update on Do Not Shift Light.
05-25-2006, 00:57
Hi Rick,
Have you called several Allison dealers/service centers and asked for their advice? Maybe you could consider calling a mobile service mechanic, if there is no other choice other than towing. Perhaps the Allison dealer in your area could make a recommendation regarding a mobile mechanic. Just some thoughts.... Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
05-25-2006, 03:44
I just replaced the tachometer sending unit and tang drive. This fixed
the problem with the tachometer from jumping from 1000 rpm to 2200 rpm. Was hoping this was the problem with the do not shift light. Light still on and back to asking questions. Does anyone have any other ideas before i have to have it towed into a repair shop 100 miles away. Kindest Regards, Rick Mcintire 86PT38 Patillo,TX 1-800-999-7107 |
05-25-2006, 06:54
Kevin, I have been talking to Allison and several of the dealers. I have did everything they have told me to do. I did talk to one that said they would send someone out. They are going to charge me $350.00 for service call plus $75.00 labor and driving time also. If they don't have the right parts they will have to come back out again. Might have to go that way because we are full timing it right now and need to find a place to stay if they tow it in. Best Regards, Rick Mcintire 86PT38 Patillo,Tx -- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Hi Rick, > > Have you called several Allison dealers/service centers and asked for their > advice? Maybe you could consider calling a mobile service mechanic, if there > is no other choice other than towing. Perhaps the Allison dealer in your > area could make a recommendation regarding a mobile mechanic. Just some > thoughts.... > > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > |
05-25-2006, 07:59
Not an outrageous price from what I've heard from many
others. Perhaps a repeat; however, if you do have it towed, ensure the drive axle is either disconnected, the drive wheels on a tow dolly, or towed with drive wheels not touching road, to prohibit turning the drive train - you would not want damage/further damage. Best of luck, John Suter --- trautoranch > - > Kevin, I have been talking to Allison and several of > the dealers. I > have did everything they have told me to do. I did > talk to one that > said they would send someone out. They are going to > charge me $350.00 > for service call plus $75.00 labor and driving time > also. If they > don't have the right parts they will have to come > back out again. > Might have to go that way because we are full timing > it right now and > need to find a place to stay if they tow it in. > Best Regards, > Rick Mcintire > 86PT38 Patillo,Tx > -- In WanderlodgeForum@yahoogroups.com, krminyl@... > wrote: > > > > Hi Rick, > > > > Have you called several Allison dealers/service > centers and asked > for their > > advice? Maybe you could consider calling a mobile > service > mechanic, if there > > is no other choice other than towing. Perhaps the > Allison dealer > in your > > area could make a recommendation regarding a > mobile mechanic. > Just some > > thoughts.... > > > > > > Kevin McKeown > > Yorba Linda, CA > > 1986 38' PT > > > > > > [Non-text portions of this message have been > removed] > > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
05-25-2006, 08:20
Is there a diagnostic plug for the transmission? Can it be diagnosed
with an OBD code reader? If so, it may be worth purchasing a reader and getting the diagnostic codes. You should be able to pick up a code reader from auto parts store for under $200. Some code readers allow you to reset the computer, perhaps that is all that is needed. Kerry 82 FC 35 Denver |
05-25-2006, 08:27
Kerry,
Good thought. Parts stores here loan out the reader if you leave a small deposit. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. davidkerryedwards wrote: > Is there a diagnostic plug for the transmission? Can it be diagnosed > with an OBD code reader? If so, it may be worth purchasing a reader > and getting the diagnostic codes. You should be able to pick up a > code reader from auto parts store for under $200. Some code readers > allow you to reset the computer, perhaps that is all that is needed. > > Kerry > 82 FC 35 > Denver > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
05-25-2006, 09:26
Here's a link which interprets Allison diagnostic codes:
http://www.fdda.com/WT%20Diagnostic%20Codes.html Kerry 82 FC 35 --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Kerry, > Good thought. Parts stores here loan out the reader if you leave a small > deposit. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > davidkerryedwards wrote: > > > Is there a diagnostic plug for the transmission? Can it be diagnosed > > with an OBD code reader? If so, it may be worth purchasing a reader > > and getting the diagnostic codes. You should be able to pick up a > > code reader from auto parts store for under $200. Some code readers > > allow you to reset the computer, perhaps that is all that is needed. > > > > Kerry > > 82 FC 35 > > Denver > > > > > > > > > > > > > > SPONSORED LINKS > > Recreational vehicles > > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > > Recreational vehicle financing > > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > > Recreational vehicle repair > > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > > > Recreational vehicle rental > > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > > Recreational vehicle camper > > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > > Recreational vehicle rate > > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > > > > > ------------------------------------------------------------------------ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ------------------------------------------------------------------------ > > > |
05-25-2006, 16:38
Call A to Z Bus sales in Colton Ca 951-781-7188 their allison tec may
help you out. $350. sounds steep. Where are you at? Gregory O'Connor 94pt Romoland,CA @yahoogroups.com, "trautoranch" > > - > Kevin, I have been talking to Allison and several of the dealers. I > have did everything they have told me to do. I did talk to one that > said they would send someone out. They are going to charge me $350.00 > for service call plus $75.00 labor and driving time also. If they > don't have the right parts they will have to come back out again. > Might have to go that way because we are full timing it right now and > need to find a place to stay if they tow it in. > Best Regards, > Rick Mcintire > 86PT38 Patillo,Tx > -- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > Hi Rick, > > > > Have you called several Allison dealers/service centers and asked > for their > > advice? Maybe you could consider calling a mobile service > mechanic, if there > > is no other choice other than towing. Perhaps the Allison dealer > in your > > area could make a recommendation regarding a mobile mechanic. > Just some > > thoughts.... > > > > > > Kevin McKeown > > Yorba Linda, CA > > 1986 38' PT > > > > > > [Non-text portions of this message have been removed] > > > |
05-26-2006, 07:46
Thanks to all of you for the information. I have found a tech to come
to our place for $50.00 service and $50.00 per hr. labor plus parts. Kindest Regards, Rick & Terri Mcintire 86PT38 Patillo,Tx. (west of Ft.Worth,TX) --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Call A to Z Bus sales in Colton Ca 951-781-7188 their allison tec may > help you out. $350. sounds steep. Where are you at? > Gregory O'Connor > 94pt Romoland,CA > > @yahoogroups.com, "trautoranch" > > > > - > > Kevin, I have been talking to Allison and several of the dealers. I > > have did everything they have told me to do. I did talk to one that > > said they would send someone out. They are going to charge me > $350.00 > > for service call plus $75.00 labor and driving time also. If they > > don't have the right parts they will have to come back out again. > > Might have to go that way because we are full timing it right now > and > > need to find a place to stay if they tow it in. > > Best Regards, > > Rick Mcintire > > 86PT38 Patillo,Tx > > -- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > > > Hi Rick, > > > > > > Have you called several Allison dealers/service centers and asked > > for their > > > advice? Maybe you could consider calling a mobile service > > mechanic, if there > > > is no other choice other than towing. Perhaps the Allison dealer > > in your > > > area could make a recommendation regarding a mobile mechanic. > > Just some > > > thoughts.... > > > > > > > > > Kevin McKeown > > > Yorba Linda, CA > > > 1986 38' PT > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
06-12-2006, 02:11
Rick, did your problem fix? what was the cause??
Greg, driving with do not shift blinking on and off 94 ptRomoland Ca --- In WanderlodgeForum@yahoogroups.com, "trautoranch" wrote: > > Thanks to all of you for the information. I have found a tech to come > to our place for $50.00 service and $50.00 per hr. labor plus parts. > Kindest Regards, > Rick & Terri Mcintire > 86PT38 Patillo,Tx. (west of Ft.Worth,TX) |
