New Tires
11-16-2006, 09:12
Post: #31
New Tires
Leroy- a couple of years ago, we were coming back from the RIV, and had to
slow down for traffic. Brenda noticed a strange noise from her side of the
coach. Comes to find out that the steel had separated from the tread and thus-
new
tires were installed on our coach. The pain of writing the check was less then
the upcoming blowout that might have taken us all out.
83 PT40
Livingston, Montana
11-16-2006, 12:43
Post: #32
New Tires
Well, installing six new tires on the back of a WB-40 is akin to
sitting on a tack---very painful---but it did not happen one day to
soon! I've read the posts and they were correct. I could not believe
the extent of sidewall cracking when the tires were being removed from
the rims.
Leroy Eckert
1990 WB-40 "Smoke N Mirrors"
Niceville, FL
11-16-2006, 13:15
Post: #33
New Tires
Leroy,
From your post I get the impression the cracking was not apparent
with a visual inspection with the tires on the coach. Is that
correct?
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "jwasnewski"
to
believe
from
> the rims.
> Leroy Eckert
> Niceville, FL
11-16-2006, 14:58
Post: #34
New Tires
Gardner:
That is correct! I carefully inspect my coach in all areas on a cycle basis. I
knew the rear tires were old (DOT codes) and below I will give the age and what
I found so others can evaluate their position. Some things I noticed I do not
understand.
On the last two trips approx 2000 miles I lost a few deco lug nut covers. I
wondered why? I found out when the technician removed the wheels. 4 of the lug
nuts on the duals on each side were hand tight. Understand that I have put
20,000 miles on this coach with very few problems. I never considered checking
the lug nuts, in fact I do not have the tools to do the job. Perhaps someone on
this forum can shed light about keeping your lug nuts tight. Do I need an 11/2"
socket and a five foot bar or what? How did those lugs get loose?
As for the tires. The tag and outside dual tires were Michelen 12R 22.5 ZX
9years old with minor visual checking. Most of the noticable checking was
evident on the radius around the cap. Since I could not readily inspect the
sidewalls of the interior duals I had not idea as to their quality. The inside
tires on the duals were 6 years old. The sidewalls of the inside tires were
absolute trash, ready to go boom. Anyone have any idea on that? Three years
younger than the outside tires and no sun? Can't blame the ozone layer or UV
for that deal.
That tack feels better now. After all, the family rides in the bus.
Leroy Eckert
Niceville, FL
Sent: Thursday, November 16, 2006 7:15 PM
Subject: [WanderlodgeForum] Re: New Tires
Leroy,
correct?
Gardner
78FC33
to
believe
from
> the rims.
> Leroy Eckert
> Niceville, FL
11-16-2006, 15:24
Post: #35
New Tires
Leroy I saw the same thing once before. A guy parked next to us and after
about an hour or so an outside dually blew. When he took it off the inside
dually looked absolutely horrid. It had more checking and deterioration than
the outside one. They were both the same age. Can't explain it.
On 16/11/06, Leroy Eckert wrote:
> Gardner:
> basis. I knew the rear tires were old (DOT codes) and below I will give the
> age and what I found so others can evaluate their position. Some things I
> noticed I do not understand.
> I wondered why? I found out when the technician removed the wheels. 4 of the
> lug nuts on the duals on each side were hand tight. Understand that I have
> put 20,000 miles on this coach with very few problems. I never considered
> checking the lug nuts, in fact I do not have the tools to do the job.
> Perhaps someone on this forum can shed light about keeping your lug nuts
> tight. Do I need an 11/2" socket and a five foot bar or what? How did those
> lugs get loose?
> inside tires on the duals were 6 years old. The sidewalls of the inside
> tires were absolute trash, ready to go boom. Anyone have any idea on that?
> Three years younger than the outside tires and no sun? Can't blame the ozone
> layer or UV for that deal.
> Leroy Eckert
> Niceville, FL
> From: Gardner Yeaw
> Leroy,
> correct?
> Gardner
> 78FC33
> "jwasnewski"
> to
> believe
> from
> > the rims.
> > Leroy Eckert
> > Niceville, FL
Rob, Sue & Merlin Robinson
94 WLWB
11-16-2006, 15:56
Post: #36
New Tires
Rob:
Perhaps some things are to be left unexplained. I take care of my bus. I
watched the removal of the tires for a reason. I guess what I saw tells me to
reserve $70.00 per month and change 8 tires every 5 years whether they need it
or not. Frankly, what I saw wasn't pretty. I cannot ride my family around on
that kind of tire.
Leroy Eckert
Niceville, FL
Sent: Thursday, November 16, 2006 9:24 PM
Subject: Re: [WanderlodgeForum] Re: New Tires
> Gardner:
> lugs get loose?
> Leroy Eckert
> Niceville, FL
> From: Gardner Yeaw
> Leroy,
> correct?
> Gardner
> 78FC33
> "jwasnewski"
> to
> believe
> from
> > the rims.
> > Leroy Eckert
> > Niceville, FL
94 WLWB
11-16-2006, 16:01
Post: #37
New Tires
Yes sir, I have learned a valuable lesson. 5 years from the date of
installation and they are gone off my bus.
Leroy Eckert
1990 WB-40 "Smoke N Mirors"
Niceville, FL
Sent: Thursday, November 16, 2006 8:12 PM
Subject: Re: [WanderlodgeForum] New Tires
new
83 PT40
Livingston, Montana
11-16-2006, 18:10
Post: #38
New Tires
Leroy,
How old are the tires you are replacing.
Howard Truitt
Camilla, Ga.
86 PT40
"Under The Waterfall"
Sent: Thursday, November 16, 2006 7:43 PM
Subject: [WanderlodgeForum] New Tires
the rims.
Leroy Eckert
Niceville, FL
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.14.6/536 - Release Date: 11/16/2006
11-16-2006, 18:26
Post: #39
New Tires
I think you will find that the inside duals do not get checked properly. Lower
pressure can lead to higher tire temps and a faster breakdown of the inside
duals.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Thursday, November 16, 2006 10:24 PM
> Gardner:
> lugs get loose?
> Leroy Eckert
> Niceville, FL
> From: Gardner Yeaw
> Leroy,
> correct?
> Gardner
> 78FC33
> "jwasnewski"
> to
> believe
> from
> > the rims.
> > Leroy Eckert
> > Niceville, FL
94 WLWB
