coolant question from CO
05-28-2006, 00:08
Guy- had one of those hoses leak on my coach. Closed all valves- and no
problem. You can fix it later. Ernie-83pt40- Livingston, Montana
05-28-2006, 00:17
thosse valvs are hard to find and tough to get to. I believe there are 4?
Ernie- not at tthe coach to count
05-28-2006, 04:06
Hi
we are in Breckenridge CO loving it. Tiger Run RV resort which is great.
The BB is running good after settling in I notice the secondary coolant hoses
that go to the
heating system was leaking, the main hoses are fine it is har to see which hose
is leaking.
my question the engine is running cool so if i close the values (4) to the
heating system am I
ok to run the coach? as I mentiom the main hoses to and from the engine &
radiator are fine.
I would prefer to work on her at home. I have a silver 92 v8 tubo
any thoughts?
guy smalley
86 pt 40
05-28-2006, 04:09
Hi Guy:
Close the valves and run. Remember though, you may not have the hydro heat
to the hot water tank after a run.
Safe travels,
At 04:06 PM 5/28/2006 +0000, you wrote:
>Hi
>hoses that go to the
>hose is leaking.
>heating system am I
>radiator are fine.
>any thoughts?
>guy smalley
>86 pt 40
05-28-2006, 05:31
The blue book says four I found three easy then the fourth behind the back
bumper
-guy smalley
User(s) browsing this thread: 9 Guest(s)
