bruce 1988 Fc 35 |
05-24-2006, 14:26
BlueBird did not use the standard Bargman wiring for the trailer
lights. I carry a "bluebird adapter". You will hear the turbo whistle, that is normal with the 300hp ATAAC, the tubing to/from the aftercooler transmits the turbine whine. Use the sound to conserve fuel. Pumping air brakes is bad, read the manual. You will lose air pressure. If you follow the procedures for checking air-brake systems, (required for a commercial license with air-brake endorsement, and IMO should be required for driving air-braked vehicles) you will find a test that is done with the engine off, depressing and holding the brake pedal, and watching for either gauge to drop. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > We finally picked up our 88 FC35 on Friday. It was located in > Chillicothe Ohio. Arrived late afternoon and verything went smooth > until we hooked up the lights to our toad. Someone had changed all > the coach wires. Red was left, Blue was right?? After playing around > for an hour I got mad and cut all the wires and spliced into my > umbilical cord. We hit the road and spent the nite at a Wal Mart. A > few minor glitches. When I road tested this baby there was a whistle > whenever you tromped the throttle. I figured a turbo leak. He took > it to some shop and they had tightened the clamps. First time I had > to climb the whistle was still there. I discovered a hose that was > on at an angle. But it was stuck to the turbo housing. I finally > removed all the clamps but it would not budge. Duck tape to the > rescue (shame). Worked OK. So many guages and switches!! I was > surprised at how it handled my 4500 lb. Toyota Tacoma. Not a hot rod > but alright. The roads on our route were terrible: Ohio.Illinois, > Indiana and the worst was Oklahoma.We hitTexas yesterday and it was > 90 degrees. The dash air works surprisingly well. But there is a lot > of air infiltration on the drivers side. Appears to be down by the > steering column. Today we arrived in AZ. It was 101. Engine temp > went to 210 to 215. But the fan overide brings it down to 180.Our > original 3801 Dometic is cold as freezer in this heat. But I dont > trust it. New fridge is on order. We changed the original mattress > and it is now heavenly. I must have some air leaks as the iar drops > overnite. I also noticed that if you hit the brakes 3 or 4 times in > a row the pressure drops way too fast to less than 90. I cannot > believe this is normal?? I have more questions but will post them > seperately.. > > Bruce 1988 Fc 35 > |
05-24-2006, 14:32
read the manual...Jeff, good input/advice. I thought the 1974 (previous
coach) had problems with the air system until you, Randy, and others told me the same. Turned out the system was more than within California tolerances. New owner is happy too! Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Jeff Miller wrote: > BlueBird did not use the standard Bargman wiring for the trailer > lights. I carry a "bluebird adapter". > > You will hear the turbo whistle, that is normal with the 300hp > ATAAC, the tubing to/from the aftercooler transmits the turbine > whine. Use the sound to conserve fuel. > > Pumping air brakes is bad, read the manual. You will lose air > pressure. If you follow the procedures for checking air-brake > systems, (required for a commercial license with air-brake > endorsement, and IMO should be required for driving air-braked > vehicles) you will find a test that is done with the engine off, > depressing and holding the brake pedal, and watching for either > gauge to drop. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > > > > We finally picked up our 88 FC35 on Friday. It was located in > > Chillicothe Ohio. Arrived late afternoon and verything went smooth > > until we hooked up the lights to our toad. Someone had changed all > > the coach wires. Red was left, Blue was right?? After playing > around > > for an hour I got mad and cut all the wires and spliced into my > > umbilical cord. We hit the road and spent the nite at a Wal Mart. > A > > few minor glitches. When I road tested this baby there was a > whistle > > whenever you tromped the throttle. I figured a turbo leak. He took > > it to some shop and they had tightened the clamps. First time I > had > > to climb the whistle was still there. I discovered a hose that was > > on at an angle. But it was stuck to the turbo housing. I finally > > removed all the clamps but it would not budge. Duck tape to the > > rescue (shame). Worked OK. So many guages and switches!! I was > > surprised at how it handled my 4500 lb. Toyota Tacoma. Not a hot > rod > > but alright. The roads on our route were terrible: Ohio.Illinois, > > Indiana and the worst was Oklahoma.We hitTexas yesterday and it > was > > 90 degrees. The dash air works surprisingly well. But there is a > lot > > of air infiltration on the drivers side. Appears to be down by the > > steering column. Today we arrived in AZ. It was 101. Engine temp > > went to 210 to 215. But the fan overide brings it down to 180.Our > > original 3801 Dometic is cold as freezer in this heat. But I dont > > trust it. New fridge is on order. We changed the original mattress > > and it is now heavenly. I must have some air leaks as the iar > drops > > overnite. I also noticed that if you hit the brakes 3 or 4 times > in > > a row the pressure drops way too fast to less than 90. I cannot > > believe this is normal?? I have more questions but will post them > > seperately.. > > > > Bruce 1988 Fc 35 > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
