installing new toilet
05-24-2006, 13:55
Our Fc 35 has the original Thetford Aqua magic 4. Works good but I
prefer the china bowls. However the toilet fits between a fitted tiled enclosure. Has anyone ever changed to a diff. toilet? How did you handle the tiles? The newer toilets are not as wide but I wonder how the edges fo the enclosure are finsihed?? THanks: Bruce FC35 1988 |
05-25-2006, 01:59
Bruce,
Yep, I would also be interested in the toilet responses. Stephen Britles ships the Sporlan repair Kits. These were difficult for me to find locally. Use the ZF trans retarder more it works great. Uses no air. There is a drawing of the seven pin toad, tail light plug, somewhere in the files, on one of the forums. I do not remember where it is located. The wiring connections could be different than what, you consider standard. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Our Fc 35 has the original Thetford Aqua magic 4. Works good but I > prefer the china bowls. However the toilet fits between a fitted > tiled enclosure. Has anyone ever changed to a diff. toilet? How did > you handle the tiles? The newer toilets are not as wide but I wonder > how the edges fo the enclosure are finsihed?? > > THanks: Bruce FC35 1988 > |
05-25-2006, 13:38
On my 1987 fc,I had Holland Motor Homes install a new china toilet.
They trimed the tile so that the toilet would fit. Then they trimmed the front and top with 3 inch wide strips of corian. They attached it with silicone. It looked real nice. Ron Hazlett 1987 fc Toledo, Ohio > Our Fc 35 has the original Thetford Aqua magic 4. Works good but I > prefer the china bowls. However the toilet fits between a fitted > tiled enclosure. Has anyone ever changed to a diff. toilet? How did > you handle the tiles? The newer toilets are not as wide but I wonder > how the edges fo the enclosure are finsihed?? > > THanks: Bruce FC35 1988 > |
05-26-2006, 00:53
Hey Ron,
Do you know the toilet manufacturer and model number?? Your 87 is one of my favorite FCs. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett" > > On my 1987 fc,I had Holland Motor Homes install a new china toilet. > They trimed the tile so that the toilet would fit. Then they trimmed > the front and top with 3 inch wide strips of corian. They attached it > with silicone. It looked real nice. > > Ron Hazlett > 1987 fc > Toledo, Ohio > > > > Our Fc 35 has the original Thetford Aqua magic 4. Works good but I > > prefer the china bowls. However the toilet fits between a fitted > > tiled enclosure. Has anyone ever changed to a diff. toilet? How did > > you handle the tiles? The newer toilets are not as wide but I wonder > > how the edges fo the enclosure are finsihed?? > > > > THanks: Bruce FC35 1988 > > > |
06-05-2006, 15:19
Hey Bill
The toilet I had installed in my 87 FC was Thetford Aria. It is a full size china toilet with electric controls. The new toilet took up more space (24 inches in length),but it was worth it once we got used to it. Ron Hazlett 1987FC Toledo, Ohio --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > Hey Ron, > > Do you know the toilet manufacturer and model number?? > Your 87 is one of my favorite FCs. > > Bill 88 FC Michigan > > |
06-06-2006, 00:25
Ron,
Thanks for the toilet info, This is something I need to do eventually. Keep us posted on your 87 adventures. Drove thru Toledo last week, Still recovering from the Tony Packo, Combo platter. Bill 88 FC Michigan 70 miles North --- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett" > > Hey Bill > > The toilet I had installed in my 87 FC was Thetford Aria. It is a full > size china toilet with electric controls. The new toilet took up more > space (24 inches in length),but it was worth it once we got used to it. > > > Ron Hazlett > 1987FC > Toledo, Ohio > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > wrote: > > > > > > Hey Ron, > > > > Do you know the toilet manufacturer and model number?? > > Your 87 is one of my favorite FCs. > > > > Bill 88 FC Michigan > > > > > |
