Detroit 8V92 question
05-26-2006, 07:00
How many gallons of oil does the standard 8V92 require when changing
oil and filters? Any online sources for Rotella 40wt oil? Troy 1986 Newell |
05-26-2006, 08:40
Troy,
Book says 23 quarts for the refill...25 quarts dry. I believe you add another 3 quarts for the oil filter. Can't help with the Rotella. I use Mobil Delvac 40wt and I buy it and the oil filters from Detroit dealer. Fill the oil filter and screw it on. Dump in 5 gallons and check the dipstick. Full is between the low & full marks. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. ttikalsky wrote: > How many gallons of oil does the standard 8V92 require when changing > oil and filters? > > Any online sources for Rotella 40wt oil? > > Troy > 1986 Newell > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
05-26-2006, 08:45
Troy:
As well as being a member of the wanderlodge, you should join the bus nuts, MCI9 bus nuts groups. A lot of them are running the DD and they are always talking about them. Bill ttikalsky How many gallons of oil does the standard 8V92 require when changing oil and filters? Any online sources for Rotella 40wt oil? Troy 1986 Newell SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- All new Yahoo! Mail --------------------------------- Get news delivered. Enjoy RSS feeds right on your Mail page. [Non-text portions of this message have been removed] |
05-26-2006, 10:32
Curt; when I had my 8V92 overhauled last year the DD said use 30 wt winter
and 40 wt summer do not use muligrade oil since its hard on a DD and will cause the engine to burn oil.matter of fact they would not stand behind the engine if I did not use single grade oil.Dave 91 WBWL PT 40 >From: Curt Sprenger >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Detroit 8V92 question >Date: Fri, 26 May 2006 13:40:12 -0700 > > > > >Troy, > > > >Book says 23 quarts for the refill...25 quarts dry. I believe you add > >another 3 quarts for the oil filter. Can't help with the Rotella. I use > >Mobil Delvac 40wt and I buy it and the oil filters from Detroit dealer. > > > >Fill the oil filter and screw it on. Dump in 5 gallons and check the > >dipstick. Full is between the low & full marks. > > > >Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > >ttikalsky wrote: > > > > > How many gallons of oil does the standard 8V92 require when changing > > > oil and filters? > > > > > > Any online sources for Rotella 40wt oil? > > > > > > Troy > > > 1986 Newell > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > > Recreational vehicles > > > ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreat\ ional+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate\ &c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > > > Â Â Â Â Â Recreational vehicle financing > > > ><http://groups.yahoo.com/gads?t=ms&k=Recr...reati\ onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w\ 4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+veh\ icle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > > > Â Â Â Â Â Recreational vehicle repair > > > ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > > > > > Recreational vehicle rental > > > ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > > > Â Â Â Â Â Recreational vehicle camper > > > ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > > > Â Â Â Â Â Recreational vehicle rate > > > ><http://groups.yahoo.com/gads?t=ms&k=Recr...onal+\ vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Rec\ reational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+\ rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > > > > > > > > > ------------------------------------------------------------------------ > > > YAHOO! GROUPS LINKS > > > > > > Â Â Â * Visit your group "WanderlodgeForum > > > Â Â Â Â Â <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > > > Â Â Â * To unsubscribe from this group, send an email to: > > > Â Â Â Â Â Â WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > > Â Â Â * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > > Â Â Â Â Â Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > ------------------------------------------------------------------------ > > > > > > > > > > > > > > SPONSORED LINKS > > > > > Recreational vehicles > > > Recreational vehicle financing > > > Recreational vehicle repair > > > > > Recreational vehicle rental > > > Recreational vehicle camper > > > Recreational vehicle rate > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > |
06-02-2006, 07:57
Thanks Bill, I belong to the MCI and the Detroit Diesel two stroke
forums but they mostly discuss hot rodding the Detroits and I prefer reliablility. Troy --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Troy: > As well as being a member of the wanderlodge, you should join the bus nuts, MCI9 bus nuts groups. A lot of them are running the DD and they are always talking about them. > > Bill > > ttikalsky > How many gallons of oil does the standard 8V92 require when changing > oil and filters? > > Any online sources for Rotella 40wt oil? > > Troy > 1986 Newell > > > > > > > SPONSORED LINKS > Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > > --------------------------------- > All new Yahoo! Mail > --------------------------------- > Get news delivered. Enjoy RSS feeds right on your Mail page. > > [Non-text portions of this message have been removed] > |
06-02-2006, 15:18
Troy try this link
http://www.rotella.com/wheretobuy/wheret...utors.html Stephen 77fc35 but still a delo user --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > > Thanks Bill, I belong to the MCI and the Detroit Diesel two stroke > forums but they mostly discuss hot rodding the Detroits and I prefer > reliablility. > > Troy > > > --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > > > > Troy: > > As well as being a member of the wanderlodge, you should join the > bus nuts, MCI9 bus nuts groups. A lot of them are running the DD and > they are always talking about them. > > > > Bill > > > > ttikalsky > > How many gallons of oil does the standard 8V92 require when changing > > oil and filters? > > > > Any online sources for Rotella 40wt oil? > > > > Troy > > 1986 Newell > > > > > > > > > > > > > > SPONSORED LINKS > > Recreational vehicles Recreational vehicle financing > Recreational vehicle repair Recreational vehicle rental > Recreational vehicle camper Recreational vehicle rate > > > > --------------------------------- > > YAHOO! GROUPS LINKS > > > > > > Visit your group "WanderlodgeForum" on the web. > > > > To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > --------------------------------- > > > > > > > > > > > > --------------------------------- > > All new Yahoo! Mail > > --------------------------------- > > Get news delivered. Enjoy RSS feeds right on your Mail page. > > > > [Non-text portions of this message have been removed] > > > |
06-02-2006, 15:19
Troy try this link
http://www.rotella.com/wheretobuy/wheret...utors.html http://www.rotella.com/products/rotella_t_single.html Stephen 77fc35 but still a delo user --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > > Thanks Bill, I belong to the MCI and the Detroit Diesel two stroke > forums but they mostly discuss hot rodding the Detroits and I prefer > reliablility. > > Troy > > > --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > > > > Troy: > > As well as being a member of the wanderlodge, you should join the > bus nuts, MCI9 bus nuts groups. A lot of them are running the DD and > they are always talking about them. > > > > Bill > > > > ttikalsky > > How many gallons of oil does the standard 8V92 require when changing > > oil and filters? > > > > Any online sources for Rotella 40wt oil? > > > > Troy > > 1986 Newell > > > > > > > > > > > > > > SPONSORED LINKS > > Recreational vehicles Recreational vehicle financing > Recreational vehicle repair Recreational vehicle rental > Recreational vehicle camper Recreational vehicle rate > > > > --------------------------------- > > YAHOO! GROUPS LINKS > > > > > > Visit your group "WanderlodgeForum" on the web. > > > > To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > --------------------------------- > > > > > > > > > > > > --------------------------------- > > All new Yahoo! Mail > > --------------------------------- > > Get news delivered. Enjoy RSS feeds right on your Mail page. > > > > [Non-text portions of this message have been removed] > > > |
